Re: Re-working the jawa/e50 build.
> Alex Hedrick Wrote:
> I do have the stock ignition flywheel, plate and coils.. I'm really
> thinking that's the problem..
> I mean it's good for a non ripper, good lighting power too. But, I'm
> gunna buy a new cdi tonight.. i want something with a curve and I still
> need lights..
> What do you think i go with?
> I'm thinking hpi mini?? Trying to keep $$ down as this has to be the
> last thing I get for this thing.
I wouldnt go hpi unless you get the 300 gram weight with it. I ran the mini rotor as is for awhile...and while it did rip, it was not great for a daily bike. The rotor is so light, about 1/3 the weight of the original, and also way smaller in diameter, so it makes a consistent idle damn near impossible not having the momentum to help carry through each stroke, especially with high compression setups. Supposedly the weight helps the crankshaft bearings last longer as well.
  Re-working the jawa/e50 build.Topic by: Alex Hedrick Alex Hedrick 01/14/19 09:18PM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/15/19 12:01AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/15/19 10:27AM
  Re: Re-working the jawa/e50 build.Re: Chöschi21 C.K. Chöschi21 C.K. 01/19/19 08:38PM
  Re: Re-working the jawa/e50 build.Re: Daniel '' Daniel '' 01/19/19 09:56PM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/20/19 01:20AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 05:21AM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/20/19 07:26AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 07:45AM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/20/19 09:29AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 09:33AM
  Re: Re-working the jawa/e50 build.Re: P D P D 01/20/19 10:44AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 10:48AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/17/19 04:10PM
  Re: Re-working the jawa/e50 build.Re: alex . alex . 01/19/19 05:06AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/19/19 07:40AM
  Re: Re-working the jawa/e50 build.Re: P D P D 01/19/19 11:09AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/19/19 11:20AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/17/19 04:36PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/17/19 05:07PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/18/19 09:37PM
  Re: Re-working the jawa/e50 build.Re: Graham Motzing Graham Motzing 01/19/19 09:37AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/19/19 10:34AM
  Re: Re-working the jawa/e50 build.Re: Graham Motzing Graham Motzing 01/19/19 04:08PM
  Re: Re-working the jawa/e50 build.Re: P D P D 01/19/19 05:20PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/18/19 09:39PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/18/19 10:31PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/19/19 11:06AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/19/19 08:46PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 12:24PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 12:39PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 07:13PM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/20/19 07:14PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 07:22PM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/20/19 10:21PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 10:26PM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/20/19 10:44PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/20/19 10:58PM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/21/19 12:46AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/21/19 12:53AM
  Re: Re-working the jawa/e50 build.Re: Graham Motzing Graham Motzing 01/21/19 11:14AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/21/19 11:35AM
  Re: Re-working the jawa/e50 build.Re: Graham Motzing Graham Motzing 01/21/19 12:40PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/21/19 03:05PM
  Re: Re-working the jawa/e50 build.Re: alex . alex . 01/21/19 02:40AM
  Re: Re-working the jawa/e50 build.Re: Max Ginsburg Max Ginsburg 01/22/19 04:55AM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/22/19 05:16AM
  Re: Re-working the jawa/e50 build.Re: Max Ginsburg Max Ginsburg 01/22/19 06:25AM
  Re: Re-working the jawa/e50 build.Re: kevin Smellaflange kevin Smellaflange 01/24/19 07:31PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/26/19 04:32PM
  Re: Re-working the jawa/e50 build.Re: P D P D 01/26/19 06:01PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/26/19 06:11PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/26/19 07:12PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/26/19 07:14PM
  Re: Re-working the jawa/e50 build.Re: P D P D 01/26/19 08:29PM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/26/19 08:24PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/26/19 08:32PM
  Re: Re-working the jawa/e50 build.Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/26/19 08:25PM
  Re: Re-working the jawa/e50 build.Re: Graham Motzing Graham Motzing 01/28/19 02:46PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 01/28/19 02:49PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 02/02/19 12:47PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 02/02/19 01:33PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 02/03/19 06:53PM
  Re: Re-working the jawa/e50 build.Re: Francois Labat Francois Labat 02/05/19 12:20PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 02/05/19 12:27PM
  Re: Re-working the jawa/e50 build.Re: Louis Brunskill Louis Brunskill 02/08/19 11:17PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 02/08/19 11:25PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 02/11/19 09:13PM
  Re: Re-working the jawa/e50 build.Re: Alex Hedrick Alex Hedrick 02/25/19 05:37PM
  Re: Re-working the jawa/e50 build.Re: Bob Selby Bob Selby 03/02/19 05:22PM
