Re: qt50 exhaust porting
Jack Rutherford /
you're probably better off grinding down the exhaust side of the piston a couple mm. It's softer and easier to work. I think there are examples posted on this site for different bikes but same idea. If you screw up, a new piston is $20 or so. The softer metal will open up your choice of bits quite a bit as well.
