Re: Vespa + HPI Mini Rotor
Marc Friedman /
This is above my pay grade but...the way to make a Vespa tame the heat probably is the mlm water cooler Vespa head. The perfect solution would be a one way bearing on the rear clutch as in the one way bearing on the front variator of a Hobbit. Then fit whatever cdi u want and forget the fan. That one way bearing requires invention. The Vespa heat is even worse than Hobbit heat.
What kit is on that mallosi points case ? Isn't it cut for a 46 mm kit. Which of course has near zero clearance from one or more studs. What did u use and is your ride hot because of that ?
  Vespa + HPI Mini RotorTopic by: Max (ツ) Max (ツ) 05/11/16 09:36PM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 05/11/16 10:28PM
  Re: Vespa + HPI Mini RotorRe: Marc Friedman Marc Friedman 05/11/16 11:00PM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 05/12/16 07:09AM
  Re: Vespa + HPI Mini RotorRe: Grande Guru Grande Guru 05/12/16 09:55AM
  Re: Vespa + HPI Mini RotorRe: Mike Boyd Mike Boyd 05/11/16 11:19PM
  Re: Vespa + HPI Mini RotorRe: ***VANILLA BLUNDER*** ***VANILLA BLUNDER*** 05/12/16 09:18AM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 05/12/16 11:22AM
  Re: Vespa + HPI Mini RotorRe: Dave Steele Dave Steele 05/12/16 03:43PM
  Re: Vespa + HPI Mini RotorRe: «tyler » «tyler » 05/12/16 09:09PM
  Re: Vespa + HPI Mini RotorRe: Grande Guru Grande Guru 05/13/16 12:22PM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 05/13/16 05:41PM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 05/18/16 09:58AM
  Re: Vespa + HPI Mini RotorRe: MTech -> MTech -> 05/12/16 09:32PM
  Re: Vespa + HPI Mini RotorRe: «tyler » «tyler » 05/12/16 09:51PM
  Re: Vespa + HPI Mini RotorRe: MTech -> MTech -> 06/01/16 12:51PM
  Re: Vespa + HPI Mini RotorRe: maxim vdb maxim vdb 07/25/16 07:19AM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 09/30/18 02:51PM
  Re: Vespa + HPI Mini RotorRe: Dirty30 Dillon Dirty30 Dillon 10/02/18 10:50AM
  Re: Vespa + HPI Mini RotorRe: JBOT Admin JBOT Admin 06/01/16 01:04PM
  Re: Vespa + HPI Mini RotorRe: JBOT Admin JBOT Admin 06/01/16 01:16PM
  Re: Vespa + HPI Mini RotorRe: MTech -> MTech -> 07/25/16 08:10AM
  Re: Vespa + HPI Mini RotorRe: maxim vdb maxim vdb 07/25/16 08:32AM
  Re: Vespa + HPI Mini RotorRe: maxim vdb maxim vdb 07/25/16 08:35AM
  Re: Vespa + HPI Mini RotorRe: maxim vdb maxim vdb 07/25/16 10:23AM
  Re: Vespa + HPI Mini RotorRe: Grande Guru Grande Guru 09/10/16 10:25AM
  Re: Vespa + HPI Mini RotorRe: Grande Guru Grande Guru 09/23/16 08:26PM
  Re: Vespa + HPI Mini RotorRe: Marc Friedman Marc Friedman 10/01/18 11:30PM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 10/02/18 12:03AM
  Re: Vespa + HPI Mini RotorRe: Graham Motzing Graham Motzing 10/03/18 10:20AM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 10/03/18 11:32AM
  Re: Vespa + HPI Mini RotorRe: scrot rash scrot rash 10/08/18 12:58PM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 10/08/18 01:19PM
  Re: Vespa + HPI Mini RotorRe: scrot rash scrot rash 10/08/18 02:31PM
  Re: Vespa + HPI Mini RotorRe: scrot rash scrot rash 10/08/18 02:44PM
  Re: Vespa + HPI Mini RotorRe: scrot rash scrot rash 10/08/18 02:57PM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 10/08/18 03:08PM
  Re: Vespa + HPI Mini RotorRe: scrot rash scrot rash 10/08/18 03:45PM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 03/31/19 05:49PM
  Re: Vespa + HPI Mini RotorRe: Marc Friedman Marc Friedman 03/31/19 07:18PM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 04/03/19 10:26PM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 04/03/19 10:28PM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 04/03/19 10:31PM
  Re: Vespa + HPI Mini RotorRe: Marc Friedman Marc Friedman 04/03/19 10:43PM
  Re: Vespa + HPI Mini RotorRe: Dave Steele Dave Steele 04/04/19 11:30AM
  Re: Vespa + HPI Mini RotorRe: Graham Motzing Graham Motzing 04/04/19 11:37AM
  Re: Vespa + HPI Mini RotorRe: EH FCC of the QCB EH FCC of the QCB 04/04/19 06:27AM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 04/04/19 07:26AM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 04/04/19 01:58PM
  Re: Vespa + HPI Mini RotorRe: Graham Motzing Graham Motzing 04/04/19 03:41PM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 03/21/20 08:35AM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 03/22/20 12:02PM
  Re: Vespa + HPI Mini RotorRe: Max (ツ) Max (ツ) 03/22/20 06:43PM
  Re: Vespa + HPI Mini RotorRe: ᴛᴇʀʀʏ ᴅᴇᴀɴ ᴛᴇʀʀʏ ᴅᴇᴀɴ 03/22/20 11:01PM
  Re: Vespa + HPI Mini RotorRe: - Joe - - Joe - 04/01/20 08:40AM
  Re: Vespa + HPI Mini RotorRe: Graham Motzing Graham Motzing 04/01/20 09:05AM
  Re: Vespa + HPI Mini RotorRe: - Joe - - Joe - 04/01/20 11:53AM
  Re: Vespa + HPI Mini RotorRe: Daniel '' Daniel '' 04/01/20 09:51PM
  Re: Vespa + HPI Mini RotorRe: - Joe - - Joe - 04/02/20 09:34AM
