Re: Trail tech temp death and rebirth
Born to be WillD /
> frank dadog Wrote:
> > Thomas TPRF Wrote:
> > Is there an advantage of a thermoresister over a thermocouple?
> Accuracy. The resistor is fixed where thermocouples work on a
> differential. So thermocouples rely much more on calibration for
> accuracy. That being said thermocouples are the probe of choice, being
> cheap and having an extremely wide operating range depending on which
> type you choose. I don't think you can even get a thermistor that
> operates at head temps. Thermocouples are good from hot water to hot
> lava.
no way, any thermocouple will read exactly the same as long as it's made properly and the alloying is correct.
true that thermistors wont go to head temps, they also dont have the range. theyre really accurate but not over a wide range. the third option and probably actually what the trailtech's using are RTD which measures temperature dependent resistance changes. it would also explain why they use ultra tiny wires. probably some precious metal or PM alloy?
but thermocouples are a temperature dependent voltage created by two metals in contact, there's lotsa things that can make em go off in readings, especially changes to resistance in the wiring, or external voltages (I expect however that the erratic readings when running are from inductance from the plug wire rather than part of the spark charge)
they all get thrown off with varying lengths of wire, but thermocouples least so.
I actually don't know a whole lot about thermocouples but i use them for tons of stuff almost daily, i even got a chart of millivolt vs temperature for different thermocouple types as a ready reference taped to the wall next to my desk.
I once tried to use a thermocouple welder to reconnect 2 leads of the end of a trailtech, and it didnt work at all, so that'd also support it being a 2 wire RTD type of thing.
  Trail tech temp death and rebirthTopic by: JBOT Admin JBOT Admin 02/27/18 09:58PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 02/27/18 10:07PM
  Re: Trail tech temp death and rebirthRe: Tyler Dead Possums Tyler Dead Possums 03/01/18 12:33PM
  Re: Trail tech temp death and rebirthRe: Thomas TPRF Thomas TPRF 03/01/18 04:02PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 03/01/18 09:47PM
  Re: Trail tech temp death and rebirthRe: cheetahchrome . cheetahchrome . 03/02/18 12:03AM
  Re: Trail tech temp death and rebirthRe: Born to be WillD Born to be WillD 02/28/18 10:23AM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 02/28/18 10:42AM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 02/28/18 10:50AM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 02/28/18 02:58PM
  Re: Trail tech temp death and rebirthRe: MPB Andyrew MPB Andyrew 02/28/18 03:22PM
  Re: Trail tech temp death and rebirthRe: todd amundson todd amundson 04/16/18 02:29PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 04/16/18 02:34PM
  Re: Trail tech temp death and rebirthRe: Neil Verchot Neil Verchot 02/28/18 10:26AM
  Re: Trail tech temp death and rebirthRe: MPB Andyrew MPB Andyrew 02/28/18 03:23PM
  Re: Trail tech temp death and rebirthRe: Tyler Dead Possums Tyler Dead Possums 03/01/18 01:09PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 03/01/18 01:13PM
  Re: Trail tech temp death and rebirthRe: Tyler Dead Possums Tyler Dead Possums 03/01/18 01:51PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 03/01/18 02:39PM
  Re: Trail tech temp death and rebirthRe: Tyler Dead Possums Tyler Dead Possums 03/01/18 03:02PM
  Re: Trail tech temp death and rebirthRe: * * * * 03/01/18 09:33PM
  Re: Trail tech temp death and rebirthRe: Tyler Dead Possums Tyler Dead Possums 03/02/18 09:10AM
  Re: Trail tech temp death and rebirthRe: * * * * 03/02/18 03:33PM
  Re: Trail tech temp death and rebirthRe: P D P D 03/02/18 06:06PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 03/02/18 08:50PM
  Re: Trail tech temp death and rebirthRe: * * * * 03/03/18 12:30AM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 03/03/18 12:34AM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 03/03/18 12:40AM
  Re: Trail tech temp death and rebirthRe: * * * * 03/03/18 02:12PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 03/03/18 02:44PM
  Re: Trail tech temp death and rebirthRe: * * * * 03/03/18 07:30PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 03/03/18 10:59PM
  Re: Trail tech temp death and rebirthRe: Thomas TPRF Thomas TPRF 03/03/18 03:04PM
