How far you go bro
I went this far.
It's cool.
Re: How far you go bro
I should go much farther
Yes you should at least install it and see how well it works.
But it does look with this Spring's being clockwise and bent the way that they are that it's going to bump against the other shoe when they engage you might want to consider flipping a Springs over so the hooks are pointing up so it has more clearance at the spring at the tip of the pad to the Pivot Point of that pad next to it.
I already tried it wayne.
It's great. Nothing hits except the POWWHHHHHHHHHHH
But more off is more better. Then I can run weaker springs (edited)
How much do the pads weigh each right now?
since you have the extra holes there you could probably use weaker Springs just by mounting them where the red lines are instead of where they are now that will give you more spring pressure holding the pad in against the centrifical force than what you have with the current mounting points.
πΏπ‘–π‘˜π‘Ž-πΏπ‘œπ‘‘π‘Žπ‘ π‘Žπ‘’π‘Ÿ π‘€π‘’π‘”π‘Žπ‘π‘’π‘  πŸ¦– /
All the way, that’s the way that she goes, and none of their mommas ever seem to know.
I like’m with red dio springs, a couple busted one night. Went a fuzz to far or mishap whoopsie
Cut 10g. off each arm was fun. (edited)
Stock Urban clutch springs fit great like that
Cool stuff
And the other thing puting the springs in that red pattern of placement puts them directly at a right angle to the pivot pin.
I have a few more urban springs cool.
Much tighter installing the springs this way. Couldn’t poke the wire thru the other holes as well. Wa yu do?
Lots of urban clutch swaps happening, could find a stock one shelved and borrow the springs
I call this mod Hannukklutch
LOLOLOLOL!!!! Thats gold-man
(see what i did there? EHHH??) :D
I think your close but I would go here too.
Triple popping! Jesse Stephenson did this on his hobbit a few years back, had a super good clutch stall. Felt like a well tuned scooter clutch, wheelies were inevitable with the ported athena he had on there. Needless to say it was too much ripping and roasted the posts.
Good thinkin’!
Fusterclutch
Bwhahaha
pentagram or gtfo.
Ahhah!
Pentagraham
This thread is great
What's the highest rpm y'all got?
I've never tried a lightened clutch with malossi blacks but I bet that could be a 9k stall.
Standard clutch with MB is 8k I think (edited)
^i bet that one stalls to 666 rpm
Joe Schuitema /
Malossi reds with moved spring holes gets me to 7500 rpm. I'd guess the blacks would push it to 9000
this fucking thread has me rolling haha
« Go to Topics β€” end of thread
