Re: Lets pool our contra spring knowledge!
Morten Olsen /
This is taken from a scooter forum;
First things first, this info assumes you know how a CVT works.
The job of the contra spring is to maintain appropriate tension on the drive belt, raise the belt up the rear pulley during deceleration, and balance the force of the roller weights to maintain the RPM range in which the gear ratio of the CVT varies. Here's how: When torque is applied to the front pulley, the roller weights cause the belt to rise, increasing the gear ratio of the pulley. Since the belt is a fixed length, the reciprocal action is that the belt must be pulled down towards the center of the rear pulley, raising the gear ratio simultaneously in the rear. The contra spring resists this force, creating a balance at a certain RPM range. Why is this important? The roller weights can't be too light or too heavy in relation to the stiffness of the contra spring. If you go too light on the weights, top speed will suffer. If you go too heavy on the weights, acceleration will suffer.
The contra spring also helps climb hills. As previously explained, torque from the front pulley raises the gear ratio and compresses the contra spring when accelerating. The reciprocal action happens when you climb a hill. Resistance is applied to the rear wheel, the bike slows down, and the contra spring pushes the belt back up the rear pulley until it reaches a ratio that provides enough torque at the rear wheel to climb the hill at that RPM. The engine RPM's change relatively little as the scooter slows down because as the gear ratio decreases, the scooter will travel slower at the same engine speed. If your RPM's drop dramatically and your engine starts lugging, you need a stiffer contra spring.
Here's a YouTube video of a weak contra spring demonstration...
Contra springs also put you in a lower gear ratio when you roll off the throttle or hit the brakes. The variator is doing the same thing as when you climb hills, only caused by change in throttle input and/or braking rather than change of slope of the road. The "coasting" effect upon roll off comes from the fact that the pulleys are still being turned during deceleration, even though it's from rolling along. This limits how fast the contra spring drops the gear ratio back down. I suspect the reason stiffer contra springs are billed as "performance" items is because the added resistance increases RPM's and theoretically would inherently decrease any lag time in sudden downshifting... say from riding very fast in a high gear ratio, slowing suddenly for a corner, then needing to accelerate hard back out of it. I image the trade off, after a certain point, would be excessive heat/friction losses, belt wear, and limited top speed.
  Lets pool our contra spring knowledge!Topic by: Mike Boyd Mike Boyd 01/06/15 01:16PM
  Re: Lets pool our contra spring knowledge!Re: JBOT Admin JBOT Admin 01/06/15 01:35PM
  Re: Lets pool our contra spring knowledge!Re: ๐ฟ๐‘–๐‘˜๐‘Ž-๐ฟ๐‘œ๐‘ก๐‘Ž๐‘ ๐‘Ž๐‘ข๐‘Ÿ ๐‘€๐‘’๐‘”๐‘Ž๐‘๐‘ข๐‘  ๐Ÿฆ– ๐ฟ๐‘–๐‘˜๐‘Ž-๐ฟ๐‘œ๐‘ก๐‘Ž๐‘ ๐‘Ž๐‘ข๐‘Ÿ ๐‘€๐‘’๐‘”๐‘Ž๐‘๐‘ข๐‘  ๐Ÿฆ– 01/06/15 08:06PM
  Re: Lets pool our contra spring knowledge!Re: Steve Smith Steve Smith 04/30/15 12:37AM
  Re: Lets pool our contra spring knowledge!Re: #CrazyWayneโ„ข rocks. #CrazyWayne #CrazyWayneโ„ข rocks. #CrazyWayne 04/30/15 02:18AM
  Re: Lets pool our contra spring knowledge!Re: Mike Boyd Mike Boyd 01/06/15 02:28PM
  Re: Lets pool our contra spring knowledge!Re: Born to be WillD Born to be WillD 01/06/15 02:47PM
  Re: Lets pool our contra spring knowledge!Re: ๐ฟ๐‘–๐‘˜๐‘Ž-๐ฟ๐‘œ๐‘ก๐‘Ž๐‘ ๐‘Ž๐‘ข๐‘Ÿ ๐‘€๐‘’๐‘”๐‘Ž๐‘๐‘ข๐‘  ๐Ÿฆ– ๐ฟ๐‘–๐‘˜๐‘Ž-๐ฟ๐‘œ๐‘ก๐‘Ž๐‘ ๐‘Ž๐‘ข๐‘Ÿ ๐‘€๐‘’๐‘”๐‘Ž๐‘๐‘ข๐‘  ๐Ÿฆ– 01/06/15 03:01PM
  Re: Lets pool our contra spring knowledge!Re: Born to be WillD Born to be WillD 01/06/15 03:27PM
  Re: Lets pool our contra spring knowledge!Re: todd amundson todd amundson 04/01/20 01:21PM
  Re: Lets pool our contra spring knowledge!Re: Born to be WillD Born to be WillD 01/06/15 03:30PM
  Re: Lets pool our contra spring knowledge!Re: JBOT Admin JBOT Admin 01/06/15 03:36PM
  Re: Lets pool our contra spring knowledge!Re: Mike Boyd Mike Boyd 01/06/15 04:39PM
  Re: Lets pool our contra spring knowledge!Re: Morten Olsen Morten Olsen 02/06/15 08:21AM
