Tomos A35 trouble
So I slapped an a35 onto a Trac Hawk frame and it was doing ok but not great. It was running and getting into second with a lot of struggling but now its just sputtering when I rev the throttle. I (we (everyone at the garage)) thinks its a timing issue but I also am not 100% convinced. Other theory is fuel delivery. Ok so heres what I got hooked up:
Tomos a35 motor
New seals and bearings
Clutch looking decent
Dellorto Sha 15:15
MLM Pipe
Treats 70CC kit with hi comp head
Things going wrong:
Spark plug is wet
bogging/cutting out when you rev
cant really go above 10mph unless with super super light throttle
Jetting is 64 dellorto
Ok so long post (sorry) but this project has been a struggle which has been fun but well ya know frustrating also. Is there something else that could be going on other than timing? Its running a stock a35 stator and aftermarket cdi from Dos.
One of my other theories is that the flywheel is warped cause when I stupidly tried to take it off without a puller it may have warped a bit. Thoughts? oh also here are some pics.
Re: Tomos A35 trouble
oh should also mention...
tried a 58,66,74,78 jet, all felt the same (but a little different) but still the same overall problem
Try like a 70 or 72. 66 seems pretty low jetting, and 74+ seems extra big. Timing shouldn’t be off if you have the flywheel pin set on it. Tomos have “fixed” ignitions unlike e50’s.
I would inspect the reeds extra closely. If they are not opening and closing properly then it will have a huge affect on the bike running.
Thats what I was thinking Garrett, so it should still be running at least decently, i know there is a very tiny room for adjustment on it so should be ok.
Jay, I will check the reeds again, maybe switch it to a carbon fiber one since I'll have it off?
Another thing, is your piston in the right way? Is the arrow pointing down towards the exhaust?
So whats up withe the duel valve 2 to 1? Get rid of that w just a filter and why is the fuel clear, no oil? So im guessing your float needle is not sealing thus flooding motor. Run it with the petcock off and hear if the motor takes off for a few seconds.
Likely the petcock with a reserve .
And , the fuel filter is backwards .
