Re: Trail tech temp death and rebirth
Max LGN /
> todd amundson Wrote:
> Nah dude. All three I bought arenโ€™t working. But as soon as I touch the
> original trail tech thermocouple to the cut harness, the shit wakes up.
That is because you cant wire a thermocouple to a trail tech, it was stated earlier the trail-tech uses a thermistor. It's just a resistor. It changes resistance with temperature and the display of the trail tech is simply measuring the ohms and converting it to a displayed temp in C of F.
There are basically two types of thermistors:
NTC = resistance goes up when temp goes down (vice versa)
PTC = resistance goes up when temp goes up (vice versa)
A thermocouple actually produces it's own temperature dependent voltage, so you would need a display that can read this type of sensor. Totally different than the thermistor.
Most thermistors are rated at X amount of ohms at room temp. So a "10k sensor" is 10,000 ohms @ 70F. You can use a multimeter to measure the resistance of the trail tech sensor and then cross that over to some other sensor that might be interchangeable. It is probably a common type of thermistor and Trail tech just has that copper ring put on so it can be mounted to a spark plug.
  Trail tech temp death and rebirthTopic by: JBOT Admin JBOT Admin 02/27/18 09:58PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 02/27/18 10:07PM
  Re: Trail tech temp death and rebirthRe: Tyler Dead Possums Tyler Dead Possums 03/01/18 12:33PM
  Re: Trail tech temp death and rebirthRe: Thomas TPRF Thomas TPRF 03/01/18 04:02PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 03/01/18 09:47PM
  Re: Trail tech temp death and rebirthRe: cheetahchrome . cheetahchrome . 03/02/18 12:03AM
  Re: Trail tech temp death and rebirthRe: Born to be WillD Born to be WillD 02/28/18 10:23AM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 02/28/18 10:42AM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 02/28/18 10:50AM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 02/28/18 02:58PM
  Re: Trail tech temp death and rebirthRe: MPB Andyrew MPB Andyrew 02/28/18 03:22PM
  Re: Trail tech temp death and rebirthRe: todd amundson todd amundson 04/16/18 02:29PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 04/16/18 02:34PM
  Re: Trail tech temp death and rebirthRe: Neil Verchot Neil Verchot 02/28/18 10:26AM
  Re: Trail tech temp death and rebirthRe: MPB Andyrew MPB Andyrew 02/28/18 03:23PM
  Re: Trail tech temp death and rebirthRe: Tyler Dead Possums Tyler Dead Possums 03/01/18 01:09PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 03/01/18 01:13PM
  Re: Trail tech temp death and rebirthRe: Tyler Dead Possums Tyler Dead Possums 03/01/18 01:51PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 03/01/18 02:39PM
  Re: Trail tech temp death and rebirthRe: Tyler Dead Possums Tyler Dead Possums 03/01/18 03:02PM
  Re: Trail tech temp death and rebirthRe: * * * * 03/01/18 09:33PM
  Re: Trail tech temp death and rebirthRe: Tyler Dead Possums Tyler Dead Possums 03/02/18 09:10AM
  Re: Trail tech temp death and rebirthRe: * * * * 03/02/18 03:33PM
  Re: Trail tech temp death and rebirthRe: P D P D 03/02/18 06:06PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 03/02/18 08:50PM
  Re: Trail tech temp death and rebirthRe: * * * * 03/03/18 12:30AM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 03/03/18 12:34AM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 03/03/18 12:40AM
  Re: Trail tech temp death and rebirthRe: * * * * 03/03/18 02:12PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 03/03/18 02:44PM
  Re: Trail tech temp death and rebirthRe: * * * * 03/03/18 07:30PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 03/03/18 10:59PM
  Re: Trail tech temp death and rebirthRe: Thomas TPRF Thomas TPRF 03/03/18 03:04PM
  Re: Trail tech temp death and rebirthRe: frank dadog frank dadog 03/03/18 06:05PM
  Re: Trail tech temp death and rebirthRe: Thomas TPRF Thomas TPRF 03/03/18 09:06PM
  Re: Trail tech temp death and rebirthRe: Born to be WillD Born to be WillD 03/06/18 09:56AM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 03/06/18 12:02PM
