Re: The Official Yamaha Chappy (LB50) Thread!!!
ken gilbert /
got the HPI CDI installed and running well. i was hoping to document with pics and took a few but they're scattered around at the moment. plus jack is calling me out!
first thing i did to the HPI was float the lighting coil. easy to desolder the existing strap to ground, pulled another conductor (stripped extension cable 14awg) through the sheath and soldered to coil.
rigged up a quick 7a bolt-mount full wave diode bridge that i scavenged a decade (or two) ago and fed that into a simple single stage cap input filter. cap was another part i had hanging around (50v 6800uF) and sufficed.
DC-DC bucker idea described in earlier posts did not work due to insufficient voltage at low rpms. after some testing i ended up taking the output of the cap filter and wiring it directly to where the oem coils used to go. one coil went as AC to the headlight circuit, the other went to the acc/batt circuits. i crimped on spade connecter terminals and did not disurb the oem molex plug.
i also replaced the battery in its original location with original electrical connections (including fuse).
so with a minimal amount of modification i am running my 6v chappy on an unregulated 12vdc. there is a good deal of sag at idle but due to the retention of the battery turn signals still work, horn still works (a bit softer). while spinning along headlight is very bright but reaches a max which looks exactly as bright as on the oem magneto. i suspect that the oem voltage regulator is a simple shunt type (zener to ground) and since my entire electrical system is in parallel this clamps output voltage to oem value.
the 60w accesssory coil on the HPI is not stiff. expecting multiple amps at 12vdc indefinitely at idle will not work. the original 6vdc loads, along with the battery, work well. to really see what's going on in the rail i really need an oscilloscope as there is a heavy ac component, but i can't argue with results. my old tek scope died years ago sadly.
switching to an LED headlight would make a profound difference, enough i believe to remove the oem "one wire" voltage reg, replace with a 12v unit, and switch to 12v accessories.. currently i have LED tail and rear turns which help a bit, but the headlight draws 35w which is 6a@6v (but the beam pattern is nice, and plenty bright while moving). i can't run the headlight on ac and everything else on dc unless i abandon chassis ground for one of them.
what most folks don't realize is that switching to cap input filter does two basic things:
1. with no load, the output voltage will rise to a max equal to the peak ac voltage. this is 1.4x the ac "rms" or heating/lighting voltage for a sinusoidal waveform. given a 12vac rms input, the no load voltage will be 16.8vdc.
2. there's no free lunch. peak current will also be multiplied by 1.4x. my 35w headlight draws 6a @ 6vac. that current load will be "felt" by the coil like 8.4a of ac load.
this is why so many oems like to run the headlight on AC--perfectly fine if you want to half wave rectify, since the AC coil stays grounded on one side and you just tap off for the DC load.
for the near future, i snagged some 10a schottky diodes off amazon and plan on replacing the bridge. switching to schottkys cuts your diode junction voltage drop in half. in a full wave bridge you've got two drops, so you'll get about 0.7v more voltage. the smaller drop means less power is lost as heat; at 7a current load 0.7v is just shy of 5 "free" watts.
ignition wise i did not seem to have any of the shorting issues that plagued jack. in fact i paid no attention whatsoever to just bolting the mounting plate on to the crankcase with oem flat head machine fasteners. i did watch carefully my lead dress and made sure i didn't pinch anything on the way back together. i slit the oem rubber double shoulder bushing and put it on the HPI sheath as that area is not only easy to pinch but also exposed to chain wash.
i set timing to 2mm btdc which ends up setting peak advance to 25*. i have not verified with a timing light. due to a high CR i hear just a hint of knock here and there so if anything i would retard it a bit.
