Nc50 2 speed max rpm, what's safe
Sup everyone, got my 2 speed juiced up and have had it to 53gps so far, which is probably about 13 or 14k rpm based on rough math. I had a working tack with the old kit it did 46 at 12,500. Anyways, it got power at 53 and feels like it would roll over a few more mph but its screaming so hard I'm kinda worried about what's gonna break next.
So what has everyone been gettin away with on stock honda cranks. I know variated bikes are bustin up cranks but that's a f*ck load more heat on a crank then the 2 speed assy imo.(edited)
Re: Nc50 2 speed max rpm, what's safe
Well that's faster than the Cox Brothers
Back when I use to play with the express's I never had luck with the 2 speed transmissions holding together, had multiple clutch bell failures, but I was running pretty high millage bikes with little to no attention paid to the transmissions before making them fast.
I had a 77 one speed that topped out at 53, those things kinda suck at those speeds.
53 with a one speed! I bet that rode real easy in traffic lol mine pipes up at about 10k. I got a spare transmission in a box, I'm more worried about the crank. I change the oil often, 20/50 motorcycle oil.
I'll also post another thread about how to make that 2 speed hold 1st gear to about 35mph, want easy. Not much info out there for the 14" bikes.
Both transmissions have the exact same total transmission ratio. The rpm will be the same at top speed.(edited)
Jack Rutherford /
assuming a tire diameter of 18.75", you're at 13,506. I would guess you are on the edge of no return. Let us know if there's more in it or not.(edited)
I ordered a cheap inductive tack on prime, will report back in 2 days what max rpm is. Back tire is a 14×2.75 which wasnt easy to fit... it seems reliable I just put over 200 miles on it in key west a few weeks ago.
Jack Rutherford /
with that tire, rpms will be lower than I calculated. What's your setup?
Setup doesn't matter, just speed and tire circumference. Oh, and that the speed is not a lie.
I'm runnin an athena 47.6mm kit ported192/138 with some off brand o ringed head set up 60psi compression 1.5mm quench, dio v block with kx65 boyesen reeds, 26mm round slide mikuni, custom/home made exhaust, lots o transmission mods. Pretty dope setup most dudes dont believe it till they see it. It shreds harder then any 14" bike I've ever seen lol
Jack Rutherford /
I asked because I figured it was the Athena kit. spacer? What transmission mods? I assume you mean 160 psi compression? custom intake?
No 60psi. Its been my experience that in general high compression on a 2 stroke is a fools errand, minor low end gained with reliability lost to pay. Plus they always roll over smoother the lower the compression. I run all my jet skis under 120psi, my 250r the highest at 160.
Just a 1mm spacer to get the compression down, like I said 1.5mm deck with an o ringed head. The athena hit came 1mm lower on the transfers then the wizard kit so it took allot of careful porting to get the t ports up where I wanted.
Wizard kit piston exploded at around 48mph cylinder pictured is the new athena.
I'll have to dig around for any pics of the trans
I question an engine's ability to run with 60psi compression.
The dome is like a toilet bowl. Its huge. Most marine engines come about 80-110 psi spankin new in case the moped dudes weren't aware. It's a lot less load on the rotating assy and less heat in the head/exh port. Cold start is obviously compromised. Throttle response under 6k is sh*t. Unridable/impossinle to tune without some clutch work but on such a tiny short stroke extreme rpm engine I see no need for insane cyl pressure. It just turns to heat/pumping loss in the rpm range were using these things at.
In the Simplex world , motors can run nicely at 60 pounds compression . They are not the best at climbing hills , but , do run 45 to 50 MPH .
Overpriced Parts /
I want that hit a dog in the ass with those kind of bikes but hell you did really good job !
