Re: Hand brake launch lever kinda
JBOT Admin /
Nothing to really see.
At least while riding.
I retuned the variation a bit tho, and am going much much faster now.
Adjusted the contra spring to be very loose,
And now I control variation mostly with the variator brake.
Start off locked (zero bouncy bouncy)
get to max rpms,
slight release of lever
then lock again.
Repeat.
The engine won't jump at all if you release the brake lightly.
I just love not having to constantly keep my foot on that launch lever.
When I need to downshift, just a slight tap on the foot lever puts the rpm where I want it.
Only concern is tight cornering when the variation is locked, cuz you launch hard out of the corner and can skip the back wheel. LolZ
  Hand brake launch lever kindaTopic by: JBOT Admin JBOT Admin 08/12/17 08:17PM
  Re: Hand brake launch lever kindaRe: cheetahchrome . cheetahchrome . 08/13/17 12:21PM
  Re: Hand brake launch lever kindaRe: Ryan . Ryan . 08/13/17 12:54PM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 08/13/17 01:34PM
  Re: Hand brake launch lever kindaRe: Ryan . Ryan . 08/13/17 02:04PM
  Re: Hand brake launch lever kindaRe: Glenn Kuehn Glenn Kuehn 08/13/17 05:38PM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 08/13/17 08:46PM
  Re: Hand brake launch lever kindaRe: Dan (LandLordsMG/PSVMC) Dan (LandLordsMG/PSVMC) 08/15/17 05:16PM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 08/15/17 05:19PM
  Re: Hand brake launch lever kindaRe: mit mortso mit mortso 08/16/17 04:36PM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 08/16/17 04:59PM
  Re: Hand brake launch lever kindaRe: Aron Chaudiere Aron Chaudiere 08/17/17 12:21AM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 08/17/17 12:37AM
  Re: Hand brake launch lever kindaRe: Scott Rehski Scott Rehski 08/17/17 08:41AM
  Re: Hand brake launch lever kindaRe: Dave & Bummerzz Dave & Bummerzz 08/17/17 09:58AM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 08/17/17 11:17AM
  Re: Hand brake launch lever kindaRe: Scott Rehski Scott Rehski 08/17/17 11:30AM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 08/17/17 02:04PM
  Re: Hand brake launch lever kindaRe: brian schulz brian schulz 08/17/17 03:27PM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 08/17/17 03:29PM
  Re: Hand brake launch lever kindaRe: brian schulz brian schulz 08/17/17 03:30PM
  Re: Hand brake launch lever kindaRe: brian schulz brian schulz 08/17/17 03:32PM
  Re: Hand brake launch lever kindaRe: Born to be WillD Born to be WillD 08/17/17 05:29PM
  Re: Hand brake launch lever kindaRe: Ryan . Ryan . 08/17/17 06:18PM
  Re: Hand brake launch lever kindaRe: Lee Hoffguy Lee Hoffguy 08/17/17 07:06PM
  Re: Hand brake launch lever kindaRe: Ada Dictome Ada Dictome 08/18/17 11:22AM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 08/18/17 12:20PM
  Re: Hand brake launch lever kindaRe: Ada Dictome Ada Dictome 08/18/17 01:06PM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 08/18/17 02:38PM
  Re: Hand brake launch lever kindaRe: Ada Dictome Ada Dictome 08/18/17 09:57PM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 08/18/17 10:29PM
  Re: Hand brake launch lever kindaRe: EH FCC of the QCB EH FCC of the QCB 08/19/17 06:23PM
  Re: Hand brake launch lever kindaRe: Rebel Moby Rebel Moby 08/19/17 10:20AM
  Re: Hand brake launch lever kindaRe: Dan (LandLordsMG/PSVMC) Dan (LandLordsMG/PSVMC) 08/19/17 02:16PM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 08/19/17 02:50PM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 08/19/17 05:53PM
  Re: Hand brake launch lever kindaRe: Dan (LandLordsMG/PSVMC) Dan (LandLordsMG/PSVMC) 08/19/17 06:01PM
  Re: Hand brake launch lever kindaRe: Ada Dictome Ada Dictome 08/23/17 10:53AM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 08/19/17 06:17PM
  Re: Hand brake launch lever kindaRe: EH FCC of the QCB EH FCC of the QCB 08/19/17 06:24PM
  Re: Hand brake launch lever kindaRe: Dan (LandLordsMG/PSVMC) Dan (LandLordsMG/PSVMC) 08/19/17 07:09PM
