Re: Stock-ish vespa pipes, who's run them
Also following, seeing as I am now a 1st time ciao owner.... a super clean euro model with oil injection. Mine came with a mystery circuit, but I've never liked circuits on anything simply because of their sound.
My plan is to run it stock for little with the circuit, then swap for one of the above mentioned pipes, probably the gianelli stock if I can find one. Then, slap a malossi 43mm on it and see how it does.
  Stock-ish vespa pipes, who's run themTopic by: Graham Motzing Graham Motzing 10/04/18 12:46PM
  Re: Stock-ish vespa pipes, who's run themRe: Seth B Seth B 10/04/18 01:28PM
  Re: Stock-ish vespa pipes, who's run themRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/04/18 01:44PM
  Re: Stock-ish vespa pipes, who's run themRe: P D P D 10/04/18 02:17PM
  Re: Stock-ish vespa pipes, who's run themRe: Seth B Seth B 10/05/18 12:02AM
  Re: Stock-ish vespa pipes, who's run themRe: Les B. Les B. 10/04/18 02:26PM
  Re: Stock-ish vespa pipes, who's run themRe: Monti S Monti S 10/04/18 02:29PM
  Re: Stock-ish vespa pipes, who's run themRe: Bad Cadillac™ Bad Cadillac™ 10/04/18 02:47PM
  Re: Stock-ish vespa pipes, who's run themRe: Ollie Tabooger Ollie Tabooger 10/04/18 03:15PM
  Re: Stock-ish vespa pipes, who's run themRe: Dirty30 Dillon Dirty30 Dillon 10/05/18 09:45AM
  Re: Stock-ish vespa pipes, who's run themRe: Derek Stahl Derek Stahl 10/04/18 06:25PM
  Re: Stock-ish vespa pipes, who's run themRe: Burrrrito Sanchez Burrrrito Sanchez 10/04/18 07:14PM
  Re: Stock-ish vespa pipes, who's run themRe: Graham Motzing Graham Motzing 10/04/18 11:38PM
  Re: Stock-ish vespa pipes, who's run themRe: alex . alex . 10/05/18 11:48AM
  Re: Stock-ish vespa pipes, who's run themRe: Graham Motzing Graham Motzing 10/05/18 12:59PM
  Re: Stock-ish vespa pipes, who's run themRe: Marc Friedman Marc Friedman 10/05/18 09:15PM
  Re: Stock-ish vespa pipes, who's run themRe: Gerry F Gerry F 10/09/18 04:57PM
  Re: Stock-ish vespa pipes, who's run themRe: Daniel '' Daniel '' 10/09/18 08:58PM
  Re: Stock-ish vespa pipes, who's run themRe: Dirty30 Dillon Dirty30 Dillon 10/10/18 08:33AM
  Re: Stock-ish vespa pipes, who's run themRe: Seth B Seth B 10/10/18 12:36PM
  Re: Stock-ish vespa pipes, who's run themRe: Dirty30 Dillon Dirty30 Dillon 10/10/18 01:12PM
  Re: Stock-ish vespa pipes, who's run themRe: Seth B Seth B 10/10/18 01:37PM
  Re: Stock-ish vespa pipes, who's run themRe: Marc Friedman Marc Friedman 10/10/18 04:37PM
  Re: Stock-ish vespa pipes, who's run themRe: Seth B Seth B 10/10/18 05:03PM
  Re: Stock-ish vespa pipes, who's run themRe: Marc Friedman Marc Friedman 10/10/18 05:18PM
  Re: Stock-ish vespa pipes, who's run themRe: Seth B Seth B 10/10/18 06:16PM
  Re: Stock-ish vespa pipes, who's run themRe: Stephen Keller Stephen Keller 10/11/18 04:04AM
  Re: Stock-ish vespa pipes, who's run themRe: Bad Cadillac™ Bad Cadillac™ 10/11/18 06:59AM
  Re: Stock-ish vespa pipes, who's run themRe: Gerry F Gerry F 10/10/18 10:18PM
  Re: Stock-ish vespa pipes, who's run themRe: Marc Friedman Marc Friedman 10/10/18 05:24PM
  Re: Stock-ish vespa pipes, who's run themRe: Marc Friedman Marc Friedman 10/10/18 05:29PM
  Re: Stock-ish vespa pipes, who's run themRe: Graham Motzing Graham Motzing 10/11/18 10:12AM
  Re: Stock-ish vespa pipes, who's run themRe: P D P D 10/11/18 10:48AM
  Re: Stock-ish vespa pipes, who's run themRe: Marc Friedman Marc Friedman 10/11/18 11:08AM
  Re: Stock-ish vespa pipes, who's run themRe: P D P D 10/11/18 11:37AM
  Re: Stock-ish vespa pipes, who's run themRe: Declan g Declan g 10/19/18 02:31PM
  Re: Stock-ish vespa pipes, who's run themRe: Seth B Seth B 01/11/20 09:11PM
  Re: Stock-ish vespa pipes, who's run themRe: Daniel '' Daniel '' 01/12/20 09:06PM
  Re: Stock-ish vespa pipes, who's run themRe: Dirty30 Dillon Dirty30 Dillon 01/12/20 09:35PM
  Re: Stock-ish vespa pipes, who's run themRe: Seth B Seth B 01/13/20 02:44AM
  Re: Stock-ish vespa pipes, who's run themRe: Ike Pipe Ike Pipe 01/13/20 09:10AM
  Re: Stock-ish vespa pipes, who's run themRe: Seth B Seth B 01/13/20 01:53PM
  Re: Stock-ish vespa pipes, who's run themRe: Daniel '' Daniel '' 01/13/20 01:37PM
  Re: Stock-ish vespa pipes, who's run themRe: Graham Motzing Graham Motzing 01/13/20 12:36PM
  Re: Stock-ish vespa pipes, who's run themRe: Born to be WillD Born to be WillD 01/14/20 02:11PM
  Re: Stock-ish vespa pipes, who's run themRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/13/20 11:25AM
  Re: Stock-ish vespa pipes, who's run themRe: Ken Thomas Ken Thomas 06/10/20 01:51AM
  Re: Stock-ish vespa pipes, who's run themRe: Dirty30 Dillon Dirty30 Dillon 06/10/20 10:08AM
  Re: Stock-ish vespa pipes, who's run themRe: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 06/10/20 02:00AM
  Re: Stock-ish vespa pipes, who's run themRe: Todd S Todd S 06/10/20 03:36AM
  Re: Stock-ish vespa pipes, who's run themRe: Marc Friedman Marc Friedman 06/10/20 12:53PM
  Re: Stock-ish vespa pipes, who's run themRe: Dirty30 Dillon Dirty30 Dillon 06/10/20 01:00PM
  Re: Stock-ish vespa pipes, who's run themRe: Marc Friedman Marc Friedman 06/10/20 01:06PM
  Re: Stock-ish vespa pipes, who's run themRe: Dirty30 Dillon Dirty30 Dillon 06/10/20 01:58PM
  Re: Stock-ish vespa pipes, who's run themRe: Marc Friedman Marc Friedman 06/10/20 02:08PM
  Re: Stock-ish vespa pipes, who's run themRe: Kevin Bishop Kevin Bishop 06/10/20 11:42PM
