Honda Hobbit PA50II Throttle Response
I bought a Honda Hobbit a few weeks back. I have done plenty of work on cars but never bikes and almost never carbs. I have an issue that when I pull the throttle cable I get the same response across the board. If I pull the intake filter I also get the same response throughout but higher rpm. I think the guy I bought it from had a clone carb put on it. Do I need to look for a new carb, any videos that may help out, any general advice, or abandon all hope ye who enter? Gonna pull it this weekend and clean everything. Should have more info after that.
Re: Honda Hobbit PA50II Throttle Response
Dirty30 Dillon /
Is the bike stock? You didn't provide any details.
What do you mean by "get the same response"?
There are a couple of guides on the wiki here which might be helpful:
https://mopedarmy.com/wiki/Troubleshooting_guide
https://mopedarmy.com/wiki/Fred%27s_Guide
The bike is stock. Same response as in no rpm change although a twist of the throttle does open the butterfly on the carb.
That's called bogging. Your running too lean. Get some bigger jets.
That or you have airleaks
Or the carb is clogged. Clean it
I doubt it's running lean if it's all stock. Nick is probably right - dirty carb.
Run it with choke and see how the bike responds to enriched fuel mix.
