Re: A35 base spacing
Chöschi21 C.K. /
I do this kind of stuff a lot, realy wouldn't recomend to mod the Pistonhead, also, if you would only go up on the Transfers you will damage your Piston and Cylinder over time because the time between opening the Exhaust and opening the Transfers would get shorter, i added an image to this post, a good tip is to Shape the parts canals that you put into the Pistons how the Ports flow.
Edit: if you can, use a Spacer, if not just go for 115° Transfers and 150° Exhaust. (edited)
  A35 base spacingTopic by: Alex hernandez Alex hernandez 07/27/18 08:16PM
  Re: A35 base spacingRe: Thomas Smith Thomas Smith 07/28/18 08:30AM
  Re: A35 base spacingRe: Alex hernandez Alex hernandez 07/28/18 08:41AM
  Re: A35 base spacingRe: P D P D 07/28/18 10:25AM
  Re: A35 base spacingRe: Alex hernandez Alex hernandez 07/28/18 02:29PM
  Re: A35 base spacingRe: P D P D 07/28/18 06:19PM
  Re: A35 base spacingRe: Chöschi21 C.K. Chöschi21 C.K. 07/31/18 06:53PM
  Re: A35 base spacingRe: Alex hernandez Alex hernandez 08/01/18 08:03AM
  Re: A35 base spacingRe: pat splat pat splat 07/28/18 08:43AM
  Re: A35 base spacingRe: alex ganz alex ganz 07/31/18 12:23PM
  Re: A35 base spacingRe: pat splat pat splat 08/01/18 12:15AM
  Re: A35 base spacingRe: Bob Selby Bob Selby 08/01/18 10:18AM
  Re: A35 base spacingRe: Alex hernandez Alex hernandez 08/01/18 01:22PM
  Re: A35 base spacingRe: Chöschi21 C.K. Chöschi21 C.K. 08/01/18 04:15PM
  Re: A35 base spacingRe: patrick stover patrick stover 08/04/18 11:49AM
  Re: A35 base spacingRe: Alex hernandez Alex hernandez 08/04/18 01:18PM
  Re: A35 base spacingRe: Alex hernandez Alex hernandez 08/06/18 03:55PM
  Re: A35 base spacingRe: Alex hernandez Alex hernandez 08/06/18 03:58PM
  Re: A35 base spacingRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 08/11/18 11:44PM
  Re: A35 base spacingRe: Alex hernandez Alex hernandez 08/12/18 12:02AM
  Re: A35 base spacingRe: Alex hernandez Alex hernandez 08/12/18 12:38AM
  Re: A35 base spacingRe: will warn will warn 08/09/18 07:57PM
  Re: A35 base spacingRe: pat splat pat splat 08/09/18 08:49PM
  Re: A35 base spacingRe: Alex hernandez Alex hernandez 08/10/18 03:49PM
  Re: A35 base spacingRe: P D P D 08/10/18 06:10PM
  Re: A35 base spacingRe: Alex hernandez Alex hernandez 08/11/18 09:05AM
  Re: A35 base spacingRe: Alex hernandez Alex hernandez 08/11/18 09:15AM
  Re: A35 base spacingRe: EH FCC of the QCB EH FCC of the QCB 08/12/18 10:04AM
  Re: A35 base spacingRe: pat splat pat splat 08/11/18 06:06PM
  Re: A35 base spacingRe: Alex hernandez Alex hernandez 08/12/18 02:58PM
  Re: A35 base spacingRe: Alex hernandez Alex hernandez 08/13/18 01:17AM
  Re: A35 base spacingRe: Alex hernandez Alex hernandez 08/23/18 09:03AM
  Re: A35 base spacingRe: jon t jon t 12/22/18 09:47AM
  Re: A35 base spacingRe: Alex hernandez Alex hernandez 12/22/18 02:43PM