i ran with the unit as ordered for about three days, then i ordered the 300g flywheel (btw treats absolutely honors their price match guarantee) and have to agree with popular consensus that it just is a way better configuration. what sealed the deal for me is the possible (probable?) improvement in longitudinal crankshaft rotational inertia balance, and by extension crank/bearing lifespan. idle is also more stable and any sluggishness in throttle response is barely perceptible. for all intents and purposes there is no downside performance-wise, however it does make adjusting timing without taking off the chappy side housing impossible (you can't get clearance to the bolts by taking off the flywheel cover plate, and it won't fit out the flywheel cover hole). (edited)
  The Official Yamaha Chappy (LB50) Thread!!!Topic by: Alfred G Alfred G 07/31/10 02:22PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Alfred G Alfred G 07/31/10 02:40PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Art B. Art B. 11/26/10 10:46AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ) Cupermcnewbster ( ) Cupermcnewbster ( 07/31/10 03:39PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: LanceCampeau.com LanceCampeau.com 07/31/10 05:42PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Tate in Madison Tate in Madison 07/31/10 05:52PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ) Cupermcnewbster ( ) Cupermcnewbster ( 08/01/10 06:57AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Alfred G Alfred G 09/03/10 02:52PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ) Cupermcnewbster ( ) Cupermcnewbster ( 09/03/10 08:06PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ryan m ryan m 09/03/10 10:55PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: smoke1 smoke1 09/04/10 02:14AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Kevin Kevin 03/24/11 08:49AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Kevin Kevin 03/24/11 08:56AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: smoke1 smoke1 09/04/10 02:36AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Rob @t ATTN! Burrito Rob @t ATTN! Burrito 09/05/10 04:53PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: smoke1 smoke1 10/15/10 01:27AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dedic761 Dedic761 09/07/10 12:15PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: smoke1 smoke1 10/23/10 02:17AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Rob @t ATTN! Burrito Rob @t ATTN! Burrito 09/08/10 10:26AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: crazyjay vandal crazyjay vandal 09/12/10 11:02PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Rob @t ATTN! Burrito Rob @t ATTN! Burrito 11/02/10 01:09PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Kevin Kevin 04/16/11 03:13PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: marquis cruz marquis cruz 01/11/14 11:07AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Shawn Shawn 10/16/10 02:02PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ffreddie ffreddie 10/16/10 02:39PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Rob @t ATTN! Burrito Rob @t ATTN! Burrito 10/23/10 12:12PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Brian Brian 11/01/10 10:31PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Rob @t ATTN! Burrito Rob @t ATTN! Burrito 11/02/10 02:47AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: brian brian 11/02/10 12:52PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Mordecai Mordecai 11/02/10 03:17PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: peibarry peibarry 01/22/11 09:30AM
  Chappy Recommended Transmission fluidRe: Art B. Art B. 11/28/10 01:54PM
  Re: Chappy Recommended Transmission fluidRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 11/29/10 03:12AM
  Re: Chappy Recommended Transmission fluidRe: Rob @t ATTN! Burrito Rob @t ATTN! Burrito 12/01/10 04:02PM
  Re: Chappy Recommended Transmission fluidRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 12/01/10 05:03PM
  Re: Chappy Recommended Transmission fluidRe: gabriel Balaa gabriel Balaa 12/02/10 03:40AM
  Re: Chappy Recommended Transmission fluidRe: gigoy gigoy 12/28/10 08:58PM
  Re: Chappy Recommended Transmission fluidRe: Dave Mcmenamy Dave Mcmenamy 10/01/19 09:26PM
  Re: Chappy Recommended Transmission fluidRe: Hunter Skiff Hunter Skiff 10/01/19 09:53PM
  Re: Chappy Recommended Transmission fluidRe: dusty dusty 12/29/10 01:22PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: SABAT! andDestroy SABAT! andDestroy 01/22/11 12:00PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: SABAT! andDestroy SABAT! andDestroy 01/22/11 12:02PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: mat mat 03/02/11 01:34AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ryan m ryan m 03/03/11 01:21AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Velocirobert Velocirobert 03/24/11 09:41PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ) Cupermcnewbster ( ) Cupermcnewbster ( 04/16/11 04:29PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Kevin Kevin 04/17/11 02:55AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ryan m ryan m 04/17/11 07:11AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Alfred G Alfred G 08/13/11 01:11AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Curtis Riendeau Curtis Riendeau 09/06/11 09:12PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jason Christensen Jason Christensen 01/08/12 10:30AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: vincent oudou vincent oudou 04/08/13 06:13AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Ted Sliwinski Ted Sliwinski 01/09/12 01:36PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Alfred G Alfred G 01/11/12 11:11PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Ryan Mayer Ryan Mayer 01/12/12 12:58AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Ryan Mayer Ryan Mayer 01/12/12 02:35PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Ted Sliwinski Ted Sliwinski 01/12/12 10:35AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Ted Sliwinski Ted Sliwinski 01/13/12 11:14AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: josh troski josh troski 04/24/12 05:27PM
  Re: The Official Yamaha Chappy (LB50) Thread!!! exhaust option!!!Re: Aj Monteiro Aj Monteiro 04/24/12 08:06PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: vincent oudou vincent oudou 04/08/13 06:22AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: josh troski josh troski 04/25/12 03:30AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: James Barlow James Barlow 05/31/12 01:31PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: george strausbaugh george strausbaugh 06/26/12 07:39PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: vincent oudou vincent oudou 04/06/13 02:28PM
