Hobbit - flywheel holder
Does anyone have a recommended for a flywheel holder for a Hobbit. My DIY model made from bolts, nuts and a wooden handle finally gave out. I know Treats has several types but the person I emailed could not guarantee any would work on a Hobbit. Thanks Jack
Re: Hobbit - flywheel holder
Stuff a bunch of rope down the spark plug hole in the cylinder, bam, motor won't turn over anymore. (edited)
I use a tiedown . Wrap it around the flywheel . Hook it to itself and then to the rear frame and sinch it tight . Undue the nut and if the flywheel still turns , step on the tiedown to tighten it more .
Its called an impact drill. Or just hit the wrench with a hammer.
