Jawa x30 carb tuning
Richard Brawner Jr /
Whats a good turning on carburetor jawa x30?
Re: Jawa x30 carb tuning
That would depend entirely on your setup.
Most people try to ditch the stock carb in favor of a Dellorto SHA or something else. Check out this article on the moped wiki: https://www.mopedarmy.com/wiki/Jawa_Tuning
What carburetor do you recommend best?
A 15 SHA is easy, but you'll have to fab up an intake. See the wiki article.
I don't have any tools to do any fabbing
Would this do
https://www.amazon.com/dp/B07FFSH865/
Not if you can't fab an intake.
Get used to using the stock Jikov carb. I'd start with the stock jet, and tune appropriately. See https://www.mopedarmy.com/wiki/Fred%27s_Guide for general troubleshooting.
What is the diameter of the intake on that engine? I think it could be around or under 10mm. If so, cramming all that air from a 15mm SHA could be a tuning nightmare. You can get an SHA adaptor for Jawa 210 intakes and install a 12mm Bing. Works great on my 207
The stock intake gasket has a 14mm ID hole. Haven't measure the cylinder yet, though apparently the 210 (which has better porting) intake port is 18mm diameter: https://www.mopedarmy.com/forums/read.php?7,2033670
