I am in the prosess of installing this Treats CDI on my Moby. I have problems finding the right hook up for the black wire with the ring terminal, which is coming out of the stator.
On one hand,we have the wiring schematic from the Wiki, which shows to connect the black wire to the HT coil, like this:
After searching I found a lot of conflicting posts, regarding burned cdi boxes and primary coils for the treats "le partie" CDI. Some people suggest to ground the HT coil and the black wire coming from the stator plate. the original CDI ignition (allumage moryama) for french MBK 51v models suggest this too:
So, which is the correct schematic? (edited)
