Re: Derbi flatreed engine un/restricted
Nice work Richard post inside pics
under cover(edited)
we just followed the line of the sidecover + cut out the circle!
I still have to notch out the cover for the 3 tabs so it sits flush to the engine side but am very happy w how it came out.
Adam Russell's work at its finest.
What did you use for the inner cover you mounted the pull start to
18gauge steel
its not as precise as it could be but it is much better than using a hobbit flywheel cover(edited)
well that sure is an innovative way to make a bench grinder
nice work!^
here is something i made this evening. hope to vent the gear box a bit more to release more heat / pressure build in the gear box.
(edited)
here is the ds50 video of it running.
dellorto 16.16, #78 jet, #2 metal slide
big k/n air air filter
mk 16mm intake
autisa reed valve cage (1 big fiberglass petal)
44mm airsal (ported) (modified piston) (decompression hole was plugged)
1990 world champion crankshaft rebuilt by vince @mrcrankshaft
new ina needle bearing installed on the big end of the connecting rod
new AO made in italy connecting rod (aka made for gila company)
plugged and disengagement kit installed
buh8 spark plug
honda crankshaft seals 17x30x6mm wide!
new skf bearings installed in the gearbox
new ibc ceramic crankshaft bearings * thank you benji treat! *
hpi mini rotor timed @ .079's btdc
gsx gold reinforce racing chain
new sfk bearing inside the clutch bell
new sfk sealed wheel bearings
white clutch springs
balanced the clutch shoes weight
yellow contra spring
36 grams of roller weight
21-34 gearing
machined pedal shaft, disengagement paw, clutch bell, vario, clutch, contra pulley
modified derbi hi boy pipe *thank you freddie swoop!*
modified minarelli v1 hi compression angle plug head machined by mars with a oring * thanks mars! *
custom pull starter
pirelli sl26 tires * thanks will@ treats! *
trail tech temp gauge says 369@ wot
i need to modify the kickstand and get the rear fender mounted back on it. i put about 125 miles on it in 3 days. rides and runs so smoothly. just as i hoped! i may of forgot something. it seems like it took forever to get it back into drive able shape.
(edited)
bump. and thanks for all the info.
oh man. i love looking at old Ed threads.
Thanks^
As a final add to this thread, I wanted to add this info to this thread as some may be wondering why there sprockets are dished or non dished/flat.
Here is to two different shims for the sprockets that come on the derbi flatreeds oldstyle. This shim is behind the sprocket.
Here is a thread in the b/s about derbi sprockets. Check your shim/sprockets.
https://mopedarmy.com/forums/read.php?2,3951413,3953120#msg-3953120
The thin shim came on mopeds with a dished rear sprocket. .550-.552ish
The thick shim came on mopeds with a flat rear sprocket. .748-.750ish
Happy Derbi!
(edited)
you know ed's old school because his caliper isn't digital
Love this thread.
Been away for awhile but I love derbis.
A lot of info in this thread. Some one should wiki this thread.
Ed
Bump
Once I get back in a shop I plan to build another awesome derbi. Thanks for the bump. There is ton of amazing info this thread that someone should really use to start a wiki page.
It's good to see Ed posting again.
He's definitely one of the top 10 Builders with true knowledge on this form.
Back in the day, I was the best until people get jealous of me. If it can be modded I did it. I learn a lot from the Argentina people. Thanks a lot Sean.(edited)
I will be contacting you sooooon
Ok, just send me a pm. Thanks.
Quick did someone figure out a one-way needle bearing to install into the clutch bell that would let you push start it. Then you wouldn't have to run the starter clutch pads or the costly pull starter from spain?
The one way needle bearing works pretty good but you need the one that has the needle rollers on the side if you want it to last any amount of time the only problem with that setup is if your engine seizes the rear wheel locks up which can cause a lot of Havoc if you're on the road on a corner and there's oncoming traffic it might not be the greatest thing in life to have happen.
See this all should be in wiki.
^Thanks^ for the link.
Sean, go to know^ Thanks
Master D. Baiter /
Watch this..chiNACHInachINA which bearings are better?
