Tomos StreetmateR A55 Clutch Kickstarter Problem
Anthony Degreif /
I have a Tomos StreetmateR, A55. I replaced the clutch bell and installed a 1st gear jammer clutch. After reassembly, when the engine is running, the kick start arm moves/rotates slowly, in the same direction it does when I kick start the engine. I can hold the kickstart arm and it won't rotate, so there isn't a lot of force trying to move it, but as soon as I let go, it immediately starts to rotate again. This wasn't a problem before I replaced the clutch bell and first gear clutch. Any suggestions as to what would cause this problem? Thank You Thank You.
Re: Tomos StreetmateR A55 Clutch Kickstarter Problem
♣Slew Foot♣ /
Either you didn't check function by letting the pedalshaft drop 2x when engine is held sideways before the clutch nut is tightened.
Roller bearing in pedalshaft gone south...
