Re: Derbi flatreed engine un/restricted
Mo Peds /
here is the ds50 video of it running.
dellorto 16.16, #78 jet, #2 metal slide
big k/n air air filter
mk 16mm intake
autisa reed valve cage (1 big fiberglass petal)
44mm airsal (ported) (modified piston) (decompression hole was plugged)
1990 world champion crankshaft rebuilt by vince @mrcrankshaft
new ina needle bearing installed on the big end of the connecting rod
new AO made in italy connecting rod (aka made for gila company)
plugged and disengagement kit installed
buh8 spark plug
honda crankshaft seals 17x30x6mm wide!
new skf bearings installed in the gearbox
new ibc ceramic crankshaft bearings * thank you benji treat! *
hpi mini rotor timed @ .079's btdc
gsx gold reinforce racing chain
new sfk bearing inside the clutch bell
new sfk sealed wheel bearings
white clutch springs
balanced the clutch shoes weight
yellow contra spring
36 grams of roller weight
21-34 gearing
machined pedal shaft, disengagement paw, clutch bell, vario, clutch, contra pulley
modified derbi hi boy pipe *thank you freddie swoop!*
modified minarelli v1 hi compression angle plug head machined by mars with a oring * thanks mars! *
custom pull starter
pirelli sl26 tires * thanks will@ treats! *
trail tech temp gauge says 369@ wot
i need to modify the kickstand and get the rear fender mounted back on it. i put about 125 miles on it in 3 days. rides and runs so smoothly. just as i hoped! i may of forgot something. it seems like it took forever to get it back into drive able shape.
(edited)
  Derbi flatreed engine un/restrictedTopic by: Mo Peds Mo Peds 04/01/11 11:20AM
  Re: Derbi flatreed engine un/restrictedRe: Organ Robbin' Organ Robbin' 04/01/11 01:15PM
  Re: Derbi flatreed engine un/restrictedRe: Dan O Dan O 04/01/11 02:28PM
  Re: Derbi flatreed engine un/restrictedRe: Organ Robbin' Organ Robbin' 04/01/11 03:46PM
  Re: Derbi flatreed engine un/restrictedRe: Dan O Dan O 04/01/11 04:45PM
  Re: Derbi flatreed engine un/restrictedRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 04/01/11 06:35PM
  Re: Derbi flatreed engine un/restrictedRe: Jesse -B Jesse -B 04/01/11 09:03PM
  Re: Derbi flatreed engine un/restrictedRe: Tate in Madison Tate in Madison 04/01/11 09:47PM
  Re: Derbi flatreed engine un/restrictedRe: Andy Haldeman Andy Haldeman 04/02/11 05:30PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 04/02/11 05:37PM
  Re: Derbi flatreed engine un/restrictedRe: derbeez ryderz derbeez ryderz 04/02/11 06:23PM
  Re: Derbi flatreed engine un/restrictedRe: Andy Haldeman Andy Haldeman 04/02/11 06:59PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 04/03/11 11:16AM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 04/03/11 11:18AM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 04/04/11 10:38AM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 04/04/11 10:40AM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 04/04/11 10:42AM
  Re: Derbi flatreed engine un/restrictedRe: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang 04/04/11 11:24AM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 04/12/11 09:57PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 04/21/11 01:07AM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 04/21/11 01:13AM
  Re: Derbi flatreed engine un/restrictedRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 04/21/11 01:27AM
  Re: Derbi flatreed engine un/restrictedRe: Andy Haldeman Andy Haldeman 04/21/11 02:14AM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 04/21/11 09:53AM
  Re: Derbi flatreed engine un/restrictedRe: Organ Robbin' Organ Robbin' 04/21/11 11:23AM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 04/21/11 11:30AM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 04/21/11 11:32AM
  Re: Derbi flatreed engine un/restrictedRe: Organ Robbin' Organ Robbin' 04/21/11 11:48AM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 04/21/11 11:52AM
  Re: Derbi flatreed engine un/restrictedRe: Organ Robbin' Organ Robbin' 04/21/11 02:27PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 03/04/12 12:45AM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 03/04/12 12:59AM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 03/04/12 01:04AM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 03/04/12 01:07AM
  Re: Derbi flatreed engine un/restrictedRe: derbeez ryderz derbeez ryderz 03/04/12 10:34AM
  Re: Derbi flatreed engine un/restrictedRe: Andy Haldeman Andy Haldeman 03/04/12 07:17PM
