Re: GY6 on a Hobbit; a different approach.
Daniel '' /
The moto matic pulley was like this one that mars designed. It put too much pressure on the fixed cheek of the rear pulley and eventually broke it. Also there are the issues with alignment that were brought up. making a rear clutch work on a hobbit is as easy as using an urban express input shaft and grabbing a special seal. You can even make a one way bearing work if you make a spacer for an hfl1616. Naz helped figure all this out and did all the machine work to get the hobbit crank to work with a doppler var. He has done it a few different ways over the years and the last iteration was by far the best and easiest way to get oversized pulleys and a rear clutch.
  GY6 on a Hobbit; a different approach.Topic by: Mars   Mars   04/22/13 08:57PM
  Re: GY6 on a Hobbit; a different approach.Re: Mars   Mars   04/22/13 09:00PM
  Re: GY6 on a Hobbit; a different approach.Re: Brad Smith Brad Smith 04/22/13 09:55PM
  Re: GY6 on a Hobbit; a different approach.Re: JBOT Admin JBOT Admin 04/22/13 10:17PM
  Re: GY6 on a Hobbit; a different approach.Re: Mars   Mars   04/22/13 10:29PM
  Re: GY6 on a Hobbit; a different approach.Re: JBOT Admin JBOT Admin 04/22/13 10:43PM
  Re: GY6 on a Hobbit; a different approach.Re: Mars   Mars   04/22/13 11:04PM
  Re: GY6 on a Hobbit; a different approach.Re: RADIUM CITY JO$HUA RADIUM CITY JO$HUA 04/22/13 11:44PM
  Re: GY6 on a Hobbit; a different approach.Re: Jake P Jake P 04/22/13 11:55PM
  Re: GY6 on a Hobbit; a different approach.Re: *.* HONDA *.* HONDA 04/23/13 01:56AM
  Re: GY6 on a Hobbit; a different approach.Re: ᴛᴇʀʀʏ ᴅᴇᴀɴ ᴛᴇʀʀʏ ᴅᴇᴀɴ 04/23/13 02:49PM
  Re: GY6 on a Hobbit; a different approach.Re: Mars   Mars   04/23/13 03:37PM
  Re: GY6 on a Hobbit; a different approach.Re: *.* HONDA *.* HONDA 04/24/13 02:25AM
  Re: GY6 on a Hobbit; a different approach.Re: Jake P Jake P 04/24/13 02:50AM
  Re: GY6 on a Hobbit; a different approach.Re: Alex Hedrick Alex Hedrick 12/30/20 02:19PM
  Re: GY6 on a Hobbit; a different approach.Re: JBOT Admin JBOT Admin 12/30/20 09:01PM
  Re: GY6 on a Hobbit; a different approach.Re: Alex Hedrick Alex Hedrick 12/30/20 10:08PM
  Re: GY6 on a Hobbit; a different approach.Re: JBOT Admin JBOT Admin 12/30/20 10:15PM
  Re: GY6 on a Hobbit; a different approach.Re: Alex Hedrick Alex Hedrick 12/30/20 11:12PM
  Re: GY6 on a Hobbit; a different approach.Re: Dirty30 Dillon Dirty30 Dillon 12/31/20 09:10AM
  Re: GY6 on a Hobbit; a different approach.Re: Daniel '' Daniel '' 12/31/20 09:49AM
