Re: 78/81 Honda Express buildup help request
Rich Swingewood /
I've got an 81 Express, have not started on it yet but curious in what you end up doing.
I would have thought if you are going full hog why not modify the frame to take the 2 speed transmission, just a thought ?
Cheers
Rich
Because you don't need to modify the frame... The 2 speed also has the same final drive and it's not capable of any higher top speed.
Rich Swingewood /
Ok, did not know, thanks.
Sounds like a great project. Pardon the slight deviation from original post, but if you decide to go with a bigger carb and/or reeds - I've got a new Malossi PHGB for the hobbit.
https://mopedarmy.com/forums/read.php?2,3868763
That intake won't fit properly on an express. Would put the carb right into the rear tire.
Tyler Dead Possums /
Ben Whittle Wrote:
> Tyler "Gary" Dead Possums Wrote:
> > I was always under the impression that forced
> > induction doesn't work on a traditional
> 2stroke,
> > since the exhaust port is open after the intake
> is
> > closed, so any boost you built goes straight
> > out... Unless the reverb air forces from the
> pipe
> > keep the boost in?! Idk, I'm no scientist.
> OP, I read this and thought I read you had typed
> this! My fault.
> It's mopeds, so do what ever you want. Get wild I
> guess.
So it's me your're insulting?!
chad dixon /
Jugs arrived Monday. Shipped them out to Maryland today for porting. Moving along now!
Done yet?
I'm guessing it's right on the predicted path to nowhere.
Someone should email him ....me....and see what the deal is....could be abortion....could be the latter
You know that the latter means the later or 2nd of two (or more), right? You gave no latter to be picked lol.
Email sent ...it could be 2 abortions....thrown from a latter
Any response yet? Chad might be halfway to another far galaxy at this point
