Re: Vespa intake timing: let's talk numbers
Maciek Dub /
Back to the timing discussion; The rv allows us to close the intake earlier than pp, helping with blow-back, increasing the ratio of starting volume of mixture in the case vs pressurized volume when the transfers open, and the time it has to pressurize. Jennings mentions that "curiously, the best port-closing timing for a wide variety of disc-valve engines is about 65-degrees after top center".
It also allows us to open the intake earlier, even before the transfers close. I'm wondering what detriment, if any, there would be to opening it up even earlier, up to 180°, or whenever case pressure goes negative (and reeds would open) between there and the transfers closing. Jennings touches on this, in the rv section, and the dutch seem to push the overlap past the recommended 10°. Seems like it might help with the port-stalling. Of course the only real way to find out is to start cutting on my stock crank a bit at a time and trying it till it gets worse...some things to do before I can commit to that.
My cycle as it is:
*Ignition
Intake Closes - 57° ATDC
Exhaust Opens - 95° ATDC
*Blowdown - 24° (95° ATDC - 119° ATDC)
*Crank Pumping - 62° (57° - 119° ATDC)
Transfers Open - 119° ATDC
Intake Opens - 132° BTDC (228°ATDC)
*Intake-Transfer overlap - 13° (132-119 BTDC / 228-241 ATDC)
Transfers Close - 241° ATDC (119° BTDC)
Exhaust Closes - 265° ATDC (95° BTDC)
*Ignition (edited)
  Vespa intake timing: let's talk numbersTopic by: Simon Nyi Simon Nyi 10/01/13 03:23PM
  Re: Vespa intake timing: let's talk numbersRe: Maciek Dub Maciek Dub 10/01/13 04:27PM
  Re: Vespa intake timing: let's talk numbersRe: Adam Blickhahn Adam Blickhahn 05/14/14 11:50PM
  Re: Vespa intake timing: let's talk numbersRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/22/14 02:34AM
  Re: Vespa intake timing: let's talk numbersRe: Josh G Josh G 10/01/13 05:47PM
  Re: Vespa intake timing: let's talk numbersRe: Josh G Josh G 10/01/13 05:52PM
  Re: Vespa intake timing: let's talk numbersRe: Josh G Josh G 10/01/13 06:19PM
  Re: Vespa intake timing: let's talk numbersRe: Maciek Dub Maciek Dub 10/01/13 06:37PM
  Re: Vespa intake timing: let's talk numbersRe: Simon Nyi Simon Nyi 10/01/13 06:50PM
  Re: Vespa intake timing: let's talk numbersRe: Graham Motzing Graham Motzing 10/01/13 08:23PM
  Re: Vespa intake timing: let's talk numbersRe: Simon Nyi Simon Nyi 10/01/13 10:55PM
  Re: Vespa intake timing: let's talk numbersRe: Allen Halk Allen Halk 10/01/13 11:25PM
  Re: Vespa intake timing: let's talk numbersRe: Deadped Ryan Deadped Ryan 10/01/13 11:42PM
  Re: Vespa intake timing: let's talk numbersRe: Simon Nyi Simon Nyi 10/18/13 12:58PM
  Re: Vespa intake timing: let's talk numbersRe: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/28/20 03:51AM
  Re: Vespa intake timing: let's talk numbersRe: «tyler » «tyler » 10/18/13 01:42PM
  Re: Vespa intake timing: let's talk numbersRe: Simon Nyi Simon Nyi 10/18/13 02:44PM
  Re: Vespa intake timing: let's talk numbersRe: Maciek Dub Maciek Dub 05/15/14 04:07AM
  Re: Vespa intake timing: let's talk numbersRe: Maciek Dub Maciek Dub 06/20/14 01:16PM
  Re: Vespa intake timing: let's talk numbersRe: Pete Puczasaurus Pete Puczasaurus 06/20/14 02:30PM
  Re: Vespa intake timing: let's talk numbersRe: Maciek Dub Maciek Dub 06/20/14 06:43PM
  Re: Vespa intake timing: let's talk numbersRe: Graham Motzing Graham Motzing 06/24/14 03:26PM