  Re: The Official Yamaha Chappy (LB50) Thread!!! [Trade Parts?]Re: Jeroen Decker Jeroen Decker 08/26/13 07:19PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: josh troski josh troski 08/10/12 08:49PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: James Barlow James Barlow 11/20/13 04:46PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: James Barlow James Barlow 01/06/13 02:24PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: josh troski josh troski 09/28/13 02:10AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: vincent oudou vincent oudou 04/06/13 02:20PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Peter Fondue Peter Fondue 04/06/13 08:23PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Peter Fondue Peter Fondue 04/06/13 10:21PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jeroen Decker Jeroen Decker 06/17/13 06:11PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Vova Fett Vova Fett 04/06/13 10:21PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Robert Schmitt Robert Schmitt 06/23/13 05:47PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: matt Karpinski matt Karpinski 07/11/13 10:24PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Robert Schmitt Robert Schmitt 07/23/13 03:53PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jeroen Decker Jeroen Decker 06/30/13 12:52PM
  Difference Between Chappy LB80 Motor vs. LB50 MotorRe: Jeroen Decker Jeroen Decker 08/12/13 04:28PM
  Re: Difference Between Chappy LB80 Motor vs. LB50 MotorRe: Andrew Squiggman Andrew Squiggman 08/12/13 04:54PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: josh troski josh troski 09/28/13 02:23AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: josh troski josh troski 09/28/13 02:37AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Alison Brown Alison Brown 11/07/13 11:33AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Sam R Sam R 11/24/13 12:53AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: marquis cruz marquis cruz 01/11/14 12:05PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Paul Miller Paul Miller 01/11/14 11:37PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: marquis cruz marquis cruz 01/31/14 03:17AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: marquis cruz marquis cruz 02/08/14 01:19AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Paul Miller Paul Miller 02/08/14 08:03PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: marquis cruz marquis cruz 02/09/14 10:20AM
  Re: The Official Yamaha Chappy (LB50) Thread!!! Safer foot pegs?!!!Re: Robert Schmitt Robert Schmitt 02/17/14 01:17PM
  Re: The Official Yamaha Chappy (LB50) Thread!!! Safer foot pegs?!!!Re: Andrew Squiggman Andrew Squiggman 02/17/14 01:55PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Declan g Declan g 03/12/14 01:20PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jamie Todd Jamie Todd 05/25/14 10:37AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Andrew Squiggman Andrew Squiggman 05/25/14 11:08AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jamie Todd Jamie Todd 05/25/14 05:03PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jeroen Decker Jeroen Decker 05/26/14 08:59AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jamie Todd Jamie Todd 05/27/14 01:37PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Willie Baar Willie Baar 06/02/14 11:26PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Carlos Carlos Carlos Carlos 07/07/14 10:10PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ramyr kaabay ramyr kaabay 02/01/15 05:50AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Andrew Squiggman Andrew Squiggman 02/01/15 03:39PM
  Looking to do an engine swap. (LB50)Re: Robert Schmitt Robert Schmitt 04/02/15 01:08PM
  Re: Looking to do an engine swap. (LB50)Re: chris osbourne chris osbourne 05/16/15 08:38PM
  Re: Looking to do an engine swap. (LB50)Re: Robert Schmitt Robert Schmitt 07/20/15 10:16PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Matt Acosta Matt Acosta 09/15/16 02:37PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Logan Snowflake Logan Snowflake 01/21/19 11:08AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Logan Snowflake Logan Snowflake 01/21/19 11:41AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 01/21/19 11:52AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Logan Snowflake Logan Snowflake 01/21/19 11:54AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 01/21/19 01:18PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Logan Snowflake Logan Snowflake 01/21/19 01:47PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 01/21/19 05:15PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Logan Snowflake Logan Snowflake 01/21/19 05:59PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 01/21/19 10:56PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Robert Schmitt Robert Schmitt 01/23/19 11:29AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Logan Snowflake Logan Snowflake 01/23/19 11:33AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 01/22/19 10:24AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Logan Snowflake Logan Snowflake 01/22/19 10:30AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Logan Snowflake Logan Snowflake 01/24/19 06:15PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: shayne zroback shayne zroback 01/26/19 09:13AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 01/27/19 01:41PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: shayne zroback shayne zroback 01/27/19 03:03PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Logan Snowflake Logan Snowflake 01/27/19 03:23PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: shayne zroback shayne zroback 01/28/19 11:45AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Robert Schmitt Robert Schmitt 01/29/19 03:55PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 01/29/19 04:20PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Logan Snowflake Logan Snowflake 01/29/19 05:04PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 02/27/19 09:40PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 02/27/19 10:44PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 02/28/19 12:10AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 02/28/19 09:28AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 02/28/19 09:58AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Thomas Whittington Thomas Whittington 11/29/20 09:50PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Robert O Robert O 11/30/20 04:12PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Robert O Robert O 12/03/20 12:47AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 01/30/19 03:21PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 01/30/19 03:31PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 01/30/19 03:34PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 01/30/19 03:42PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 01/30/19 05:33PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/30/19 03:41PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 01/31/19 09:16AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 01/31/19 09:27AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 01/31/19 