Re: Hand brake launch lever kinda
Ok, I see now that the rebar is pinned to the bar that can be pulled by the cable. Look like it would work but looks awfully poor leverage.
Must be a bitch to do that by hand.
Still wondering about the lever.
Maybe attached to the original decomp lever?
Or an extra brake lever or throttle?
Ah, puch clutch lever.
Lol, nevermind.
I stupid
yup a puch left hand side assembly
Hey Jbot... you going to the races in 3 weeks?
No, I don't race on tracks.
I prefer 1000mi races. More my style.
Brian, so with no variation the clutch lever has a bunch of slack in it, correct, because there needs to be that extra cable length for when the engine variates? Then, if you grab the clutch lever it pulls in that slack/extra cable length, thereby pulling the engine back forward, effectively downshifting like it would if you stomped on a launch lever?
Nick,
I don't know how Jesse solved the issue of slack in the cable at full variation. Since the clutch lever pinches the cable there is no potential of the cable becoming disconnected at the lever location. maybe at the engine mount location the cable would just freely move when the lever is not engaged
Anonymous User /
scootertrash
Good 1!
Anonymous User /
scootertrash
JBOT, a friend Wrote:
> On a ride now, and man, I just gotta say.
> This is the most fun I've had with a Moby in
> years.
> Coolest thing is that you can see how high your
> bike really can rev by locking the engine.
> It's so much different than having too strong of a
> spring where it keeps trying to variate and you
> can get weird bucking.
> This makes it like a multi speed bike.
> For gods sake somebody else do this.
> And I'm an atheist
Fire it up! Let's see some Jbotic hobbit Tung-en-grüV locking action!
Nothing to really see.
At least while riding.
I retuned the variation a bit tho, and am going much much faster now.
Adjusted the contra spring to be very loose,
And now I control variation mostly with the variator brake.
Start off locked (zero bouncy bouncy)
get to max rpms,
slight release of lever
then lock again.
Repeat.
The engine won't jump at all if you release the brake lightly.
I just love not having to constantly keep my foot on that launch lever.
When I need to downshift, just a slight tap on the foot lever puts the rpm where I want it.
Only concern is tight cornering when the variation is locked, cuz you launch hard out of the corner and can skip the back wheel. LolZ
im gonna build a moby and do this.
Noticed that the steel lever arm off the launch lever pedal for the variator brake didn't grab for shit,
So I changed it to aluminum, added holes for extra grip and siped the pads.
Now it works great with this mechanical caliper from scootertrash, , almost as easy as my hydraulic caliper on the Moby.
Can you make a video showing it in action?
Nope, it has to be used when riding....don't have a helmet cam
You must have duct tape . LOL
That's not worthy of an lol.
That was stupid as fuck
Never would anyone laugh at that.
What is wrong with you?
I think you're fucked in the head
LOL ^
J-Bot can make anything but a mount for his camera.
Belated little girl giggle
Charlie
> Charlie
When I don't care about something, yes. I cannot make it.
Charlie
not to derail but what's up with your pipe mount?
What do you mean?
It's a swinging engine so I have a mid pipe ball joint and added support at the header.
Took this little bubbie out for a ride yesterday, and it's just as thrilling as it was before.
In tight twists and turns I just keep the variator brake locked, and the power delivery is instantaneous.
No goat at startup even with a super weak spring.
No one has tried this yet?
nah i just learned to be happy with my mopeds being slow, much easier.
Yeah, that's fine too.
Not
Has anyone done this yet on a French bike?
If not you're really missing out.
VIDEOOOOOO
Anonymous User /
scootertrash
Thumbs uP!
Hard to see the brake clamping down in the vid.
Once it's under load it performs very different. But that weak ass spring is perfect if you can lock the variation position.
I'm still using a stock crank and haven't had any breakage due to locking and releasing the swing.
How about some riding footage, side by side with a similar setup without the lever? Its hard to visualize just how much these things affect performance
How about not.
If you can't see the advantage I don't know what to tell you.
Just picture a lock for your launch lever. There's a ton of ways to use this
