Franco Morini Mo1 swap w/ a Mo4 on a Snark Satellite/Pacer Supersport
Kevin O'Connor /
Has anyone tried to bolt a Mo4 engine up to a frame designed for a Mo1 engine? I am contemplating buying a Mo4 from Europe and installing it on my Snark Satellite. I know it won't be a "moped" then, but that is not a concern of mine. All I have found doing research is a very poor dimensioned drawing of a Mo4. I cannot read the spacing between engine mounting bolts. Can you?
Re: Franco Morini Mo1 swap w/ a Mo4 on a Snark Satellite/Pacer Supersport
Dirty30 Dillon /
I believe the MO4 shares engine mounting dimensions with the M101.
Either way, TriPed Dave can chime in and provide some more info
Kevin O'Connor /
bump
It looks very similar to the dimensions of the m101
Kevin O'Connor /
Can you read those numbers on that picture? If so what does it read for the distance between engine mounting bolt holes?
Hello no I can't read that shit
Dirty30 Dillon /
If you message Tri-Ped Dave, he would give you an answer right away.
It definitely does not swap directly for the M01/M1 motor mounts. And looking at a diagram of the M101, it definitely has a different bottom mounting position as well.
Kevin O'Connor /
Thanks I sent him a PM.