  Re: Lets pool our contra spring knowledge!Re: mit mortso mit mortso 04/30/15 11:06AM
  Re: Lets pool our contra spring knowledge!Re: JBOT Admin JBOT Admin 04/30/15 01:43PM
  Re: Lets pool our contra spring knowledge!Re: JBOT Admin JBOT Admin 04/30/15 01:56PM
  Re: Lets pool our contra spring knowledge!Re: Steve Smith Steve Smith 04/30/15 03:38PM
  Re: Lets pool our contra spring knowledge!Re: Mike Boyd Mike Boyd 04/30/15 04:06PM
  Re: Lets pool our contra spring knowledge!Re: mit mortso mit mortso 04/30/15 05:08PM
  Re: Lets pool our contra spring knowledge!Re: JBOT Admin JBOT Admin 04/30/15 11:29PM
  Re: Lets pool our contra spring knowledge!Re: #CrazyWayneโ„ข rocks. #CrazyWayne #CrazyWayneโ„ข rocks. #CrazyWayne 05/01/15 12:29PM
  Re: Lets pool our contra spring knowledge!Re: JBOT Admin JBOT Admin 05/01/15 12:33PM
  Re: Lets pool our contra spring knowledge!Re: #CrazyWayneโ„ข rocks. #CrazyWayne #CrazyWayneโ„ข rocks. #CrazyWayne 05/01/15 12:36PM
  Re: Lets pool our contra spring knowledge!Re: JBOT Admin JBOT Admin 05/01/15 12:57PM
  Re: Lets pool our contra spring knowledge!Re: #CrazyWayneโ„ข rocks. #CrazyWayne #CrazyWayneโ„ข rocks. #CrazyWayne 05/01/15 02:02PM
  Re: Lets pool our contra spring knowledge!Re: JBOT Admin JBOT Admin 05/01/15 04:10PM
  Re: Lets pool our contra spring knowledge!Re: Steve Smith Steve Smith 05/01/15 04:15PM
  Re: Lets pool our contra spring knowledge!Re: JBOT Admin JBOT Admin 05/01/15 04:20PM
  Re: Lets pool our contra spring knowledge!Re: Steve Smith Steve Smith 05/01/15 04:35PM
  Re: Lets pool our contra spring knowledge!Re: #CrazyWayneโ„ข rocks. #CrazyWayne #CrazyWayneโ„ข rocks. #CrazyWayne 05/01/15 04:57PM
  Re: Lets pool our contra spring knowledge!Re: Steve Smith Steve Smith 05/01/15 05:24PM
  Re: Lets pool our contra spring knowledge!Re: JBOT Admin JBOT Admin 05/01/15 04:21PM
  Re: Lets pool our contra spring knowledge!Re: JBOT Admin JBOT Admin 05/01/15 04:23PM
  Re: Lets pool our contra spring knowledge!Re: JBOT Admin JBOT Admin 05/01/15 04:51PM
  Re: Lets pool our contra spring knowledge!Re: JBOT Admin JBOT Admin 05/01/15 05:04PM
  Re: Lets pool our contra spring knowledge!Re: #CrazyWayneโ„ข rocks. #CrazyWayne #CrazyWayneโ„ข rocks. #CrazyWayne 05/01/15 05:08PM
  Re: Lets pool our contra spring knowledge!Re: JBOT Admin JBOT Admin 05/01/15 05:12PM
  Re: Lets pool our contra spring knowledge!Re: JBOT Admin JBOT Admin 05/01/15 05:23PM
  Re: Lets pool our contra spring knowledge!Re: Steve Smith Steve Smith 05/01/15 06:11PM
  Re: Lets pool our contra spring knowledge!Re: JBOT Admin JBOT Admin 05/01/15 06:27PM
  Re: Lets pool our contra spring knowledge!Re: JBOT Admin JBOT Admin 05/01/15 08:07PM
  Re: Lets pool our contra spring knowledge!Re: Steve Smith Steve Smith 05/01/15 08:50PM
  Re: Lets pool our contra spring knowledge!Re: Morten Olsen Morten Olsen 05/05/15 09:44AM
  Re: Lets pool our contra spring knowledge!Re: JBOT Admin JBOT Admin 05/05/15 11:27AM
  Re: Lets pool our contra spring knowledge!Re: Steve Smith Steve Smith 05/05/15 11:40AM
  Re: Lets pool our contra spring knowledge!Re: JBOT Admin JBOT Admin 05/05/15 11:46AM
  Re: Lets pool our contra spring knowledge!Re: Morten Olsen Morten Olsen 05/06/15 05:41AM
  Re: Lets pool our contra spring knowledge!Re: Morten Olsen Morten Olsen 05/06/15 11:24AM
  Re: Lets pool our contra spring knowledge!Re: #CrazyWayneโ„ข rocks. #CrazyWayne #CrazyWayneโ„ข rocks. #CrazyWayne 05/06/15 12:21PM
  Re: Lets pool our contra spring knowledge!Re: Morten Olsen Morten Olsen 05/06/15 01:56PM
  Re: Lets pool our contra spring knowledge!Re: Morten Olsen Morten Olsen 05/06/15 02:22PM
  Re: Lets pool our contra spring knowledge!Re: JBOT Admin JBOT Admin 05/06/15 11:34AM
  Re: Lets pool our contra spring knowledge!Re: Morten Olsen Morten Olsen 05/06/15 12:03PM
  Re: Lets pool our contra spring knowledge!Re: Morten Olsen Morten Olsen 05/06/15 02:10PM
  Re: Lets pool our contra spring knowledge!Re: Terbo Speghetti Terbo Speghetti 03/31/20 03:21PM
  Re: Lets pool our contra spring knowledge!Re: JBOT Admin JBOT Admin 04/01/20 01:06PM
  Re: Lets pool our contra spring knowledge!Re: Dr No Fun Dr No Fun 04/03/20 04:21PM
  Re: Lets pool our contra spring knowledge!Re: Mike Boyd Mike Boyd 04/01/20 02:08PM
  Re: Lets pool our contra spring knowledge!Re: JBOT Admin JBOT Admin 04/03/20 04:27PM
