When all wires are connected the horn just blows continuously.
When I hook up all the wires on my A35, the blinkers stop working and the horn just blows and blows if I disconnect the horn the signals work perfectly. What the heck? Am I missing a ground on the triple tree? Or what could cause this. Even stranger when I parked it last night it all worked, somewhat. The left blinkers worked, but the right ones would also make the front left blinker also, blink ever so slightly. But the horn did work perfectly. Any ideas? If nothing I’ll just trash the horn. You can’t hear it in traffic anyway ..... it’s a non oem v6 horn. Do I need a 12v horn? I noticed this cause when I got on and checked the blinkers, the rear right wouldn’t light at all, even with the horn hooked up back left was dead. I know the wires are connected cause I did the wiring. After I unhooked the horn that blinker worked perfectly. Why would the horn effect the turn signals?
Re: When all wires are connected the horn just blows continuously.
THATs how it’s supposed to be.
Safety first
♣Slew Foot♣ /
The tail wiring that goes through the frame and fender is freyed...
And the blinkers only work when there is enough electrical charge produced by the engine to power them. So you have to be at a higher rpm to get them going at first.
♣Slew Foot♣ /
The buzzing the buzzing.
Plastic on Speedo is vibrating.
Terbo Speghetti /
Loud pipes save lives
Alarms do that when a vehicle is stolen
♣Slew Foot♣ /
Tomos a35 is 12v for the horn.
Moped horns... you cant hear them at high speeds, and they are too quiet or dont work at all when stopped and idling.
♣Slew Foot♣ /
Tomos resonate to the frequency of NJ how far away are you you might be on a node...
Cut the horn wire. In the movies they always cut a blue wire so look for a blue wire.
not grounded horn will blow