09:37AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 02/02/19 05:07PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 02/02/19 05:40PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 02/04/19 04:11PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 02/02/19 08:07PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 02/11/19 07:40PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 02/11/19 08:15PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 02/12/19 01:33PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 02/18/19 06:31PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: P D P D 02/18/19 08:58PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 02/18/19 09:32PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 02/18/19 09:35PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 02/18/19 10:27PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 02/18/19 10:57PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 02/18/19 11:08PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 02/23/19 07:02PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: P D P D 02/23/19 07:51PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 02/23/19 08:40PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 02/23/19 09:19PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 02/23/19 08:00PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 02/23/19 09:01PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 02/23/19 09:24PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: P D P D 02/24/19 10:31AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: P D P D 02/24/19 10:41AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 02/24/19 11:42AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: P D P D 02/24/19 01:18PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 02/24/19 05:48PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 02/24/19 08:33PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 02/24/19 12:21PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 02/24/19 05:38PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: kevin Smellaflange kevin Smellaflange 02/24/19 06:35PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 02/24/19 08:05PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 02/24/19 10:08PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 02/25/19 01:53PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 02/25/19 01:55PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 02/25/19 02:16PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 02/25/19 02:20PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: P D P D 02/25/19 03:05PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 02/25/19 03:14PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 02/26/19 09:43AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 02/26/19 02:29PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Nicole Hascoet Nicole Hascoet 02/28/19 08:13AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 02/28/19 09:56AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 03/01/19 11:18PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 03/09/19 01:18PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 03/09/19 04:42PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 03/23/19 09:25PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 03/23/19 09:49PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 03/24/19 08:51AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 04/01/19 04:41PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 04/01/19 04:57PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 04/01/19 04:59PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 04/01/19 06:56PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 04/01/19 07:20PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 04/02/19 05:59PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 04/02/19 06:13PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Michael Blank Michael Blank 04/04/19 03:26PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 04/04/19 04:07PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 04/04/19 06:27PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 04/04/19 08:43PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 04/04/19 08:51PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 04/04/19 10:51PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Michael Blank Michael Blank 04/05/19 12:11PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Michael Blank Michael Blank 04/04/19 03:41PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 04/04/19 04:05PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Michael Blank Michael Blank 04/05/19 12:03PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Turner Strawn Turner Strawn 06/11/20 01:52AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 06/11/20 10:03AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 04/04/19 04:17PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Michael Blank Michael Blank 04/05/19 12:06PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 05/01/19 04:19PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Michael Blank Michael Blank 05/01/19 07:11PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 05/01/19 07:22PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Michael Blank Michael Blank 05/01/19 07:27PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 05/02/19 09:14AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 05/02/19 09:39AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 05/02/19 08:44PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 04/05/19 10:49PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jacob Trumble Jacob Trumble 04/07/19 06:34PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 04/08/19 06:56AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 05/03/19 12:17PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 05/03/19 01:14PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 05/06/19 11:03AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 05/06/19 11:31AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 05/07/19 12:00PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 07/18/19 03:00PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 07/18/19 04:01PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 07/23/19 08:41AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 07/23/19 09:29AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 07/23/19 11:42AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 07/23/19 11:45AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 05/07/19 01:48PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 05/07/19 01:50PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 05/07/19 01:51PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 05/07/19 01:53PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 05/07/19 02:39PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 05/07/19 02:40PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 05/08/19 