Re: qt50 exhaust porting
Jack Rutherford /
I'm just wondering if you raised the exhaust port at all. You can usually do so at least a couple mm without issue. You'll lose a little low end. You can also widen the exhaust port slightly without so much hit on low end. If you watched those Ken O'connor videos and followed them, you're right on track.
