Re: Vespa + HPI Mini Rotor
Marc Friedman /
So if I'm reading this right., if you alllign the stator plate to the lowest of the four posts that would hold the stock coils, than the taper of the crank doesn't allow for the rotor to be low enough to cover the coils. So it sounds that unless you remill the taper you should first press and bolt the rotor to the crank and that could actually be done before the crank is
Put into the case. Based on the where the rotor fits is where the stator needs to be set.
So
Far so insane. What r u doing for a fan? My conception is that this calls for water cooling of
At least the head. This is why Vespas are insane to mod past a mild build u less you are a genius with a complete machine shop that u know how to use at your disposal.
The guy who figures out a good solution taking a
Case and fitting
A
Hpi reliably and with a
Fan has got my order. Otherwise after
Months of
Futile
Kinetic
Mcivering I am back to 6 v plus points.
  Vespa + HPI Mini RotorTopic by: Max (ツ) Max (ツ) 05/11/16 09:36PM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 05/11/16 10:28PM
  Re: Vespa + HPI Mini RotorRe: Marc Friedman Marc Friedman 05/11/16 11:00PM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 05/12/16 07:09AM
  Re: Vespa + HPI Mini RotorRe: Grande Guru Grande Guru 05/12/16 09:55AM
  Re: Vespa + HPI Mini RotorRe: Mike Boyd Mike Boyd 05/11/16 11:19PM
  Re: Vespa + HPI Mini RotorRe: ***VANILLA BLUNDER*** ***VANILLA BLUNDER*** 05/12/16 09:18AM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 05/12/16 11:22AM
  Re: Vespa + HPI Mini RotorRe: Dave Steele Dave Steele 05/12/16 03:43PM
  Re: Vespa + HPI Mini RotorRe: «tyler » «tyler » 05/12/16 09:09PM
  Re: Vespa + HPI Mini RotorRe: Grande Guru Grande Guru 05/13/16 12:22PM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 05/13/16 05:41PM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 05/18/16 09:58AM
  Re: Vespa + HPI Mini RotorRe: MTech -> MTech -> 05/12/16 09:32PM
  Re: Vespa + HPI Mini RotorRe: «tyler » «tyler » 05/12/16 09:51PM
  Re: Vespa + HPI Mini RotorRe: MTech -> MTech -> 06/01/16 12:51PM
  Re: Vespa + HPI Mini RotorRe: maxim vdb maxim vdb 07/25/16 07:19AM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 09/30/18 02:51PM
  Re: Vespa + HPI Mini RotorRe: Dirty30 Dillon Dirty30 Dillon 10/02/18 10:50AM
  Re: Vespa + HPI Mini RotorRe: JBOT Admin JBOT Admin 06/01/16 01:04PM
  Re: Vespa + HPI Mini RotorRe: JBOT Admin JBOT Admin 06/01/16 01:16PM
  Re: Vespa + HPI Mini RotorRe: MTech -> MTech -> 07/25/16 08:10AM
  Re: Vespa + HPI Mini RotorRe: maxim vdb maxim vdb 07/25/16 08:32AM
  Re: Vespa + HPI Mini RotorRe: maxim vdb maxim vdb 07/25/16 08:35AM
  Re: Vespa + HPI Mini RotorRe: maxim vdb maxim vdb 07/25/16 10:23AM
  Re: Vespa + HPI Mini RotorRe: Grande Guru Grande Guru 09/10/16 10:25AM
  Re: Vespa + HPI Mini RotorRe: Grande Guru Grande Guru 09/23/16 08:26PM
  Re: Vespa + HPI Mini RotorRe: Marc Friedman Marc Friedman 10/01/18 11:30PM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 10/02/18 12:03AM
  Re: Vespa + HPI Mini RotorRe: Graham Motzing Graham Motzing 10/03/18 10:20AM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 10/03/18 11:32AM
  Re: Vespa + HPI Mini RotorRe: scrot rash scrot rash 10/08/18 12:58PM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 10/08/18 01:19PM
  Re: Vespa + HPI Mini RotorRe: scrot rash scrot rash 10/08/18 02:31PM
  Re: Vespa + HPI Mini RotorRe: scrot rash scrot rash 10/08/18 02:44PM
  Re: Vespa + HPI Mini RotorRe: scrot rash scrot rash 10/08/18 02:57PM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 10/08/18 03:08PM
  Re: Vespa + HPI Mini RotorRe: scrot rash scrot rash 10/08/18 03:45PM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 03/31/19 05:49PM
  Re: Vespa + HPI Mini RotorRe: Marc Friedman Marc Friedman 03/31/19 07:18PM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 04/03/19 10:26PM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 04/03/19 10:28PM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 04/03/19 10:31PM
  Re: Vespa + HPI Mini RotorRe: Marc Friedman Marc Friedman 04/03/19 10:43PM
  Re: Vespa + HPI Mini RotorRe: Dave Steele Dave Steele 04/04/19 11:30AM
  Re: Vespa + HPI Mini RotorRe: Graham Motzing Graham Motzing 04/04/19 11:37AM
  Re: Vespa + HPI Mini RotorRe: EH FCC of the QCB EH FCC of the QCB 04/04/19 06:27AM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 04/04/19 07:26AM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 04/04/19 01:58PM
  Re: Vespa + HPI Mini RotorRe: Graham Motzing Graham Motzing 04/04/19 03:41PM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 03/21/20 08:35AM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 03/22/20 12:02PM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 03/22/20 06:43PM
  Re: Vespa + HPI Mini RotorRe: ᴛᴇʀʀʏ ᴅᴇᴀɴ ᴛᴇʀʀʏ ᴅᴇᴀɴ 03/22/20 11:01PM
  Re: Vespa + HPI Mini RotorRe: - Joe - - Joe - 04/01/20 08:40AM
  Re: Vespa + HPI Mini RotorRe: Graham Motzing Graham Motzing 04/01/20 09:05AM
  Re: Vespa + HPI Mini RotorRe: - Joe - - Joe - 04/01/20 11:53AM
  Re: Vespa + HPI Mini RotorRe: Daniel '' Daniel '' 04/01/20 09:51PM
  Re: Vespa + HPI Mini RotorRe: - Joe - - Joe - 04/02/20 09:34AM
