Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?
Overpriced Parts /
Ya 19mm kinda too big for stock cylinder anyway let alone 21mm.
Do your homework! A stock high torque 2HP cylinder has a round intake hole 14 maybe 15 MM so why would you even want to put that carburetor or any 21mm square intake on.
Even if you could get to 21 mm carburetor to work running really tiny jets and dremeling the cylinder intake hole 21mm Square you still would lose a lot of low-end. A 14 mm Bing maybe 15mm Bing is best to use with your setup anyway. A Proma pipe tops out quick so soon as you 21 mm carburetor would start into the powerband your pipe would die out where as a 14-15mm carburetor when jetted correctly will give you good power throughout the range
  can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Topic by: Jim Herman Jim Herman 03/18/16 01:41PM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Overpriced Parts Overpriced Parts 03/18/16 04:17PM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Bob Selby Bob Selby 03/19/16 09:02AM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Jim Herman Jim Herman 03/19/16 09:16AM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Bob Selby Bob Selby 03/19/16 10:34AM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Jim Herman Jim Herman 03/19/16 10:41AM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Ben Whittle Ben Whittle 03/19/16 11:51AM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Max Johnson Max Johnson 03/19/16 11:58AM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Rebel Moby Rebel Moby 03/19/16 05:43PM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Pizza the Hutt Pizza the Hutt 03/22/16 06:54AM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Jim Herman Jim Herman 03/22/16 08:31AM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Overpriced Parts Overpriced Parts 03/22/16 11:28AM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Gromosaurus Rex - Brad Pitt Gromosaurus Rex - Brad Pitt 03/22/16 11:00AM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Tom Phuleyrie Tom Phuleyrie 03/15/19 11:11PM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Mike Boyd Mike Boyd 03/16/19 01:38AM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: EH FCC of the QCB EH FCC of the QCB 03/16/19 08:06AM
