Do not put a smaller bore intake on any carb unless you want to mess endlessly with disappointing results while you change jets, emulsion tubes, slides then back to jets then timing then emulsion tubes, then mess with the slide, look for non existent vacuum leaks then mess with the timing again, change jets then look at plug heat range...
...might be a leap year but why waste all 366 days trying to get something to tune...
