Re: motobecane CDI ignition le partie - ground confusion
I noticed that the new version of the cdi wiring looks like both the black and black/white wires go together, is that so? Now I went from one confusion to another it looks like both wires go together. I don't want to take a chance and burn something
Yep, can confirm. Just installed this last month, runs great off of cheetahs diagram.
Cheetahs diagram is spot on, only debatable part is the exciter coil wire for the coil - should is be floating or run to common... the jury is out on that subject... either method will produce a robust and consistent spark.
If you follow the diagram and still no joy for a snappy blue spark then swap the orange and black wires at the coil.
What happened to the diagram?
Does this mean the current coming out the CDI is AC ?
I don't see a rectifier used for the current going to the lights.
yeah these are AC out of the box, you have to rectify for DC
Got my 40T running nicely with the le partie CDI, but have yet to wire up the lights— which voltage regulator should I buy?? What do you guys run?
Ed - Dead Possums /
The 12v trail tech dial a brightness is the best.
That's just a regulator though right? Not a regulator/rectifier. My understanding is you're still getting AC with that, just regulated.
I've been rocking these cheap amazon $9 ones, they seem fine.
Wired as such: https://www.mopedarmy.com/wiki/NU50M_Full_Wave_Rectifer
In the drawing there 1 is out to lights, 2 and 3 are input from your coil (just split the wire and hook to both leads on the regulator/rectifier), and 4 is ground. Has worked well for my LED conversions. Blasted a bunch of hot glue in it to keep the wires from falling off. I'm sure there's a better plug or something you could get, but whatev. (edited)
Ed - Dead Possums /
The trailtech is much easier to wire in anywhere in the circuit(like on the forks behind headlight).
Yes it's regulated AC...that's what you want unless you're needing DC for like, a water pump or phone charger.
Thank you! Gonna nab one and throw it on.
On swinging engines, I always ground to frame with a big ol battery style fatty gauge ground strap. It’s stopped any grounding issues, some people love their floating grounds I’ve just never seen the need
DC is better for LED lights too. Some will work fine with AC (rectified or not) but LEDs are fundamentally one-way devices, and you'll have more stable and brighter lights with DC.
What's that thing in the bottom left of cheetah's diagram. Is that the headlight?
🇮🇹💦 Of the Loin /
AC is a garbage waveform
All my homies send it to 0hz
