Derbi flatreed engine un/restricted
Here is what I found when I open up a 1984 flatreed engine(restricted install).
Look at the picture and you can see that the euro flatreed engine intake/reedcage area opening is unrestricted.
Thought I would share this since so many derbis are being found. I plan to open the 84 cases.
(anyone else tig welding the primary gear and output shaft and installing a soft plug into the disengagement hole.
I will show my broken parts a bit later)
Re: Derbi flatreed engine un/restricted
Man what were they thinkin...Casting a whole different motor when all they needed to do was add a restrictor plate in so people could easily take it out later if they wanted more power. Something tells me the EPA had something to do with this
Never seen that before. All the euro flat reeeds I've got had intakes that have had tamper proof bolts but that never stopped a drill and backout bit
This is a Start 5 i just got from overseas
why would they do that shit...you're reeds break...well I guess you're fucked...who engineered that shit?
I was trying to remove those damn things and snapped one off and broke a back out off in the other
I've seen one or 2 flat reeds like that. Pretty silly.
Wow that intake is huge.
Tate in Madison /
Yeah, I have seen those but not on a Derbi.
Solution I used was to use a dremel to cut a nice clean notch all the way across the bolt then use an impact screw driver and hammer them out.
Why didn't they just keep the old Derbi way of restricting? Where they put a little plastic top hat down the intakes throat and put a washer up in the variator?
Damn the man. Or in this case, damn the Se
ed what model did the restricted motor come off?
my 84/85 flat reed SLE is completely open into the crankcase like the picture on the right
84 sl model
derbeez ryderz /
my 86 sle is like the one to the left.
unless you have the 4 pedal and huge carb i doubt you would see gains from the huge open one. it might help case compression having that closed in area too, like the one on the left.
agreed
It uses a crankshaft that has a line cut into the wheels, so that the mix can get where it needs. I will post a picture of the wheels I had disassemble. (totally trashed)
Most primary gears I seen are without holes in the gear. This engines has 3 huge holes in the primary (lighter then the newer style flatreed)
I have seen this happen on .. 5 derbi engines now.
I plan to fix it by removing it and having the output shaft and primary gear tig welded/fused together, I hope I don't have push it any long distances ever.
gnarly!
I could wiggle the plate. So I remove it and the rivets.
Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang /
my 86 has the one on the left side... restricted i guess? damn i have the lomat all ready to go was just going to wait for better reeds before i put it all together guess i'll rethink that plan....
Here is the output shaft and primary gear fused/tig together.
Rebalance and refit/cut the bearing tolerances, installing ina bearings. I will show picture of the other parts that the weight is remove. No more weight mass spinning inside. Should help some.
next is the .. also the the sprocket front and back views.
Should much heat .. shrink the opening .0003's.
Ok, since the transmission was all broke up.
I plug the hole in the case where the disengagement lever/switch came through the cases.
So once I had the primary weld to the output shaft. I shrink the holes on the teeth/pedal side. So once it was honed with into tolances I press the new ina bearings into the output/primary gear. I deicded to remove all the spinning mass that was inside the derbi engine.
Very cool! That ought to help it spin up a bit faster!
dude. word
Thanks guys,
I have 3 more engines that I will need to do this do. Sad poor design.
Hook me up with an engine Ed...I've got this BRN morini kit...
Not many. even know that the morini kit works on the derbi and there .. much room to mod and make flowie.
Find a morini decomp head with you wanna sport this cylinder or .. pickup the moring racing head on 77
On the down stroke.
looks like there's room for modification ;)
I can make a decomp head...but I'd probably combo with something already in the market...but it would be nice to pair it with the cylinder so they dont look all stupid. The metra50 turned out nicely on the pp motor
I kinda wish I had the money for that choke derbi variant sport r that jeff was selling a while back. I love those red and white R versions. I gotta try and talk fred into selling me one with rad 3 star's on it.
Never had to the chance to work on a pp engine yet. Red ones are nice for sure.
