Re: Vespa intake timing: let's talk numbers
Maciek Dub /
Excerpt from Jennings on rotary disc-valve intake opening:
"If there is a rule, it is that the point of opening for rotary valves is best established right at the point of transfer-closing if you want a very broad range of power. On the other hand, maximum power is obtained by opening the intake port somewhat earlier: from 130- to 145- degrees before top center, which means that the intake and transfer ports have overlapping open periods. This presupposes that the engine will have been fitted with a proper expansion chamber."
He expands on this, so don't just cut to the max and hope it works, but it seems one can get a bit more aggressive than the anticipato cranks, by about 10° on each side in a stock case with a maxed out intake, especially on a variated engine where You don't really care about the low end.
A bit less in the polini speed case, as it gets you 6-10° more duration that's about 5-8° advanced compared to a modified stock intake. It actually closes earlier (http://vespa-ciao.nl/page.php?id=180) so there'd be more room on that side, but the opening would already be in the mid 140s. (edited)
  Vespa intake timing: let's talk numbersTopic by: Simon Nyi Simon Nyi 10/01/13 03:23PM
  Re: Vespa intake timing: let's talk numbersRe: Maciek Dub Maciek Dub 10/01/13 04:27PM
  Re: Vespa intake timing: let's talk numbersRe: Adam Blickhahn Adam Blickhahn 05/14/14 11:50PM
  Re: Vespa intake timing: let's talk numbersRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/22/14 02:34AM
  Re: Vespa intake timing: let's talk numbersRe: Josh G Josh G 10/01/13 05:47PM
  Re: Vespa intake timing: let's talk numbersRe: Josh G Josh G 10/01/13 05:52PM
  Re: Vespa intake timing: let's talk numbersRe: Josh G Josh G 10/01/13 06:19PM
  Re: Vespa intake timing: let's talk numbersRe: Maciek Dub Maciek Dub 10/01/13 06:37PM
  Re: Vespa intake timing: let's talk numbersRe: Simon Nyi Simon Nyi 10/01/13 06:50PM
  Re: Vespa intake timing: let's talk numbersRe: Graham Motzing Graham Motzing 10/01/13 08:23PM
  Re: Vespa intake timing: let's talk numbersRe: Simon Nyi Simon Nyi 10/01/13 10:55PM
  Re: Vespa intake timing: let's talk numbersRe: Allen Halk Allen Halk 10/01/13 11:25PM
  Re: Vespa intake timing: let's talk numbersRe: Deadped Ryan Deadped Ryan 10/01/13 11:42PM
  Re: Vespa intake timing: let's talk numbersRe: Simon Nyi Simon Nyi 10/18/13 12:58PM
  Re: Vespa intake timing: let's talk numbersRe: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/28/20 03:51AM
  Re: Vespa intake timing: let's talk numbersRe: «tyler » «tyler » 10/18/13 01:42PM
  Re: Vespa intake timing: let's talk numbersRe: Simon Nyi Simon Nyi 10/18/13 02:44PM
  Re: Vespa intake timing: let's talk numbersRe: Maciek Dub Maciek Dub 05/15/14 04:07AM
  Re: Vespa intake timing: let's talk numbersRe: Maciek Dub Maciek Dub 06/20/14 01:16PM
  Re: Vespa intake timing: let's talk numbersRe: Pete Puczasaurus Pete Puczasaurus 06/20/14 02:30PM
  Re: Vespa intake timing: let's talk numbersRe: Maciek Dub Maciek Dub 06/20/14 06:43PM
  Re: Vespa intake timing: let's talk numbersRe: Graham Motzing Graham Motzing 06/24/14 03:26PM
  Re: Vespa intake timing: let's talk numbersRe: Maciek Dub Maciek Dub 07/13/14 02:38AM
  Re: Vespa intake timing: let's talk numbersRe: Maciek Dub Maciek Dub 07/13/14 03:33AM
