What's this hole for?
Patrick Mattison /
So there's a threaded hole on the bottom of this E50 that doesn't appear to be in any of the blocks in the repair guides. It goes through to the lower end, so it will need a bolt in it to run. My question is does something attach there?
Re: What's this hole for?
Patrick Mattison /
Thank you very much.
At first I confused your handle with your reply and thought, "But I don't want any worm dirt in my crankcase..."
it's a crankcase drain if you flood it but really it's unecessary and not all e50s even have it. you've hotta plug it with a bolt and loctite'll help keep it in and sealed. the bolt has to be very short so it doesnt hit the crank
