Re: Treats piston port VS MK reed kit, A Review
Drew Bell /
i raised the exhaust 3mm
also widened 1mm on each side..(i would go wider now)
i took a 25 cent piece and used it as a templet for for the cut out on the piston
mark the piston at TDC
so you know when the piston is at the top of the intake stroke. mark at the top of the intake on the piston.. thats the peak of the arch you want to cut
trying to achieve 360 degree intake duration
it went really fast.. over 65mph
korado cdi
20mm carb
homoet 8p
ktm clutch.
but mostly ran a 3 shoe from the korado.
some really wild case matching
spun over 12500rpm
with that bridged exhaust .. you are going to be able to get wild.. this will be fast (edited)
  Treats piston port VS MK reed kit, A ReviewTopic by: Jake P Jake P 06/03/12 07:04PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Overpriced Parts Overpriced Parts 06/03/12 08:22PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/03/12 08:24PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 06/03/12 08:26PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/03/12 08:31PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Overpriced Parts Overpriced Parts 06/03/12 08:44PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/03/12 11:09PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Graham Motzing Graham Motzing 06/04/12 03:12PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/04/12 04:45PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Graham Motzing Graham Motzing 06/04/12 05:35PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/04/12 05:40PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Graham Motzing Graham Motzing 06/04/12 05:53PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/04/12 06:03PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Michael Thomas Michael Thomas 06/04/12 07:21PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/04/12 07:39PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/04/12 07:51PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/05/12 01:53AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: SABAT! andDestroy SABAT! andDestroy 06/04/12 04:35PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/04/12 08:24PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/04/12 08:39PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Graham Motzing Graham Motzing 06/04/12 09:37PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/04/12 10:55PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/04/12 09:54PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/04/12 11:11PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/04/12 11:13PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/04/12 11:29PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/04/12 11:31PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/04/12 11:37PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/05/12 12:11AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/05/12 12:21AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Charlie BUZZARD Charlie BUZZARD 06/05/12 09:00AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/05/12 01:10PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/05/12 10:33AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Graham Motzing Graham Motzing 06/05/12 12:13PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/05/12 02:10PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: ! West Seattle ! ! West Seattle ! 06/05/12 03:16PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/05/12 03:23PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: ! West Seattle ! ! West Seattle ! 06/05/12 03:36PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/05/12 05:03PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/05/12 05:35PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/05/12 07:02PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Graham Motzing Graham Motzing 06/06/12 10:52AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/12/12 12:51PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/12/12 06:08PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Overpriced Parts Overpriced Parts 06/12/12 09:56PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/12/12 11:53PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/13/12 12:04AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Graham Motzing Graham Motzing 06/13/12 12:49AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/13/12 12:50AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Graham Motzing Graham Motzing 06/13/12 11:20AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/13/12 01:45PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: ! West Seattle ! ! West Seattle ! 06/13/12 04:43PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/13/12 08:39PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/14/12 09:48AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/14/12 10:45AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: mit mortso mit mortso 06/14/12 02:21PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang 06/15/12 11:52AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/15/12 11:59AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: derbeez ryderz derbeez ryderz 06/15/12 02:55PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Drew Bell Drew Bell 06/16/12 12:59AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Charles Cole (OFMC) Charles Cole (OFMC) 06/16/12 01:14AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Rich (OFMC) Rich (OFMC) 06/16/12 02:21AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Drew Bell Drew Bell 06/16/12 09:13AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Rich (OFMC) Rich (OFMC) 06/16/12 09:54AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Graham Motzing Graham Motzing 06/16/12 11:54AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/16/12 04:48PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/18/12 09:21AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/18/12 09:56PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Drew Bell Drew Bell 06/19/12 11:42AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/24/12 01:26AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/24/12 09:08AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Cole Doubt Cole Doubt 06/24/12 12:10PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/24/12 04:14PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang 06/24/12 02:30PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang 06/24/12 05:05PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Eric P Eric P 06/24/12 11:12PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/24/12 11:27PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/25/12 09:17PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Blake MD No PM Plz Blake MD No PM Plz 06/27/12 