hpi is one of the easiest to adjust
if you know what your doing
in my case ive got a polini evo kick engine so its cdi ignition
the coil mounting points are a bit more sunk in then the points version
im thinking about making a simple sunk base plate
so if i mill the rotor it will sink an additional 3.8-4mm
what would be perfect for the thread clearance