  Re: Trail tech temp death and rebirthRe: frank dadog frank dadog 03/03/18 06:05PM
  Re: Trail tech temp death and rebirthRe: Thomas TPRF Thomas TPRF 03/03/18 09:06PM
  Re: Trail tech temp death and rebirthRe: Born to be WillD Born to be WillD 03/06/18 09:56AM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 03/06/18 12:02PM
  Re: Trail tech temp death and rebirthRe: Born to be WillD Born to be WillD 03/06/18 12:38PM
  Re: Trail tech temp death and rebirthRe: EH FCC of the QCB EH FCC of the QCB 04/08/18 10:48AM
  Re: Trail tech temp death and rebirthRe: Born to be WillD Born to be WillD 03/06/18 10:00AM
  Re: Trail tech temp death and rebirthRe: Lazy Pedaler Lazy Pedaler 04/08/18 10:34AM
  Re: Trail tech temp death and rebirthRe: Nick Sullivan Nick Sullivan 12/07/20 09:34PM
  Re: Trail tech temp death and rebirthRe: Nick Sullivan Nick Sullivan 12/07/20 09:37PM
  Re: Trail tech temp death and rebirthRe: todd amundson todd amundson 04/16/18 11:58PM
  Re: Trail tech temp death and rebirthRe: Max LGN Max LGN 04/17/18 06:29AM
  Re: Trail tech temp death and rebirthRe: Born to be WillD Born to be WillD 04/17/18 09:48AM
  Re: Trail tech temp death and rebirthRe: Max LGN Max LGN 04/17/18 12:32PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 05/18/18 11:54PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 03/06/21 05:48PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 03/06/21 06:05PM
  Re: Trail tech temp death and rebirthRe: EH FCC of the QCB EH FCC of the QCB 03/06/21 06:32PM
  Re: Trail tech temp death and rebirthRe: weldwizard Jake weldwizard Jake 12/06/20 08:10PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 12/06/20 08:38PM
  Re: Trail tech temp death and rebirthRe: Rick Bergsma Rick Bergsma 12/12/20 04:16PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 12/12/20 04:21PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 12/12/20 04:23PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 12/12/20 04:28PM
  Re: Trail tech temp death and rebirthRe: Rick Bergsma Rick Bergsma 12/12/20 04:37PM
  Re: Trail tech temp death and rebirthRe: weldwizard Jake weldwizard Jake 12/06/20 08:31PM
  Re: Trail tech temp death and rebirthRe: weldwizard Jake weldwizard Jake 12/06/20 08:39PM
  Re: Trail tech temp death and rebirthRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 12/07/20 12:59PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 12/07/20 01:08PM
  Re: Trail tech temp death and rebirthRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 12/07/20 04:38PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 12/07/20 08:49PM
  Re: Trail tech temp death and rebirthRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 12/08/20 01:06AM
  Re: Trail tech temp death and rebirthRe: Brian F Brian F 12/07/20 11:21PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 12/08/20 12:45AM
  Re: Trail tech temp death and rebirthRe: weldwizard Jake weldwizard Jake 12/08/20 12:36AM
  Re: Trail tech temp death and rebirthRe: Brian F Brian F 12/08/20 11:36AM
  Re: Trail tech temp death and rebirthRe: Graham Motzing Graham Motzing 12/08/20 11:47AM
  Re: Trail tech temp death and rebirthRe: Brian F Brian F 12/09/20 10:45AM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 12/09/20 12:04PM
  Re: Trail tech temp death and rebirthRe: Brian F Brian F 12/09/20 02:53PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 12/09/20 08:33PM
  Re: Trail tech temp death and rebirthRe: Brian F Brian F 12/11/20 11:34AM
  Re: Trail tech temp death and rebirthRe: Graham Motzing Graham Motzing 12/12/20 09:43PM
  Re: Trail tech temp death and rebirthRe: Papa _ Papa _ 12/13/20 09:41AM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 12/18/20 09:32PM
  Re: Trail tech temp death and rebirthRe: Johnny Braaapp Johnny Braaapp 01/16/21 11:11AM
  Re: Trail tech temp death and rebirthRe: P D P D 01/16/21 11:45AM
  Re: Trail tech temp death and rebirthRe: Jason Majernik Jason Majernik 01/12/21 09:26PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 01/12/21 10:53PM
  Re: Trail tech temp death and rebirthRe: Jason Majernik Jason Majernik 01/16/21 12:04AM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 01/16/21 11:00AM
  Re: Trail tech temp death and rebirthRe: Marc Friedman Marc Friedman 01/19/21 12:05PM
  Re: Trail tech temp death and rebirthRe: Johnny Braaapp Johnny Braaapp 01/19/21 12:07PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 01/19/21 01:47PM