03:06PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 05/08/19 04:27PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 05/08/19 09:38PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: shayne zroback shayne zroback 05/10/19 06:50PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 05/11/19 05:36PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: shayne zroback shayne zroback 05/11/19 07:17PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 05/12/19 02:40PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: shayne zroback shayne zroback 05/12/19 08:21PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Robin D'Agostino Robin D'Agostino 05/13/19 01:18PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 05/13/19 03:12PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 05/13/19 09:09PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 05/14/19 09:13AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 05/14/19 09:54PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 05/15/19 11:02AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 05/16/19 08:57PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 05/16/19 10:16PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 05/17/19 12:12AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 05/17/19 08:22AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 05/19/19 01:25PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 05/20/19 09:28AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 05/20/19 05:58PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: P D P D 05/21/19 09:27AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 05/25/19 10:14AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 05/25/19 02:21PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 05/25/19 08:52PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 05/25/19 02:23PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 05/25/19 02:53PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 05/25/19 08:54PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 05/25/19 10:32PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 05/26/19 11:38AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 05/26/19 01:02PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 05/26/19 01:07PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 05/26/19 06:06PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Michael Blank Michael Blank 05/28/19 03:34PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 05/28/19 03:37PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 05/29/19 09:10AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Michael Blank Michael Blank 05/29/19 09:15AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 05/29/19 09:46AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 05/29/19 10:03AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 05/29/19 10:02PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 05/30/19 10:54AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 05/30/19 10:59AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 05/30/19 03:21PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 05/31/19 08:30AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 06/03/19 12:03PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 06/03/19 12:37PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 06/03/19 12:42PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 06/03/19 01:29PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Michael Blank Michael Blank 06/03/19 01:29PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 06/04/19 09:32AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 06/04/19 09:34PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 06/05/19 09:03AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 06/05/19 02:53PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 06/05/19 10:21PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 06/06/19 09:02AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 06/10/19 09:10PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 06/05/19 12:19AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 06/05/19 07:47AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Michael Blank Michael Blank 06/05/19 08:59AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 06/06/19 04:10PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 06/10/19 09:19PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 06/10/19 09:21PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 06/10/19 09:30PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 06/10/19 09:40PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 06/07/19 10:39AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 06/07/19 05:15PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 06/10/19 09:58PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 06/10/19 10:10PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 06/10/19 10:36PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 06/11/19 12:00AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 06/11/19 09:02AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 06/11/19 11:28AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 06/28/19 10:33AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 06/28/19 10:44AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 07/03/19 02:16AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 07/03/19 10:07AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 07/03/19 10:19AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 07/03/19 10:38AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 06/11/19 09:50AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 06/11/19 04:09PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 06/11/19 07:32PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 06/11/19 07:43PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 06/19/19 09:57AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: shayne zroback shayne zroback 06/19/19 01:40PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 06/20/19 12:58PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: P D P D 06/20/19 01:49PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 06/20/19 02:05PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 06/21/19 08:42AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: P D P D 06/21/19 09:48AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Michael Blank Michael Blank 06/22/19 07:24PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 06/24/19 11:05AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Michael Blank Michael Blank 06/24/19 11:18AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 06/24/19 11:39AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Michael Blank Michael Blank 06/24/19 11:51AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 06/24/19 12:13PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 06/24/19 03:11PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 06/24/19 03:20PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 