  Re: Trail tech temp death and rebirthRe: Born to be WillD Born to be WillD 03/06/18 12:38PM
  Re: Trail tech temp death and rebirthRe: EH FCC of the QCB EH FCC of the QCB 04/08/18 10:48AM
  Re: Trail tech temp death and rebirthRe: Born to be WillD Born to be WillD 03/06/18 10:00AM
  Re: Trail tech temp death and rebirthRe: Lazy Pedaler Lazy Pedaler 04/08/18 10:34AM
  Re: Trail tech temp death and rebirthRe: Nick Sullivan Nick Sullivan 12/07/20 09:34PM
  Re: Trail tech temp death and rebirthRe: Nick Sullivan Nick Sullivan 12/07/20 09:37PM
  Re: Trail tech temp death and rebirthRe: todd amundson todd amundson 04/16/18 11:58PM
  Re: Trail tech temp death and rebirthRe: Max LGN Max LGN 04/17/18 06:29AM
  Re: Trail tech temp death and rebirthRe: Born to be WillD Born to be WillD 04/17/18 09:48AM
  Re: Trail tech temp death and rebirthRe: Max LGN Max LGN 04/17/18 12:32PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 05/18/18 11:54PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 03/06/21 05:48PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 03/06/21 06:05PM
  Re: Trail tech temp death and rebirthRe: EH FCC of the QCB EH FCC of the QCB 03/06/21 06:32PM
  Re: Trail tech temp death and rebirthRe: weldwizard Jake weldwizard Jake 12/06/20 08:10PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 12/06/20 08:38PM
  Re: Trail tech temp death and rebirthRe: Rick Bergsma Rick Bergsma 12/12/20 04:16PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 12/12/20 04:21PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 12/12/20 04:23PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 12/12/20 04:28PM
  Re: Trail tech temp death and rebirthRe: Rick Bergsma Rick Bergsma 12/12/20 04:37PM
  Re: Trail tech temp death and rebirthRe: weldwizard Jake weldwizard Jake 12/06/20 08:31PM
  Re: Trail tech temp death and rebirthRe: weldwizard Jake weldwizard Jake 12/06/20 08:39PM
  Re: Trail tech temp death and rebirthRe: ๐Ÿ‡ฎ๐Ÿ‡น๐Ÿ’ฆ Of the Loin ๐Ÿ‡ฎ๐Ÿ‡น๐Ÿ’ฆ Of the Loin 12/07/20 12:59PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 12/07/20 01:08PM
  Re: Trail tech temp death and rebirthRe: ๐Ÿ‡ฎ๐Ÿ‡น๐Ÿ’ฆ Of the Loin ๐Ÿ‡ฎ๐Ÿ‡น๐Ÿ’ฆ Of the Loin 12/07/20 04:38PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 12/07/20 08:49PM
  Re: Trail tech temp death and rebirthRe: ๐Ÿ‡ฎ๐Ÿ‡น๐Ÿ’ฆ Of the Loin ๐Ÿ‡ฎ๐Ÿ‡น๐Ÿ’ฆ Of the Loin 12/08/20 01:06AM
  Re: Trail tech temp death and rebirthRe: Brian F Brian F 12/07/20 11:21PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 12/08/20 12:45AM
  Re: Trail tech temp death and rebirthRe: weldwizard Jake weldwizard Jake 12/08/20 12:36AM
  Re: Trail tech temp death and rebirthRe: Brian F Brian F 12/08/20 11:36AM
  Re: Trail tech temp death and rebirthRe: Graham Motzing Graham Motzing 12/08/20 11:47AM
  Re: Trail tech temp death and rebirthRe: Brian F Brian F 12/09/20 10:45AM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 12/09/20 12:04PM
  Re: Trail tech temp death and rebirthRe: Brian F Brian F 12/09/20 02:53PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 12/09/20 08:33PM
  Re: Trail tech temp death and rebirthRe: Brian F Brian F 12/11/20 11:34AM
  Re: Trail tech temp death and rebirthRe: Graham Motzing Graham Motzing 12/12/20 09:43PM
  Re: Trail tech temp death and rebirthRe: Papa _ Papa _ 12/13/20 09:41AM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 12/18/20 09:32PM
  Re: Trail tech temp death and rebirthRe: Johnny Braaapp Johnny Braaapp 01/16/21 11:11AM
  Re: Trail tech temp death and rebirthRe: P D P D 01/16/21 11:45AM
  Re: Trail tech temp death and rebirthRe: Jason Majernik Jason Majernik 01/12/21 09:26PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 01/12/21 10:53PM
  Re: Trail tech temp death and rebirthRe: Jason Majernik Jason Majernik 01/16/21 12:04AM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 01/16/21 11:00AM
  Re: Trail tech temp death and rebirthRe: Marc Friedman Marc Friedman 01/19/21 12:05PM
  Re: Trail tech temp death and rebirthRe: Johnny Braaapp Johnny Braaapp 01/19/21 12:07PM
  Re: Trail tech temp death and rebirthRe: JBOT Admin JBOT Admin 01/19/21 01:47PM
