Re: Change top angle of driven pulley
JBOT Admin /
Kicks ass. Could move the wheel about 3/4 inch forward. Zero slip.
Just need some stronger springs and it will be nutso. Those stretched blues are a lil weak.
Either I'll do malossi blacks or I'll try the clutch of David. Problem is I tried that once and all the springs ended up eating themselves.. it fucked up the cases too.
Btw, is there any way of getting malossi blacks without buying the whole fucking set of springs?
Only issue with this was the original thin pulley steel warping. Didn't matter that much as I recut the whole cheek. But yeah, thin steel and heat are very warp prone. Funny thing is that the outer cheek is actually more true now than the original cheek was. I turned the whole assembley on an old hobbit input shaft from the gearbox. That way it's true where it's important. Based on the shaft center
  Change top angle of driven pulleyTopic by: JBOT Admin JBOT Admin 12/16/18 01:30PM
  Re: Change top angle of driven pulleyRe: scrot rash scrot rash 12/16/18 02:39PM
  Re: Change top angle of driven pulleyRe: JBOT Admin JBOT Admin 12/16/18 07:53PM
  Re: Change top angle of driven pulleyRe: Crazy Wayne Crazy Wayne 12/16/18 03:12PM
  Re: Change top angle of driven pulleyRe: JBOT Admin JBOT Admin 12/16/18 07:55PM
  Re: Change top angle of driven pulleyRe: JBOT Admin JBOT Admin 12/16/18 08:47PM
  Re: Change top angle of driven pulleyRe: alex . alex . 12/17/18 02:48AM
  Re: Change top angle of driven pulleyRe: scrot rash scrot rash 12/17/18 10:51AM
  Re: Change top angle of driven pulleyRe: alex . alex . 12/17/18 12:14PM
  Re: Change top angle of driven pulleyRe: JBOT Admin JBOT Admin 12/17/18 12:22PM
  Re: Change top angle of driven pulleyRe: alex . alex . 12/17/18 04:54PM
  Re: Change top angle of driven pulleyRe: JBOT Admin JBOT Admin 12/17/18 05:01PM
  Re: Change top angle of driven pulleyRe: JBOT Admin JBOT Admin 12/17/18 05:10PM
  Re: Change top angle of driven pulleyRe: JBOT Admin JBOT Admin 12/17/18 05:32PM
  Re: Change top angle of driven pulleyRe: JBOT Admin JBOT Admin 12/17/18 05:37PM
  Re: Change top angle of driven pulleyRe: JBOT Admin JBOT Admin 12/17/18 07:00PM
  Re: Change top angle of driven pulleyRe: JBOT Admin JBOT Admin 12/17/18 07:45PM
  Re: Change top angle of driven pulleyRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 12/18/18 01:59PM
  Re: Change top angle of driven pulleyRe: alex . alex . 12/18/18 03:31AM
  Re: Change top angle of driven pulleyRe: JBOT Admin JBOT Admin 12/18/18 01:16PM
  Re: Change top angle of driven pulleyRe: Crazy Wayne Crazy Wayne 12/18/18 01:19PM
  Re: Change top angle of driven pulleyRe: scrot rash scrot rash 12/19/18 06:28AM
  Re: Change top angle of driven pulleyRe: scrot rash scrot rash 12/17/18 05:45PM
  Re: Change top angle of driven pulleyRe: JBOT Admin JBOT Admin 12/17/18 11:53AM
  Re: Change top angle of driven pulleyRe: scrot rash scrot rash 12/17/18 12:50PM
  Re: Change top angle of driven pulleyRe: JBOT Admin JBOT Admin 12/17/18 04:59PM
  Re: Change top angle of driven pulleyRe: alex . alex . 12/17/18 05:16PM