06/24/19 04:03PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: P D P D 06/24/19 04:39PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 06/24/19 08:34PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 06/25/19 09:55AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 06/25/19 10:10AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 06/25/19 10:32AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 06/25/19 01:27PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 06/25/19 02:47PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 06/26/19 11:41AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 06/26/19 11:59AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 06/26/19 02:22PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 06/26/19 03:28PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 06/26/19 05:24PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 06/27/19 10:56AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 06/25/19 06:44AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 06/25/19 09:48AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 06/25/19 10:19AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 07/01/19 01:01PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 07/01/19 04:26PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 07/01/19 09:29PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 07/02/19 09:58AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 07/02/19 10:05AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: shayne zroback shayne zroback 07/02/19 10:47AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 07/03/19 08:21AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Michael Blank Michael Blank 07/03/19 08:33AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 07/03/19 10:39AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 07/03/19 10:52AM
  oem exhaust modificationsRe: ken gilbert ken gilbert 07/10/19 08:53AM
  Re: oem exhaust modificationsRe: Hunter Skiff Hunter Skiff 07/10/19 09:29AM
  Re: oem exhaust modificationsRe: Dirty30 Dillon Dirty30 Dillon 07/10/19 09:52AM
  Re: oem exhaust modificationsRe: ken gilbert ken gilbert 07/10/19 10:01AM
  Re: oem exhaust modificationsRe: ken gilbert ken gilbert 07/10/19 09:56AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 07/10/19 09:09AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 07/10/19 09:48AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 07/10/19 10:10AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 07/10/19 10:14AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 07/10/19 10:14AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 07/10/19 10:34AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 07/11/19 11:46AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 07/11/19 11:49AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 07/11/19 11:55AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 07/12/19 11:23AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 07/12/19 11:27AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 07/13/19 10:18AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 07/13/19 10:36AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 07/14/19 03:54PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 07/17/19 03:14PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 07/17/19 04:01PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 07/18/19 08:07AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 07/18/19 02:44PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 07/18/19 02:40PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 07/18/19 02:57PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 07/18/19 03:08PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 07/23/19 05:27PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 07/24/19 06:29AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 07/28/19 06:47PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 07/29/19 10:39AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 07/31/19 02:55PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 08/11/19 08:30AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 08/13/19 09:57PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 08/13/19 09:59PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 08/15/19 03:21PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 08/20/19 06:01PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 08/22/19 05:54PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 08/23/19 11:51AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 08/25/19 06:46PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 08/29/19 08:15AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 08/29/19 09:25AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 08/31/19 02:08PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 09/01/19 03:08PM
  Chappy & Chappy StuffRe: Logan Snowflake Logan Snowflake 09/22/19 11:45AM
  Re: Chappy & Chappy StuffRe: Jack Rutherford Jack Rutherford 09/29/19 05:44PM
  Re: Chappy & Chappy StuffRe: Hunter Skiff Hunter Skiff 09/29/19 06:04PM
  Re: Chappy & Chappy StuffRe: Jack Rutherford Jack Rutherford 09/29/19 06:05PM
  Re: Chappy & Chappy StuffRe: ken gilbert ken gilbert 09/30/19 02:31PM
  Re: Chappy & Chappy StuffRe: ken gilbert ken gilbert 09/30/19 02:43PM
  Re: Chappy & Chappy StuffRe: ken gilbert ken gilbert 09/30/19 02:54PM
  Re: Chappy & Chappy StuffRe: ken gilbert ken gilbert 09/30/19 03:17PM
  Re: Chappy & Chappy StuffRe: ken gilbert ken gilbert 09/30/19 03:28PM
  Re: Chappy & Chappy StuffRe: ken gilbert ken gilbert 09/30/19 03:39PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 10/07/19 03:51PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 10/08/19 06:46AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 10/08/19 07:35AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 10/08/19 07:44AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: P D P D 10/08/19 10:38AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 10/08/19 09:38AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 10/08/19 02:33PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 10/23/19 06:52PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 10/23/19 07:02PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 10/24/19 07:58AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 11/03/19 10:22PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Terbo Speghetti Terbo Speghetti 10/08/19 10:07AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Josiah Radebaugh Josiah Radebaugh 10/08/19 10:37AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 10/08/19 12:18PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 11/05/19 07:11AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 11/05/19 04:47PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 11/06/19 07:18AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 11/12/19 11:56AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 11/12/19 02:06PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 