Re: qt50 exhaust porting
Jack Rutherford /
And here's your dinner:
All the bits you need and you can find them at ccspecialty
Follow his instructions and you should be fine. You can probably go 2mm easily when you raise the exhaust port on the qt. Or you can go 1mm and then run it and see and go more later. (edited)
