Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?
Jim Herman /
as far as "bolt and go" i may have stretched that a bit. Im aware that jetting and tuning is required. My maxi is a 2HP. Ive decided to start with a 15mm bing to pair with the circuit pipe, might look into upping the front gear and see where that gets me.
I will hold onto the dellotro and maybe find a use for it down the road.
thanks for the input!
  can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Topic by: Jim Herman Jim Herman 03/18/16 01:41PM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Overpriced Parts Overpriced Parts 03/18/16 04:17PM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Bob Selby Bob Selby 03/19/16 09:02AM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Jim Herman Jim Herman 03/19/16 09:16AM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Bob Selby Bob Selby 03/19/16 10:34AM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Jim Herman Jim Herman 03/19/16 10:41AM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Ben Whittle Ben Whittle 03/19/16 11:51AM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Max Johnson Max Johnson 03/19/16 11:58AM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Rebel Moby Rebel Moby 03/19/16 05:43PM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Pizza the Hutt Pizza the Hutt 03/22/16 06:54AM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Jim Herman Jim Herman 03/22/16 08:31AM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Overpriced Parts Overpriced Parts 03/22/16 11:28AM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Gromosaurus Rex - Brad Pitt Gromosaurus Rex - Brad Pitt 03/22/16 11:00AM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Tom Phuleyrie Tom Phuleyrie 03/15/19 11:11PM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: Mike Boyd Mike Boyd 03/16/19 01:38AM
  Re: can i use a 19mm intake on a dellorto PHBG 21mm AD carburetor?Re: EH FCC of the QCB EH FCC of the QCB 03/16/19 08:06AM