11/15/19 08:26PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 11/15/19 09:31PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 11/16/19 09:52AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 11/17/19 07:56AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 11/18/19 10:26AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 11/22/19 06:11AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 11/22/19 09:49AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 11/25/19 06:08AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 11/28/19 10:33AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 11/28/19 10:42AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: P D P D 11/28/19 11:16AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 12/06/19 08:08PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 01/20/20 10:39PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 01/21/20 09:26PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 01/22/20 06:08PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 01/22/20 11:30PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 01/29/20 07:45PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 02/03/20 12:16PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 02/03/20 01:16PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 02/03/20 01:20PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 02/04/20 05:56AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 02/04/20 12:26PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 02/04/20 01:14PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 02/04/20 02:35PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 02/04/20 04:19PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 02/10/20 11:08AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 02/10/20 06:57PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 02/03/20 12:18PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 02/03/20 12:42PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 02/03/20 02:22PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 02/25/20 08:55AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 02/26/20 02:23PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: P D P D 02/26/20 02:41PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 02/26/20 03:09PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: P D P D 02/26/20 04:10PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: P D P D 02/26/20 04:24PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Michael Blank Michael Blank 02/26/20 05:12PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: P D P D 02/26/20 05:22PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 02/26/20 06:44PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Michael Blank Michael Blank 02/26/20 07:04PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: P D P D 02/26/20 07:13PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 03/02/20 05:45PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: P D P D 03/02/20 07:02PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 03/02/20 08:20PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 03/03/20 09:20AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 03/05/20 09:54AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 03/05/20 10:35AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: P D P D 03/05/20 11:07AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 03/06/20 09:47AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Robert Gyra Robert Gyra 03/08/20 03:50PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 03/10/20 02:28PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 03/13/20 04:11PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 03/14/20 12:45PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 03/24/20 10:18AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Michael Blank Michael Blank 03/27/20 11:52PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 03/28/20 01:33PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Michael Blank Michael Blank 03/28/20 10:24PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 03/28/20 11:02PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Sean Curley Sean Curley 04/01/20 05:59PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Sean Curley Sean Curley 04/01/20 10:44PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 04/02/20 12:05AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Satan 666 Satan 666 04/02/20 09:08AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Sean Curley Sean Curley 04/02/20 09:47PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 04/03/20 12:00AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Sean Curley Sean Curley 04/03/20 05:09PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: P D P D 04/03/20 05:20PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Sean Curley Sean Curley 04/03/20 05:28PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Sean Curley Sean Curley 04/03/20 05:30PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: P D P D 04/03/20 05:42PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 04/03/20 07:15PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 04/03/20 10:42PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Sean Curley Sean Curley 04/04/20 10:27AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 04/04/20 01:00PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Sean Curley Sean Curley 04/04/20 02:31PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Sean Curley Sean Curley 04/04/20 05:08PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Michael Blank Michael Blank 04/08/20 04:42PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 04/08/20 06:17PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 04/08/20 06:20PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Michael Blank Michael Blank 04/16/20 05:34PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 04/08/20 09:45PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Michael Blank Michael Blank 04/09/20 10:03AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Culichor C Culichor C 05/07/20 08:12AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jeff Panian Jeff Panian 06/05/20 02:55PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 06/05/20 08:57PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 06/06/20 08:01AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: MPB Andyrew MPB Andyrew 06/10/20 11:51AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 06/10/20 01:02PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Culichor C Culichor C 06/10/20 01:05PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: MPB Andyrew MPB Andyrew 06/10/20 01:21PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 06/13/20 12:22AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: MPB Andyrew MPB Andyrew 06/10/20 01:25PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 06/10/20 01:59PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: MPB Andyrew MPB Andyrew 06/10/20 