Re: motobecane CDI ignition le partie - ground confusion
I noticed that the new version of the cdi wiring looks like both the black and black/white wires go together, is that so? Now I went from one confusion to another it looks like both wires go together. I don't want to take a chance and burn something
Yep, can confirm. Just installed this last month, runs great off of cheetahs diagram.
Cheetahs diagram is spot on, only debatable part is the exciter coil wire for the coil - should is be floating or run to common... the jury is out on that subject... either method will produce a robust and consistent spark.
If you follow the diagram and still no joy for a snappy blue spark then swap the orange and black wires at the coil.
What happened to the diagram?
Francois Labat /
Does this mean the current coming out the CDI is AC ?
I don't see a rectifier used for the current going to the lights.
yeah these are AC out of the box, you have to rectify for DC
