Re: Treats piston port VS MK reed kit, A Review
LSLB RXb /
This is the piston that solves the problem. Single ring, just needs a boost window cut. Ring gap is straight, still leaves you with 2.7mm of meat up top. Still need to countersink, but no need to do anything else.
Pics:
1977 w/ treats v2 piston bdc intake side, 1977 w/ treats v2 bdc ex side, 1977 w/ treats at tdc
  Treats piston port VS MK reed kit, A ReviewTopic by: Jake P Jake P 06/03/12 07:04PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Overpriced Parts Overpriced Parts 06/03/12 08:22PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/03/12 08:24PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 06/03/12 08:26PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/03/12 08:31PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Overpriced Parts Overpriced Parts 06/03/12 08:44PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/03/12 11:09PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Graham Motzing Graham Motzing 06/04/12 03:12PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/04/12 04:45PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Graham Motzing Graham Motzing 06/04/12 05:35PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/04/12 05:40PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Graham Motzing Graham Motzing 06/04/12 05:53PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/04/12 06:03PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Michael Thomas Michael Thomas 06/04/12 07:21PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/04/12 07:39PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/04/12 07:51PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/05/12 01:53AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: SABAT! andDestroy SABAT! andDestroy 06/04/12 04:35PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/04/12 08:24PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/04/12 08:39PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Graham Motzing Graham Motzing 06/04/12 09:37PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/04/12 10:55PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/04/12 09:54PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/04/12 11:11PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/04/12 11:13PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/04/12 11:29PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/04/12 11:31PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/04/12 11:37PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/05/12 12:11AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/05/12 12:21AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Charlie BUZZARD Charlie BUZZARD 06/05/12 09:00AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/05/12 01:10PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/05/12 10:33AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Graham Motzing Graham Motzing 06/05/12 12:13PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/05/12 02:10PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: ! West Seattle ! ! West Seattle ! 06/05/12 03:16PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/05/12 03:23PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: ! West Seattle ! ! West Seattle ! 06/05/12 03:36PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/05/12 05:03PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/05/12 05:35PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/05/12 07:02PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Graham Motzing Graham Motzing 06/06/12 10:52AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/12/12 12:51PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/12/12 06:08PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Overpriced Parts Overpriced Parts 06/12/12 09:56PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/12/12 11:53PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/13/12 12:04AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Graham Motzing Graham Motzing 06/13/12 12:49AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/13/12 12:50AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Graham Motzing Graham Motzing 06/13/12 11:20AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/13/12 01:45PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: ! West Seattle ! ! West Seattle ! 06/13/12 04:43PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/13/12 08:39PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/14/12 09:48AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/14/12 10:45AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: mit mortso mit mortso 06/14/12 02:21PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang 06/15/12 11:52AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/15/12 11:59AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: derbeez ryderz derbeez ryderz 06/15/12 02:55PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Drew Bell Drew Bell 06/16/12 12:59AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Charles Cole (OFMC) Charles Cole (OFMC) 06/16/12 01:14AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Rich (OFMC) Rich (OFMC) 06/16/12 02:21AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Drew Bell Drew Bell 06/16/12 09:13AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Rich (OFMC) Rich (OFMC) 06/16/12 09:54AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Graham Motzing Graham Motzing 06/16/12 11:54AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/16/12 04:48PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/18/12 09:21AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/18/12 09:56PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Drew Bell Drew Bell 06/19/12 11:42AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/24/12 01:26AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/24/12 09:08AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Cole Doubt Cole Doubt 06/24/12 12:10PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/24/12 04:14PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang 06/24/12 02:30PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang 06/24/12 05:05PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Eric P Eric P 06/24/12 11:12PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/24/12 11:27PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/25/12 09:17PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Blake MD No PM Plz Blake MD No PM Plz 06/27/12 08:22AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: timothy rendall timothy rendall 06/30/12 06:01PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/25/12 