08:22AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: timothy rendall timothy rendall 06/30/12 06:01PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/25/12 09:27PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/25/12 10:15PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/25/12 10:32PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/25/12 09:18PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/27/12 12:06AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/27/12 12:33AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/27/12 12:51AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/27/12 01:03AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/27/12 08:18PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/27/12 08:24PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/27/12 08:28PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Bill Murrow Bill Murrow 06/27/12 09:12PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Bill Murrow Bill Murrow 06/27/12 09:14PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/27/12 11:01PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Graham Motzing Graham Motzing 06/28/12 11:01AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 06/28/12 11:07AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/29/12 05:33PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Kaj Niegmann Kaj Niegmann 06/29/12 06:41PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/29/12 06:55PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Kaj Niegmann Kaj Niegmann 06/30/12 11:32AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jesse Brosnan Jesse Brosnan 06/30/12 12:00PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 07/03/12 12:09AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Daniel '' Daniel '' 07/04/12 01:26PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 07/04/12 06:51PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jesse Brosnan Jesse Brosnan 07/04/12 10:43PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 07/08/12 02:44AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Kaj Niegmann Kaj Niegmann 07/09/12 11:15PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 07/10/12 03:14AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Kaj Niegmann Kaj Niegmann 07/13/12 08:56PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 07/14/12 11:54PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: will warn will warn 07/15/12 12:19AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: timothy rendall timothy rendall 07/15/12 06:01AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Kaj Niegmann Kaj Niegmann 07/16/12 10:57PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 07/17/12 12:31AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Kaj Niegmann Kaj Niegmann 07/18/12 12:11AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Kaj Niegmann Kaj Niegmann 07/18/12 12:13AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 07/18/12 02:06AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 07/18/12 05:36PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Kaj Niegmann Kaj Niegmann 07/19/12 04:06AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 07/19/12 07:33PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Kaj Niegmann Kaj Niegmann 07/20/12 11:12PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 09/01/12 11:20PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Daniel '' Daniel '' 09/02/12 01:13PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 09/02/12 02:44PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 09/03/12 04:18AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 09/16/12 07:14PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Bill Murrow Bill Murrow 09/16/12 07:51PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 09/16/12 07:54PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Bill Murrow Bill Murrow 09/16/12 07:58PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 09/16/12 11:42PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 09/17/12 11:34PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 09/17/12 11:44PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 09/18/12 12:30AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Kaj Niegmann Kaj Niegmann 10/14/12 11:49PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 12/19/12 02:52PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Max (ツ) Max (ツ) 12/19/12 03:11PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Salsa Salsa Salsa Salsa 12/19/12 03:19PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 12/19/12 03:57PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 12/19/12 04:51PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 12/19/12 10:20PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 12/19/12 11:15PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: campeona del mundo campeona del mundo 12/19/12 11:46PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 12/20/12 12:28AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 01/25/13 09:30PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: CtpEDsHED . CtpEDsHED . 01/25/13 09:47PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 01/25/13 09:58PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Trevor Yee Trevor Yee 01/26/13 01:15PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: LSLB RXb LSLB RXb 01/26/13 02:24PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 01/26/13 02:29PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 12/11/13 06:28PM
  !Re: Daniel '' Daniel '' 12/11/13 07:55PM
  Re: !Re: Jake P Jake P 12/11/13 07:57PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Charles Cole (OFMC) Charles Cole (OFMC) 12/07/16 05:57PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 12/07/16 06:09PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Mike Boyd Mike Boyd 12/07/16 07:00PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 01/03/19 05:42PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: will warn will warn 12/07/16 07:08PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Mike Boyd Mike Boyd 12/07/16 07:13PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Charles Cole (OFMC) Charles Cole (OFMC) 01/08/19 06:54PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Chöschi21 C.K. Chöschi21 C.K. 02/07/19 05:36PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: D L D L 06/14/19 03:05PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Jake P Jake P 06/14/19 03:52PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Graham Motzing Graham Motzing 06/17/19 11:15AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: D L D L 06/15/19 05:22PM
  Re: Treats piston port VS MK reed kit, A ReviewRe: Amelie Corbeil Amelie Corbeil 06/17/19 11:17AM
  Re: Treats piston port VS MK reed kit, A ReviewRe: D L D L 04/06/20 04:24PM
