Re-working the jawa/e50 build.
Alex Hedrick /
I got new cylinder studs, exhaust studs clutch cover bolts.
The new 6.4 jammer.
MLM 1mm base spacer and 2 .5mm base gaskets. Just a bunch of shit.
I'm going to be tearing down the e50 k-star 70cc build so I can do some port timing, deck the cylinder .031 (.8mm) open boost ports on the piston and knotch the skirt 1 or 2mm on intake side. Maybe open up the intake a little and for sure widen the exhaust 1mm each side.
Stay tuned. I'll be posting lots of pictures along the way. And maybe some videos.
  Re-working the jawa/e50 build.Topic by: Alex Hedrick Alex Hedrick 01/14/19 09:18PM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/15/19 12:01AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/15/19 10:27AM
  Re: Re-working the jawa/e50 build.Re: Chöschi21 C.K. Chöschi21 C.K. 01/19/19 08:38PM
  Re: Re-working the jawa/e50 build.Re: Daniel '' Daniel '' 01/19/19 09:56PM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/20/19 01:20AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 05:21AM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/20/19 07:26AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 07:45AM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/20/19 09:29AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 09:33AM
  Re: Re-working the jawa/e50 build.Re: P D P D 01/20/19 10:44AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 10:48AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/17/19 04:10PM
  Re: Re-working the jawa/e50 build.Re: alex . alex . 01/19/19 05:06AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/19/19 07:40AM
  Re: Re-working the jawa/e50 build.Re: P D P D 01/19/19 11:09AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/19/19 11:20AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/17/19 04:36PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/17/19 05:07PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/18/19 09:37PM
  Re: Re-working the jawa/e50 build.Re: Graham Motzing Graham Motzing 01/19/19 09:37AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/19/19 10:34AM
  Re: Re-working the jawa/e50 build.Re: Graham Motzing Graham Motzing 01/19/19 04:08PM
  Re: Re-working the jawa/e50 build.Re: P D P D 01/19/19 05:20PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/18/19 09:39PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/18/19 10:31PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/19/19 11:06AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/19/19 08:46PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 12:24PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 12:39PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 07:13PM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/20/19 07:14PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 07:22PM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/20/19 10:21PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 10:26PM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/20/19 10:44PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 10:58PM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/21/19 12:46AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/21/19 12:53AM
  Re: Re-working the jawa/e50 build.Re: Graham Motzing Graham Motzing 01/21/19 11:14AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/21/19 11:35AM
  Re: Re-working the jawa/e50 build.Re: Graham Motzing Graham Motzing 01/21/19 12:40PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/21/19 03:05PM
  Re: Re-working the jawa/e50 build.Re: alex . alex . 01/21/19 02:40AM
  Re: Re-working the jawa/e50 build.Re: Max Ginsburg Max Ginsburg 01/22/19 04:55AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/22/19 05:16AM
  Re: Re-working the jawa/e50 build.Re: Max Ginsburg Max Ginsburg 01/22/19 06:25AM
  Re: Re-working the jawa/e50 build.Re: kevin Smellaflange kevin Smellaflange 01/24/19 07:31PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/26/19 04:32PM
  Re: Re-working the jawa/e50 build.Re: P D P D 01/26/19 06:01PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/26/19 06:11PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/26/19 07:12PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/26/19 07:14PM
  Re: Re-working the jawa/e50 build.Re: P D P D 01/26/19 08:29PM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/26/19 08:24PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/26/19 08:32PM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/26/19 08:25PM
  Re: Re-working the jawa/e50 build.Re: Graham Motzing Graham Motzing 01/28/19 02:46PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/28/19 02:49PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 02/02/19 12:47PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 02/02/19 01:33PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 02/03/19 06:53PM
  Re: Re-working the jawa/e50 build.Re: Francois Labat Francois Labat 02/05/19 12:20PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 02/05/19 12:27PM
  Re: Re-working the jawa/e50 build.Re: Louis Brunskill Louis Brunskill 02/08/19 11:17PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 02/08/19 11:25PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 02/11/19 09:13PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 02/25/19 05:37PM
  Re: Re-working the jawa/e50 build.Re: Bob Selby Bob Selby 03/02/19 05:22PM