  Re: Hand brake launch lever kindaRe: Ada Dictome Ada Dictome 08/20/17 05:13PM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 08/19/17 06:20PM
  Re: Hand brake launch lever kindaRe: Flagrant - Flagrant - 08/19/17 06:26PM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 08/19/17 06:29PM
  Re: Hand brake launch lever kindaRe: Ada Dictome Ada Dictome 08/19/17 06:42PM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 08/19/17 06:54PM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 08/20/17 05:36PM
  Re: Hand brake launch lever kindaRe: Ada Dictome Ada Dictome 08/20/17 05:46PM
  Re: Hand brake launch lever kindaRe: Charles Cole (OFMC) Charles Cole (OFMC) 08/20/17 05:55PM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 08/20/17 06:19PM
  Re: Hand brake launch lever kindaRe: Ada Dictome Ada Dictome 08/21/17 10:24AM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 08/21/17 04:03PM
  Re: Hand brake launch lever kindaRe: Ada Dictome Ada Dictome 08/24/17 11:55AM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 08/21/17 04:40PM
  Re: Hand brake launch lever kindaRe: nick s nick s 08/21/17 04:56PM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 08/21/17 05:01PM
  Re: Hand brake launch lever kindaRe: brian schulz brian schulz 08/22/17 08:50AM
  Re: Hand brake launch lever kindaRe: brian schulz brian schulz 08/22/17 08:51AM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 08/22/17 11:20AM
  Re: Hand brake launch lever kindaRe: brian schulz brian schulz 08/22/17 11:49AM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 08/22/17 12:07PM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 08/22/17 12:13PM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 08/22/17 12:17PM
  Re: Hand brake launch lever kindaRe: brian schulz brian schulz 08/22/17 01:35PM
  Re: Hand brake launch lever kindaRe: brian schulz brian schulz 08/22/17 01:36PM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 12/05/17 04:25PM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 03/05/18 02:56PM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 02/28/19 08:58PM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 02/28/19 09:15PM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 08/22/17 01:45PM
  Re: Hand brake launch lever kindaRe: nick s nick s 08/22/17 02:07PM
  Re: Hand brake launch lever kindaRe: brian schulz brian schulz 08/23/17 08:11AM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 08/24/17 01:12PM
  Re: Hand brake launch lever kindaRe: Born to be WillD Born to be WillD 08/24/17 01:14PM
  Re: Hand brake launch lever kindaRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 12/05/17 07:31PM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 12/05/17 07:59PM
  Re: Hand brake launch lever kindaRe: P D P D 12/06/17 12:32AM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 12/06/17 01:23AM
  Re: Hand brake launch lever kindaRe: P D P D 12/06/17 01:24AM
  Re: Hand brake launch lever kindaRe: Charlie Wonka Charlie Wonka 12/06/17 01:33AM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 12/06/17 12:19PM
  Re: Hand brake launch lever kindaRe: Born to be WillD Born to be WillD 12/06/17 01:43PM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 12/06/17 02:00PM
  Re: Hand brake launch lever kindaRe: Graham Motzing Graham Motzing 03/05/18 05:06PM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 03/05/18 08:11PM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 01/31/19 01:19PM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 01/31/19 08:09PM
  Re: Hand brake launch lever kindaRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 02/01/19 01:00PM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 02/01/19 01:55PM
  Re: Hand brake launch lever kindaRe: weldwizard Jake weldwizard Jake 02/01/19 04:40PM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 02/01/19 09:21PM
  Re: Hand brake launch lever kindaRe: Ada Dictome Ada Dictome 02/01/19 12:47PM
  Re: Hand brake launch lever kindaRe: JBOT Admin JBOT Admin 02/01/19 12:56PM