09:27PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/25/12 10:15PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/25/12 10:32PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/25/12 09:18PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/27/12 12:06AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/27/12 12:33AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/27/12 12:51AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/27/12 01:03AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/27/12 08:18PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/27/12 08:24PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/27/12 08:28PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Bill Murrow Bill Murrow 06/27/12 09:12PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Bill Murrow Bill Murrow 06/27/12 09:14PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/27/12 11:01PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Graham Motzing Graham Motzing 06/28/12 11:01AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/28/12 11:07AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/29/12 05:33PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Kaj Niegmann Kaj Niegmann 06/29/12 06:41PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/29/12 06:55PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Kaj Niegmann Kaj Niegmann 06/30/12 11:32AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jesse Brosnan Jesse Brosnan 06/30/12 12:00PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 07/03/12 12:09AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Daniel '' Daniel '' 07/04/12 01:26PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 07/04/12 06:51PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jesse Brosnan Jesse Brosnan 07/04/12 10:43PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 07/08/12 02:44AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Kaj Niegmann Kaj Niegmann 07/09/12 11:15PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 07/10/12 03:14AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Kaj Niegmann Kaj Niegmann 07/13/12 08:56PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 07/14/12 11:54PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: will warn will warn 07/15/12 12:19AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: timothy rendall timothy rendall 07/15/12 06:01AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Kaj Niegmann Kaj Niegmann 07/16/12 10:57PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 07/17/12 12:31AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Kaj Niegmann Kaj Niegmann 07/18/12 12:11AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Kaj Niegmann Kaj Niegmann 07/18/12 12:13AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 07/18/12 02:06AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 07/18/12 05:36PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Kaj Niegmann Kaj Niegmann 07/19/12 04:06AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 07/19/12 07:33PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Kaj Niegmann Kaj Niegmann 07/20/12 11:12PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 09/01/12 11:20PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Daniel '' Daniel '' 09/02/12 01:13PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 09/02/12 02:44PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 09/03/12 04:18AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 09/16/12 07:14PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Bill Murrow Bill Murrow 09/16/12 07:51PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 09/16/12 07:54PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Bill Murrow Bill Murrow 09/16/12 07:58PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 09/16/12 11:42PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 09/17/12 11:34PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 09/17/12 11:44PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 09/18/12 12:30AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Kaj Niegmann Kaj Niegmann 10/14/12 11:49PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 12/19/12 02:52PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Max (ツ) Max (ツ) 12/19/12 03:11PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Salsa Salsa Salsa Salsa 12/19/12 03:19PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 12/19/12 03:57PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 12/19/12 04:51PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 12/19/12 10:20PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 12/19/12 11:15PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: campeona del mundo campeona del mundo 12/19/12 11:46PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 12/20/12 12:28AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 01/25/13 09:30PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: CtpEDsHED . CtpEDsHED . 01/25/13 09:47PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 01/25/13 09:58PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Trevor Yee Trevor Yee 01/26/13 01:15PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 01/26/13 02:24PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 01/26/13 02:29PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 12/11/13 06:28PM
  !Re: Daniel '' Daniel '' 12/11/13 07:55PM
  Re: !Re: Jake P Jake P 12/11/13 07:57PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Charles Cole (OFMC) Charles Cole (OFMC) 12/07/16 05:57PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 12/07/16 06:09PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Mike Boyd Mike Boyd 12/07/16 07:00PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 01/03/19 05:42PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: will warn will warn 12/07/16 07:08PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Mike Boyd Mike Boyd 12/07/16 07:13PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Charles Cole (OFMC) Charles Cole (OFMC) 01/08/19 06:54PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Chöschi21 C.K. Chöschi21 C.K. 02/07/19 05:36PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: D L D L 06/14/19 03:05PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/14/19 03:52PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Graham Motzing Graham Motzing 06/17/19 11:15AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: D L D L 06/15/19 05:22PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Amelie Corbeil Amelie Corbeil 06/17/19 11:17AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: D L D L 04/06/20 04:24PM
