Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?
Pizza the Hutt /
The basic answer to the original question is that a 21mm carb to 19mm intake isn't ideal but won't be quite the catastrophe that rebelmoby made it sound like, at least in my opinion.
Going 26mph doesn't immediately mean that your ped has a problem, you might have a 1.5hp engine. Check the hp rating before you spend any time looking for a problem that might not be there. The larger issue is trying to put all that on a stock cylinder at all. This is a bit of a simplification but the carb, cylinder and pipe are meant to work in balance with eachother. You can't radically increase the sizes one at a time.
On a side note, I don't know what conversation you had with the seller but no carb is "bolt and go" for any ped. A new carb will always require tuning at the very least. PHBGs are more complicated to tune than pretty much any other carb, read the wiki article specifically written about tuning them.
  can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Topic by: Jim Herman Jim Herman 03/18/16 01:41PM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Overpriced Parts Overpriced Parts 03/18/16 04:17PM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Bob Selby Bob Selby 03/19/16 09:02AM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Jim Herman Jim Herman 03/19/16 09:16AM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Bob Selby Bob Selby 03/19/16 10:34AM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Jim Herman Jim Herman 03/19/16 10:41AM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Ben Whittle Ben Whittle 03/19/16 11:51AM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Max Johnson Max Johnson 03/19/16 11:58AM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Rebel Moby Rebel Moby 03/19/16 05:43PM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Pizza the Hutt Pizza the Hutt 03/22/16 06:54AM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Jim Herman Jim Herman 03/22/16 08:31AM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Overpriced Parts Overpriced Parts 03/22/16 11:28AM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Gromosaurus Rex - Brad Pitt Gromosaurus Rex - Brad Pitt 03/22/16 11:00AM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Tom Phuleyrie Tom Phuleyrie 03/15/19 11:11PM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Mike Boyd Mike Boyd 03/16/19 01:38AM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: EH FCC of the QCB EH FCC of the QCB 03/16/19 08:06AM
