Re: Arduino Based CDI
I could design and make the boards for somthing like this, but wouldn't be able to handle the code. Man, board fab is so cheap now it doesn't even make sence to make them myself anymore.....what a world
Esp32 could handle it easily....I'm kinda blown away that this doesn't this exist already.
Man I haven't made any digital projects for such a long time, basically just been focusing on my ham, radio and tv resurrections......might have to think about this
I kinda joked a few years ago that I was going to make a tube based kinda--cdi with low voltage Soviet pico-tubes...because why wouldn't you use a tube instead of a 30 cent transistor or diode, then make a filament supply just because....lol that was such a stupid idea.
Dirty30 Dillon /
The last thing I want to complicate, is my 40 year old moped ignition.
That said, I applaud anyone who takes the time to build and code this out.
๐Ÿ‡ฎ๐Ÿ‡น๐Ÿ’ฆ Of the Loin /
Using RTOS would make it work in real-time for sure
And this wouldn't make it any more complicated than a CDI box already is
it would be super cool to make this box work with a pietcard setup too!
Dillion it's not for old stockers. It's for blasters. And wanna be tuners like me.
You don't even need a full RTOS, you could run it from a simple interrupt trigger.
But I want an async web server to let me toggle curves on the fly from my smartphone
Dirty30 Dillon /
> tuners like me.
I have plenty o blasters that didn't require me to do any board level work. Like I said, if you're a computer man, this is sick. I just don't have the technical aptitude to make this, and can't see a reason to trudge through programming if I can plop a MVT/Malossi/Parmakit/HPI CDI no there and jam out.
yamaha tzr250 was doing stuff like this up till like 2005 iirc
Rtos? Then why not do real time logging of head and exhaust temperature as well an make a universal-ish two stroke tuning and datalogging device. This could go so deep.
Best option would be ability to change curves on the fly with a wired handlebar control, so I dunno. But....Wired control or just a phone mount.... economically speaking, server and phone mount are the way to go.
also, a phone would be ideal for actually modifying the curves too....
web repository to download different curves other have made?
Is anyone actually looking into doing this because it sounds fun. I really don't think an atmega is the way forward tho..
There is a chip called lm1815 that works well for debouncing/digitizing a reluctor signal. It's also got some good RF isolation built in. My buddy designs custom ECU/ignition systems for race teams, they use it quit a bit
All this can be done with ESP32
2 core, up to like 200mhz processor, they have a few mb of flash usually, has WiFi and BLE and you can buy a devkit for 10 bucks
Like let's do it I have a bunch laying around
If I can help with anything please let me know. I can volunteer to blow up a bike for testing purposes. I have a garelli NOI that i can put a pietcard setup on to test that.
Thenggregy Cawilan /
> Mars โ€€ Wrote:
> Ryan, are you up for sharing your schematic? I'm a little electrotarded
> and looking for a good way of doing what it looks like you've done.
> I don't know how you are with C, but my firmware is coming along nice
> and maybe with your hardware and my software we could have some rockin'
> stuff.
Sir how to convert to the arduino uno this code instead of atmel IC thanks sir and more power!!!
I would say that I don't have a testing setup at the moment, but I'll see if I can port this to ESP32 to start with
Will your codes for this be available open source? I would like to see if I can get my son involved in this. He has a degree in programming and it would be nice to have it put to use a bit on the selfish side. Since we did pay for it.
Yeah no this would def be open source, would be FreeRTOS if used as well
Sounds like we should make a gitlab
I ordered some esp32s and am pretty excited! It does indeed look like a great product for this. I've been out of microcontrollers for about a decade, and am amazed at how much these little guys can do.
My target project for this is based on a kinetic CDI, which triggers off of the inversion of the pulse rather than using an external trigger.
Keep it up! Up! Up!
I have a basic RTOS shell code that stays online, so if you figure out the CDI code it should slot right in....
Ok fine I'll make a git repo for this today too
Additionally, my RTOS code will post data to an MQTT broker so if you run testing near WiFi you could do some live data streaming at ~1second resolution
> resolution
Cant it then connect into your phone via wifi to display things? Or Bluetooth? And if it needs to connect to wifi prior to connecting to your device then I have one of those MiFi hot spots from my wireless carrier. Would something like that work? It is bike mounted wifi that runs off it's own battery.
There's some sample code I found for setting the wifi information via the Bluetooth, but right now I just hard code the WiFi info
https://github.com/Maitlandk/mopedCDI
its private rightnow I guess just request access?
For my use case (kinetic coils/flywheel on a vespa motor), detecting the zero crossing of the coil voltage seems like the important thing? I won't really be sure until I rebuild the engine I'm planning on using as the test bed.
I'm tempted to use a little comparator circuit for that, it'll be very fast and I can use the edge as an interrupt trigger.
Hmm, that link gives me a 404.
yah I made it public now
will upload a bare bones RTOS skeleton later
I think the CDI code will be pretty simple. The basics are:
On an interrupt (either from an ignition coil zero crossing or an external trigger), schedule the spark, either immediately (no curve) or after some delay (derived from a CDI curve).
In a separate task, compute the amount of time between interrupts, and use that to calculate the current RPM.
Okay, I uploaded some example code that runs two tasks in FreeRTOS.
WiFi connection+MQTT and a memory check function
You'll need the hornbill AWS IoT library if you want to use MQTT, otherwise just comment that out
I'm thinking about our resolution requirements and timer stuff. I wasn't sure if we'd have access to a high precision timer on FreeRTOS on an esp32, or if we need one.
For ease of math purposes, 200 Hz = 12,000 rpm, this seems like a reasonable ballpark.
To get 1ยฐ resolution, we'd need a timer capable of ticking on the scale of 14 ยตs.
Per this page, it looks like esp_timer has microsecond precision, so that should be plenty: https://docs.espressif.com/projects/esp-idf/en/latest/esp32/api-reference/system/esp_timer.html
So this seems OK to me.
« Go to Topics โ€” end of thread
