Za50 starter clutch is hard to pull
just got my first za50 got it running starting clutch is very tough to pull and then cable popped so replaced it was afraid it was overtightened down low but loosened it and it wont engage the crank so just as someone who is green to za50s before I pull the transmission open what should I expect?
Re: Za50 starter clutch is hard to pull
did the tighten till wheel engages down low and loosen 6 turns but still is crazy tough
to yank
So is it a cable or clutch problem?
clutch, starter specifically
Did you break anything?
took it apart last night everything appears fine starter plate has almost no friction material on the edge
