Camino Race cranks anyone??
Yea so there are these race cranks for the hondas now. not shur what the price will be but as soon as i know i'll let you guys know.
Re: Camino Race cranks anyone??
yup
this is not new.
That one doesn't look so much like the "Green Tree" crank- so yeah, it may be kind of new...
Dan Webber Kastner /
Here it is for sale. There are a few available right now, with the rest still in shipment. They are a totally new crank. Let us know what you think about them.
Dan
https://www.1977mopeds.com/product/963/Honda-Hobbit-Performance-Crank/
The design is like the pa50III version. I+II=III ;)
Reason I say this is ..
The crank is built thick on the vario side.
You will need a special seal 17x25.4x7, yes honda makes this seal from the factory.
The crank is super strong for you racers.
Amazing quality!
grats, dan.
i couldnt break my green crank, after breaking 2 stockers within 200 miles i bought a green crank and put around 1000 miles on it max RPM rips and it didnt phase it.
did you have these balanced after they were stuffed?
Peter,
I have been running the prototype for 1200 miles. Super balanced.
Bobby Dopefiend /
do you guys know if a camino crank will bolt onto and NC50?
those look just like the camino DMP race crank, which are long out of production...i had been trying to track one down for a while on the dutch tuning sites with no luck, so i'm super excited to get one for my build..
who makes these?
What is this "green crank" people keep talking about? Don't jerk me around now
The cranks are custom made for us.
Dan
oh sweet! maybe i'll this rout over derbi crank!
so will they be in production for a while? i'll def. buy one in about a month.... the only thing you need to change is the seal then? will standard hobbit size bearing fit on this?
will 77 address this seal issue on its website listing?
sure thing pal
Sorry, I hit the wrong number even tho 25.4 is a real oil seal size.
There is NOT seal issue.
Any honda dealer will order the seals for you until 77 gets them instock.
The vario side seal is a standard honda made seal for/from honda mopeds.
hobbit, pa50I/II, nc, nx50m, 15x25.5x7 - 91201-147-003
Team 77, camino NT 17x25.5x7 - 91201-GB7-631 (Double Lip)
You need one of each size for your crank upgrade.
Some of you may have had this happen to you. The vario seal popping out. Make sure you have the seal free of oil on the outside of the new seal and case and use some thread retainer (green stuff). Use a q-tip to apply a small amount of oil to the inside of the seal this will kept the seal from burning up or smearing maybe even tear the sealing lips.
so is the vario side lip is seal lip is slightly larger? That could be advantage itself even if it's not a the stanrdard seal size. More diameter = more strength.
-naz
this crank makes the green crank look like a joke
Knock knock...whos there? hobbit. hobbit who? hobbit green crank
yup, rollers, polished rod, aluminum stuffed, heavier output shaft.. no more broken cranks
you see they have the ZA crank also
I suck at writing
-naz
Polini cup season will be fun to watch I bet with all the krazy fast hobbit, pa50ers .... now all them red 20mph pa's...
like 2 years ago I seen them everywhere on the forums for sale. Now not one.
Charles Cole (OFMC) /
On the way YAY!
So...don't mind my ignorance, but will this fit the aforementioned pa50I (you know, the doggish 20mph-er)?
why yes it will :)
Fits all the pa50 I and II cases.
so i assume the 6004 C3 bearings are good
Of course, its a copy of the pa50II just has a thicker vario side as freddie said no more broken/snapped cranks. It will be alot harder since these are machined and not casted from what I can tell.
ed i called honda here in louisville and they said that the 17
