What is this clanking sound? 2005 Tomos ST
Sound starts when i pull the throttle a a bit
https://youtube.com/shorts/52T3eH4eAg4?feature=share
Re: What is this clanking sound? 2005 Tomos ST
Tighten down head and exhaust bolts n try again.
still does it.. is this a normal sound?
♣Slew Foot♣ /
Sometimes the Speedo vibrates and is it a quick thunk when it gets load? If it's the latter it's the question mark spring on the countershaft. Kickstarter cage roller wear.
no, it only does this when I blip the throttle.. it doesn't rattle when riding at speed. only when idling + a bit of throttle
I'm not sure it's your issue, but I have come across bkes where the first gear clutch rattles. It goes away once the clutch engages.
could be the nut holding on the clutches is coming loose
Idk man that sou dad a lot like the small end co. Rod bearing / bushing. My ped had a something very similar good luck dude it really could be almost anything
