Re: A35 base spacing
P D /
> Alex hernandez Wrote:
> you cut the piston down at the transfers? How did it perform? Was it
> worth the trouble?
I did that on a TM125 that I installed an RM125 piston in . I also changed the skirt configuration .
That turned out to be the best motor . It would perform well from idle , like a trials bike , all the way through to high RPMs . It had no problems staying with , and passing some , 250cc bikes .
  A35 base spacingTopic by: Alex hernandez Alex hernandez 07/27/18 08:16PM
  Re: A35 base spacingRe: Thomas Smith Thomas Smith 07/28/18 08:30AM
  Re: A35 base spacingRe: Alex hernandez Alex hernandez 07/28/18 08:41AM
  Re: A35 base spacingRe: P D P D 07/28/18 10:25AM
  Re: A35 base spacingRe: Alex hernandez Alex hernandez 07/28/18 02:29PM
  Re: A35 base spacingRe: P D P D 07/28/18 06:19PM
  Re: A35 base spacingRe: Chöschi21 C.K. Chöschi21 C.K. 07/31/18 06:53PM
  Re: A35 base spacingRe: Alex hernandez Alex hernandez 08/01/18 08:03AM
  Re: A35 base spacingRe: pat splat pat splat 07/28/18 08:43AM
  Re: A35 base spacingRe: alex ganz alex ganz 07/31/18 12:23PM
  Re: A35 base spacingRe: pat splat pat splat 08/01/18 12:15AM
  Re: A35 base spacingRe: Bob Selby Bob Selby 08/01/18 10:18AM
  Re: A35 base spacingRe: Alex hernandez Alex hernandez 08/01/18 01:22PM
  Re: A35 base spacingRe: Chöschi21 C.K. Chöschi21 C.K. 08/01/18 04:15PM
  Re: A35 base spacingRe: patrick stover patrick stover 08/04/18 11:49AM
  Re: A35 base spacingRe: Alex hernandez Alex hernandez 08/04/18 01:18PM
  Re: A35 base spacingRe: Alex hernandez Alex hernandez 08/06/18 03:55PM
  Re: A35 base spacingRe: Alex hernandez Alex hernandez 08/06/18 03:58PM
  Re: A35 base spacingRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 08/11/18 11:44PM
  Re: A35 base spacingRe: Alex hernandez Alex hernandez 08/12/18 12:02AM
  Re: A35 base spacingRe: Alex hernandez Alex hernandez 08/12/18 12:38AM
  Re: A35 base spacingRe: will warn will warn 08/09/18 07:57PM
  Re: A35 base spacingRe: pat splat pat splat 08/09/18 08:49PM
  Re: A35 base spacingRe: Alex hernandez Alex hernandez 08/10/18 03:49PM
  Re: A35 base spacingRe: P D P D 08/10/18 06:10PM
  Re: A35 base spacingRe: Alex hernandez Alex hernandez 08/11/18 09:05AM
  Re: A35 base spacingRe: Alex hernandez Alex hernandez 08/11/18 09:15AM
  Re: A35 base spacingRe: Baron Von Moped Baron Von Moped 08/12/18 10:04AM
  Re: A35 base spacingRe: pat splat pat splat 08/11/18 06:06PM
  Re: A35 base spacingRe: Alex hernandez Alex hernandez 08/12/18 02:58PM
  Re: A35 base spacingRe: Alex hernandez Alex hernandez 08/13/18 01:17AM
  Re: A35 base spacingRe: Alex hernandez Alex hernandez 08/23/18 09:03AM
  Re: A35 base spacingRe: jon t jon t 12/22/18 09:47AM
  Re: A35 base spacingRe: Alex hernandez Alex hernandez 12/22/18 02:43PM