  Re: Vespa intake timing: let's talk numbersRe: Maciek Dub Maciek Dub 07/13/14 02:38AM
  Re: Vespa intake timing: let's talk numbersRe: Maciek Dub Maciek Dub 07/13/14 03:33AM
  Re: Vespa intake timing: let's talk numbersRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 07/13/14 03:49AM
  Re: Vespa intake timing: let's talk numbersRe: Pete Puczasaurus Pete Puczasaurus 07/13/14 02:09PM
  Re: Vespa intake timing: let's talk numbersRe: Maciek Dub Maciek Dub 07/13/14 07:10AM
  Re: Vespa intake timing: let's talk numbersRe: Maciek Dub Maciek Dub 07/17/14 12:17PM
  Re: Vespa intake timing: let's talk numbersRe: Marc Friedman Marc Friedman 07/17/14 12:46PM
  Re: Vespa intake timing: let's talk numbersRe: Maciek Dub Maciek Dub 07/17/14 12:59PM
  Re: Vespa intake timing: let's talk numbersRe: Maciek Dub Maciek Dub 07/17/14 01:31PM
  Re: Vespa intake timing: let's talk numbersRe: Marc Friedman Marc Friedman 07/17/14 01:42PM
  Re: Vespa intake timing: let's talk numbersRe: Maciek Dub Maciek Dub 07/17/14 02:11PM
  Re: Vespa intake timing: let's talk numbersRe: Marc Friedman Marc Friedman 07/17/14 02:57PM
  Re: Vespa intake timing: let's talk numbersRe: Maciek Dub Maciek Dub 07/17/14 04:24PM
  Re: Vespa intake timing: let's talk numbersRe: peter heid peter heid 07/20/14 10:35AM
  Re: Vespa intake timing: let's talk numbersRe: Maciek Dub Maciek Dub 08/19/14 02:51AM
  Re: Vespa intake timing: let's talk numbersRe: Marc Friedman Marc Friedman 12/14/14 02:59PM
  Re: Vespa intake timing: let's talk numbersRe: Maciek Dub Maciek Dub 07/22/14 03:30AM
  Re: Vespa intake timing: let's talk numbersRe: Marc Friedman Marc Friedman 12/14/14 03:50PM
  Re: Vespa intake timing: let's talk numbersRe: Marc Friedman Marc Friedman 12/14/14 04:06PM
  Re: Vespa intake timing: let's talk numbersRe: Marc Friedman Marc Friedman 12/14/14 04:20PM
  Re: Vespa intake timing: let's talk numbersRe: Marc Friedman Marc Friedman 12/14/14 04:26PM
  Re: Vespa intake timing: let's talk numbersRe: Marc Friedman Marc Friedman 12/15/14 09:44AM
  Re: Vespa intake timing: let's talk numbersRe: «tyler » «tyler » 12/15/14 12:24PM
  Re: Vespa intake timing: let's talk numbersRe: Marc Friedman Marc Friedman 12/15/14 12:28PM
  Re: Vespa intake timing: let's talk numbersRe: Maciek Dub Maciek Dub 12/16/14 05:34PM
  Re: Vespa intake timing: let's talk numbersRe: alex . alex . 12/19/14 04:35AM
  Re: Vespa intake timing: let's talk numbersRe: alex . alex . 12/19/14 05:00AM
  Re: Vespa intake timing: let's talk numbersRe: Walt W Walt W 12/22/14 08:35PM
  Re: Vespa intake timing: let's talk numbersRe: Marc Friedman Marc Friedman 12/22/14 08:48PM
  Re: Vespa intake timing: let's talk numbersRe: alex . alex . 12/23/14 04:15AM
  Re: Vespa intake timing: let's talk numbersRe: Marc Friedman Marc Friedman 12/23/14 01:12PM
  Re: Vespa intake timing: let's talk numbersRe: Maciek Dub Maciek Dub 12/24/14 11:48AM
  Re: Vespa intake timing: let's talk numbersRe: «tyler » «tyler » 10/02/13 08:46AM
  Re: Vespa intake timing: let's talk numbersRe: Simon Nyi Simon Nyi 10/18/13 01:52AM
  Re: Vespa intake timing: let's talk numbersRe: «tyler » «tyler » 10/18/13 09:31AM
  Re: Vespa intake timing: let's talk numbersRe: Pete Puczasaurus Pete Puczasaurus 06/11/14 07:38PM
  Re: Vespa intake timing: let's talk numbersRe: Pete Puczasaurus Pete Puczasaurus 06/20/14 01:09PM
  Re: Vespa intake timing: let's talk numbersRe: «tyler » «tyler » 12/15/14 07:52AM
  Re: Vespa intake timing: let's talk numbersRe: Marc Friedman Marc Friedman 12/15/14 09:19AM