  Re: Vespa intake timing: let's talk numbersRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 07/13/14 03:49AM
  Re: Vespa intake timing: let's talk numbersRe: Pete Puczasaurus Pete Puczasaurus 07/13/14 02:09PM
  Re: Vespa intake timing: let's talk numbersRe: Maciek Dub Maciek Dub 07/13/14 07:10AM
  Re: Vespa intake timing: let's talk numbersRe: Maciek Dub Maciek Dub 07/17/14 12:17PM
  Re: Vespa intake timing: let's talk numbersRe: Marc Friedman Marc Friedman 07/17/14 12:46PM
  Re: Vespa intake timing: let's talk numbersRe: Maciek Dub Maciek Dub 07/17/14 12:59PM
  Re: Vespa intake timing: let's talk numbersRe: Maciek Dub Maciek Dub 07/17/14 01:31PM
  Re: Vespa intake timing: let's talk numbersRe: Marc Friedman Marc Friedman 07/17/14 01:42PM
  Re: Vespa intake timing: let's talk numbersRe: Maciek Dub Maciek Dub 07/17/14 02:11PM
  Re: Vespa intake timing: let's talk numbersRe: Marc Friedman Marc Friedman 07/17/14 02:57PM
  Re: Vespa intake timing: let's talk numbersRe: Maciek Dub Maciek Dub 07/17/14 04:24PM
  Re: Vespa intake timing: let's talk numbersRe: peter heid peter heid 07/20/14 10:35AM
  Re: Vespa intake timing: let's talk numbersRe: Maciek Dub Maciek Dub 08/19/14 02:51AM
  Re: Vespa intake timing: let's talk numbersRe: Marc Friedman Marc Friedman 12/14/14 02:59PM
  Re: Vespa intake timing: let's talk numbersRe: Maciek Dub Maciek Dub 07/22/14 03:30AM
  Re: Vespa intake timing: let's talk numbersRe: Marc Friedman Marc Friedman 12/14/14 03:50PM
  Re: Vespa intake timing: let's talk numbersRe: Marc Friedman Marc Friedman 12/14/14 04:06PM
  Re: Vespa intake timing: let's talk numbersRe: Marc Friedman Marc Friedman 12/14/14 04:20PM
  Re: Vespa intake timing: let's talk numbersRe: Marc Friedman Marc Friedman 12/14/14 04:26PM
  Re: Vespa intake timing: let's talk numbersRe: Marc Friedman Marc Friedman 12/15/14 09:44AM
  Re: Vespa intake timing: let's talk numbersRe: «tyler » «tyler » 12/15/14 12:24PM
  Re: Vespa intake timing: let's talk numbersRe: Marc Friedman Marc Friedman 12/15/14 12:28PM
  Re: Vespa intake timing: let's talk numbersRe: Maciek Dub Maciek Dub 12/16/14 05:34PM
  Re: Vespa intake timing: let's talk numbersRe: alex . alex . 12/19/14 04:35AM
  Re: Vespa intake timing: let's talk numbersRe: alex . alex . 12/19/14 05:00AM
  Re: Vespa intake timing: let's talk numbersRe: Walt W Walt W 12/22/14 08:35PM
  Re: Vespa intake timing: let's talk numbersRe: Marc Friedman Marc Friedman 12/22/14 08:48PM
  Re: Vespa intake timing: let's talk numbersRe: alex . alex . 12/23/14 04:15AM
  Re: Vespa intake timing: let's talk numbersRe: Marc Friedman Marc Friedman 12/23/14 01:12PM
  Re: Vespa intake timing: let's talk numbersRe: Maciek Dub Maciek Dub 12/24/14 11:48AM
  Re: Vespa intake timing: let's talk numbersRe: «tyler » «tyler » 10/02/13 08:46AM
  Re: Vespa intake timing: let's talk numbersRe: Simon Nyi Simon Nyi 10/18/13 01:52AM
  Re: Vespa intake timing: let's talk numbersRe: «tyler » «tyler » 10/18/13 09:31AM
  Re: Vespa intake timing: let's talk numbersRe: Pete Puczasaurus Pete Puczasaurus 06/11/14 07:38PM
  Re: Vespa intake timing: let's talk numbersRe: Pete Puczasaurus Pete Puczasaurus 06/20/14 01:09PM
  Re: Vespa intake timing: let's talk numbersRe: «tyler » «tyler » 12/15/14 07:52AM
  Re: Vespa intake timing: let's talk numbersRe: Marc Friedman Marc Friedman 12/15/14 09:19AM
