Honda PA50 Not Running
I’ve got a 1980 Honda PA50 and for whatever reason I cannot get it to run. I’ve got spark and a good amount of compression, but for whatever reason, I can’t get fuel to the engine. The float bowl fills up just fine with no leaks and I’ve cleaned the carb twice on it and the jet is perfectly fine. It’ll run for about a second if I shoot some staring in the motor, but that’s about it.
Re: Honda PA50 Not Running
Jesse Nordlander /
Air leak, probably cranks seals
Daveen Bavari /
Any other possible issues?
The crank seal behind your clutch is likely bad, ive seen 3 bad ones outta 5.
Daveen Bavari /
Okay, I’ll get those changed out and see what happens. It seems to be relatively common from what I’ve read in other forum posts
Daveen Bavari /
Changing the crank seals didn’t solve my issue.
Daveen Bavari /
I’m so confused with this one
Reeds not opening for some reason, perhaps?
Daveen Bavari /
They seem to flap just fine
Daveen Bavari /
> Jacky Chan Wrote:
> Are you sure you put the seals on the right side?
> https://www.treatland.tv/honda-hobbit-OEM-engine-crankshaft-seal-15-x-25-5-p/honda-hobbit-oem-seal-729684.htm
> https://www.treatland.tv/honda-hobbit-oversize-crankshaft-seal-p/hobbit-not-oem-seal-17-25.5-7.htm
> I did mine wrong and didn't notice till I did a leak down test hope this
> helps
The seals are in the correct orientation
Hmm besides cranks seals the only other possible spots for leaks are case seal, base gasket, head gasket, carb intake and head plus decomp.
Daveen Bavari /
Oh man, I really don’t want to take the engine apart to change the case seal because everything else you listed is either new or in working order XD (edited)
If you locate the leak w a test soap n bubbles then maybe you can superglue or duct tape the leak.
Daveen Bavari /
I checked the case gasket and that’s fine.
Is your plug wet?
Does the fuel drain out of the hose well if you disconnect it from the carb?
Did you replace your condenser? Often you’ll have spark but it won’t run when the condenser is shit.
Lastly, what is your compression reading with s short hose tester?
And are you sure your jets are clear?
You should be able to see thru them, if not... gtr string and some carb cleaner and compressed air is the ticket
How much compression are you getting? "a good amount of compression"
Daveen Bavari /
The plug is completely dry
110 psi
The carb I can assure you is completely clear. It was taken apart entirely, sprayed, and blew compressed air through everything. The bowl does fill up as well.
Does it start w choke? Lots of times i just wanna see a bike run so l load a spray bottle with premix and use that as running fluid. A few squirts in the plug hole to fire it up and squirt fluid down the carb throat and throttle and squirt to hear the motor run and rev out.
Doung that reassures that its fuel related and not spark also lets the motor burn off some cobwebs from sitting so long.
Daveen Bavari /
Doesn’t start with choke. It can run for a little bit if I spray starting fluid in it. The spark plug is completely dry.
If you are getting no fuel there’s only a few things it can be.
1. Reeds not closing
2. Clogged jet (probable cause)
3. Massive air leak causing no vacuum.
4. Clogged petcock
5. No or low compression
Did you literally look thru the jet to see if you can see light thru it? 99% of stock hobbit no fuel issues is a clogged carb.
110 psi with a long hose tester or short hose?
If it’s a short hose that’s low psi. Right on the edge of not running
Dirty30 Dillon /
100% your issue is carburation. JBot got it with the dry plug diag.
Daveen Bavari /
> 4. Clogged petcock
The only thing it could be put of that list is the reeds. I’ve blown and sprayed the carb in every place and yes, I can see light through the jet. The bowl on the carb will fill up with no issues. It’s just not able to get sucked into the engine.
Are you using the metal reeds?
Take em out and look to see if you can again see light thru the ends of the reeds. They can get stuck open with varnish or schmutz.
You really should just do a leak down test.
Daveen Bavari /
They’re plastic ones, so they’re probably slightly warped
Well cut the original metal ones into reed springs that press the reeds shut
Like this.
I bend the springs towards closing before I install, then they push the reeds closed really well
Matt Grantonic /
I agree, carb issue. I like to clean carbs using typical carb/choke cleaner and an air compressor tip at 60 psi or so. ALSO, a strand of fine copper wire through every hole you can find. Funny how you often have to mechanically remove residue when air pressure wont budge it. A very small amount of crud can keep it from running.
Daveen Bavari /
I’ve already done that 3 times. If you want, I can ship it to you so you can clean it for me XD