02:15PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 06/10/20 02:29PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 06/13/20 12:07PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 06/11/20 11:02PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 06/13/20 12:24PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 06/13/20 01:03PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 06/23/20 01:28PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 06/29/20 11:51AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: James Cline James Cline 06/15/20 11:54PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: P D P D 06/16/20 12:43PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: James Cline James Cline 06/16/20 08:22PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: James Cline James Cline 06/17/20 04:48PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: P D P D 06/17/20 10:27PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: MPB Andyrew MPB Andyrew 06/23/20 04:03PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 06/29/20 12:46PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Kyle Pattison Kyle Pattison 07/09/20 11:44PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: P D P D 07/10/20 08:20AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 07/10/20 08:43AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 07/11/20 02:10PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 07/14/20 08:59PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 07/14/20 09:22PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 07/15/20 09:40PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 07/15/20 11:38PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 07/16/20 01:15AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 07/16/20 02:41PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 07/14/20 08:56PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 07/16/20 11:13AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 07/16/20 11:57AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Eric Migliorino Eric Migliorino 07/16/20 01:38PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 07/16/20 01:50PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 07/16/20 03:14PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 07/18/20 05:00PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: James Cline James Cline 07/30/20 01:04AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 08/06/20 05:37PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 08/06/20 06:40PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 08/06/20 08:18PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 08/06/20 08:45PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: P D P D 08/06/20 09:15PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 08/06/20 10:21PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 08/06/20 10:35PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 08/19/20 02:38PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 08/19/20 07:16PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 08/20/20 01:20PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 08/20/20 03:32PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Dirty30 Dillon Dirty30 Dillon 08/20/20 04:14PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 09/21/20 09:03PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Robert O Robert O 11/26/20 12:16PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 11/26/20 11:46PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Robert O Robert O 11/27/20 12:46PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Michael Blank Michael Blank 11/27/20 01:46PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Robert O Robert O 11/27/20 04:32PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Michael Blank Michael Blank 11/27/20 04:33PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Robert O Robert O 11/27/20 04:37PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Robert O Robert O 11/27/20 04:51PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 11/27/20 07:33PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Robert O Robert O 11/28/20 11:41AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 12/04/20 07:10AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 12/04/20 07:31AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 12/04/20 09:41AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Robert O Robert O 12/04/20 12:21PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Robert O Robert O 12/04/20 06:14PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Robert O Robert O 12/05/20 05:32PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 12/05/20 08:48AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Billy Mild Billy Mild 12/07/20 01:07PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Robert O Robert O 12/10/20 03:33PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Robert O Robert O 12/10/20 03:36PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Robert O Robert O 12/13/20 07:03PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Robert O Robert O 12/14/20 01:51PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Robert O Robert O 12/14/20 03:21PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jon Cruz Jon Cruz 12/15/20 09:21AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jon Cruz Jon Cruz 12/15/20 09:22AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Robert O Robert O 12/16/20 11:02AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jon Cruz Jon Cruz 12/16/20 09:29PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Robert O Robert O 12/17/20 08:23PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Robert O Robert O 12/17/20 11:51PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jon Cruz Jon Cruz 12/20/20 06:30PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Robert O Robert O 12/24/20 02:37AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jon Cruz Jon Cruz 12/14/20 11:54AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Robert O Robert O 12/18/20 12:25AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Robert O Robert O 12/18/20 02:58AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 03/31/21 06:54PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 03/31/21 08:45PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Rob LaFreniere Rob LaFreniere 04/04/21 11:36PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Jack Rutherford Jack Rutherford 04/06/21 08:13AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: ken gilbert ken gilbert 05/22/21 07:43PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 05/22/21 08:41PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Robert O Robert O 05/22/21 11:20PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Robert O Robert O 05/22/21 11:23PM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: Hunter Skiff Hunter Skiff 05/23/21 08:06AM
  Re: The Official Yamaha Chappy (LB50) Thread!!!Re: J o h n J o h n 05/26/21 12:29AM
