Puch Newport rewire
Jack Masterson /
Have a e50 with the 6wire setup but the wiring was all messed up when I got it. I've seen a lot of diagrams but nothing that lines up quite right. I have all the wires out of the stator and all stock head/tail lights, horn, speedometer, etc. which I would like to get working. My light switch is confusing me though, from my picture, yellow is going to stator yellow and gray is going to the horn/blueblack. Should I add another wire based on the diagram to connect Lo to the headlight? Also where does it hook up to the rear light?
Re: Puch Newport rewire
The yellow is your light. Yes I't does go to the coil. No you do not need to add another wire to your switch.
If you're doing wiring without a multimeter I highly highly highly recommend buying a cheap one off Amazon. Then you could tell definitively what terminals on the switch are connected when the lights are set to on, the horn button is pressed, etc.