  Re: Derbi flatreed engine un/restrictedRe: Spencer Jacobson Spencer Jacobson 03/04/12 07:45PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 03/04/12 09:49PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 08/25/12 08:15PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 08/25/12 08:23PM
  Re: Derbi flatreed engine un/restrictedRe: Ryan N. Ryan N. 08/25/12 08:46PM
  Re: Derbi flatreed engine un/restrictedRe: Ryan N. Ryan N. 08/26/12 01:17AM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 09/24/12 11:31PM
  Re: Derbi flatreed engine un/restrictedRe: Ryan N. Ryan N. 09/24/12 11:53PM
  Re: Derbi flatreed engine un/restrictedRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 09/25/12 01:55AM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 09/25/12 09:52PM
  Re: Derbi flatreed engine un/restrictedRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 09/25/12 10:05PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 09/28/12 12:34PM
  Re: Derbi flatreed engine un/restrictedRe: derbeez ryderz derbeez ryderz 09/28/12 02:41PM
  Re: Derbi flatreed engine un/restrictedRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 09/28/12 09:13PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 09/28/12 10:53PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 10/23/12 01:40PM
  Re: Derbi flatreed engine un/restrictedRe: not a Baron Asshole not a Baron Asshole 10/23/12 02:44PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 10/23/12 02:51PM
  Re: Derbi flatreed engine un/restrictedRe: Matt Perry Matt Perry 10/23/12 06:50PM
  Re: Derbi flatreed engine un/restrictedRe: mit mortso mit mortso 10/23/12 07:12PM
  Re: Derbi flatreed engine un/restrictedRe: mit mortso mit mortso 10/26/12 02:17AM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 10/26/12 10:07AM
  Re: Derbi flatreed engine un/restrictedRe: Matt Perry Matt Perry 10/31/12 09:02PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 11/11/12 10:09PM
  Re: Derbi flatreed engine un/restrictedRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 11/12/12 12:46AM
  Re: Derbi flatreed engine un/restrictedRe: SABAT! andDestroy SABAT! andDestroy 01/30/13 09:29AM
  Re: Derbi flatreed engine un/restrictedRe: LSLB RXb LSLB RXb 01/30/13 09:37AM
  Re: Derbi flatreed engine un/restrictedRe: SABAT! andDestroy SABAT! andDestroy 01/30/13 07:00PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 01/31/13 09:23AM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 03/10/13 12:16AM
  Re: Derbi flatreed engine un/restrictedRe: Quinn Welch L2S Quinn Welch L2S 03/10/13 01:15AM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 03/10/13 10:27AM
  Re: Derbi flatreed engine un/restrictedRe: LSLB RXb LSLB RXb 03/10/13 11:45AM
  Re: Derbi flatreed engine un/restrictedRe: derbeez ryderz derbeez ryderz 03/10/13 08:24PM
  Re: Derbi flatreed engine un/restrictedRe: ◕ ‿ ◕ ◕ ‿ ◕ 03/10/13 08:49PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 03/10/13 11:14PM
  Re: Derbi flatreed engine un/restrictedRe: Ryan N. Ryan N. 03/11/13 02:40AM
  Re: Derbi flatreed engine un/restrictedRe: Max (ツ) Max (ツ) 03/11/13 12:27PM
  Re: Derbi flatreed engine un/restrictedRe: Button Rojo Button Rojo 03/12/14 04:24PM
  Re: Derbi flatreed engine un/restrictedRe: Overpriced Parts Overpriced Parts 03/13/14 07:05PM
  Re: Derbi flatreed engine un/restrictedRe: Kyle M. Kyle M. 03/14/14 02:11AM
  Re: Derbi flatreed engine un/restrictedRe: Overpriced Parts Overpriced Parts 03/14/14 10:58AM
  Re: Derbi flatreed engine un/restrictedRe: Kyle M. Kyle M. 03/14/14 11:43AM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 03/11/13 12:31PM
  Re: Derbi flatreed engine un/restrictedRe: Max (ツ) Max (ツ) 03/11/13 12:43PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 05/21/13 11:15PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 05/21/13 11:34PM
  Re: Derbi flatreed engine un/restrictedRe: Caleb macguyver-keller Caleb macguyver-keller 03/11/14 06:23AM
  Re: Derbi flatreed engine un/restrictedRe: Andrew Squiggman Andrew Squiggman 03/21/14 12:07AM
  Re: Derbi flatreed engine un/restrictedRe: Kyle M. Kyle M. 03/12/14 02:46PM
  Re: Derbi flatreed engine un/restrictedRe: Button Rojo Button Rojo 03/14/14 09:21AM
  Re: Derbi flatreed engine un/restrictedRe: Kyle M. Kyle M. 03/14/14 11:52AM
  Re: Derbi flatreed engine un/restrictedRe: Overpriced Parts Overpriced Parts 03/14/14 12:34PM
  Re: Derbi flatreed engine un/restrictedRe: Kyle M. Kyle M. 03/14/14 03:12PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 03/14/14 01:31PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 03/17/14 01:46PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 03/17/14 01:57PM
  Re: Derbi flatreed engine un/restrictedRe: Chris Toth Chris Toth 03/17/14 04:17PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 03/17/14 04:19PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 03/19/14 10:24PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 03/20/14 10:05PM
  Re: Derbi flatreed engine un/restrictedRe: Richard Schwartz Richard Schwartz 03/20/14 10:38PM
  Re: Derbi flatreed engine un/restrictedRe: ◕ ‿ ◕ ◕ ‿ ◕ 03/20/14 11:31PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 03/28/14 11:13PM
  Re: Derbi flatreed engine un/restrictedRe: Shannon Hall Shannon Hall 03/29/14 01:14AM
  Re: Derbi flatreed engine un/restrictedRe: Dan O Dan O 03/29/14 12:21PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 03/29/14 05:09PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 03/29/14 05:14PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 03/30/14 09:56AM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 03/30/14 02:32PM
  Re: Derbi flatreed engine un/restrictedRe: LSLB RXb LSLB RXb 03/30/14 04:33PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 03/30/14 05:29PM
  Re: Derbi flatreed engine un/restrictedRe: GET REALIZED! BE HERE NOW! GET REALIZED! BE HERE NOW! 03/30/14 05:48PM
  Re: Derbi flatreed engine un/restrictedRe: Richard Schwartz Richard Schwartz 03/30/14 07:18PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 04/04/14 06:27PM
  Re: Derbi flatreed engine un/restrictedRe: ◕ ‿ ◕ ◕ ‿ ◕ 04/04/14 06:34PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 04/04/14 06:42PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 04/18/14 11:46AM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 04/19/14 12:33AM
  Re: Derbi flatreed engine un/restrictedRe: Dan O Dan O 04/19/14 06:10AM
  Re: Derbi flatreed engine un/restrictedRe: ◕ ‿ ◕ ◕ ‿ ◕ 04/19/14 10:56AM
  Re: Derbi flatreed engine un/restrictedRe: Richard Schwartz Richard Schwartz 04/19/14 11:18AM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 04/19/14 01:11PM
  Re: Derbi flatreed engine un/restrictedRe: Dan O Dan O 04/19/14 01:22PM
  Re: Derbi flatreed engine un/restrictedRe: Richard Schwartz Richard Schwartz 04/19/14 02:24PM
  Re: Derbi flatreed engine un/restrictedRe: Richard Schwartz Richard Schwartz 04/19/14 02:38PM
  Re: Derbi flatreed engine un/restrictedRe: LSLB RXb LSLB RXb 04/19/14 05:49PM
  Re: Derbi flatreed engine un/restrictedRe: Dan O Dan O 04/19/14 07:06PM
  Re: Derbi flatreed engine un/restrictedRe: Richard Schwartz Richard Schwartz 04/19/14 07:32PM
  Re: Derbi flatreed engine un/restrictedRe: Ryan N. Ryan N. 04/19/14 09:23PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 04/19/14 11:44PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 05/08/14 11:19AM
  Re: Derbi flatreed engine un/restrictedRe: Dave & Bummerzz Dave & Bummerzz 06/12/15 08:46PM
  Re: Derbi flatreed engine un/restrictedRe: Marvin Chan Marvin Chan 06/12/15 11:12PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 02/27/16 10:58AM
  Re: Derbi flatreed engine un/restrictedRe: Ryan N. Ryan N. 02/27/16 08:21PM
  Re: Derbi flatreed engine un/restrictedRe: Charlie BUZZARD Charlie BUZZARD 09/11/17 03:00PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 07/14/18 01:07PM
  Re: Derbi flatreed engine un/restrictedRe: Wild Card Wild Card 11/10/18 09:16PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 11/11/18 01:05PM
  Re: Derbi flatreed engine un/restrictedRe: Crazy Wayne Crazy Wayne 11/11/18 02:13PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 11/11/18 02:28PM
  Re: Derbi flatreed engine un/restrictedRe: Wild Card Wild Card 11/11/18 02:38PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 11/11/18 04:05PM
  Re: Derbi flatreed engine un/restrictedRe: Crazy Wayne Crazy Wayne 11/11/18 04:37PM
  Re: Derbi flatreed engine un/restrictedRe: Wild Card Wild Card 11/11/18 04:12PM
  Re: Derbi flatreed engine un/restrictedRe: Mo Peds Mo Peds 11/11/18 04:47PM
  Re: Derbi flatreed engine un/restrictedRe: jonny 5ive jonny 5ive 12/19/18 06:38PM
  Re: Derbi flatreed engine un/restrictedRe: 𝐿𝑖𝑘𝑎-𝐿𝑜𝑡𝑎𝑠𝑎𝑢𝑟 𝑀𝑒𝑔𝑎𝑝𝑢𝑠 🦖 𝐿𝑖𝑘𝑎-𝐿𝑜𝑡𝑎𝑠𝑎𝑢𝑟 𝑀𝑒𝑔𝑎𝑝𝑢𝑠 🦖 12/20/18 01:50PM
  Re: Derbi flatreed engine un/restrictedRe: Dead Possum Dead Possum 12/15/19 08:46PM
  Re: Derbi flatreed engine un/restrictedRe: ck 🌧🌧🌧 ck 🌧🌧🌧 12/18/19 02:48PM
  Re: Derbi flatreed engine un/restrictedRe: Blake MD No PM Plz Blake MD No PM Plz 12/19/19 12:32AM
